04-16-2014, 04:30 PM | #1 |
Rep 1,251
Max sizing for OEM style 219 18'
Whats the biggest sized tires you can fit on the oem Style 219 18' ?
2013 Scion FR-S
2009 BMW E92 M3 2008 BMW E90 335i 2005 BMW X3 3.0i |
04-16-2014, 05:11 PM | #2 |
Rep 6,734
Biggest sizes that fit or biggest sizes that fit AND provide good performance? Your performance gain is diminished if you install a tire that's too wide for the rim.
I wouldn't go wider than 275 mm on the 9.5" rear wheel and 255mm on the 8.5" front wheel. There are people who have gone wider but I don't recommend it. Some autocross rules limit wheel sizing so I have seen some auto-crossers run very wide tires on OEM wheels.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 04-16-2014 at 05:37 PM.. |
04-16-2014, 11:18 PM | #3 | |
Rep 1,251
I want the biggest size that fits an3d provide good performance,
I am on Dinan Stage 1 suspension and 219M 18' wheels F: 245/40R18 -> F: 255/40R18 R: 265/40R18 -> R: 275/40R18 Quote:
2013 Scion FR-S
04-16-2014, 11:20 PM | #4 |
Rep 5,483
I've used 295/30 and 315/30 on OEM siZed wheels. It all depends on the application
A few have run the 285/35 on the rear. I would go with that along with 255/40 front, if i was bent on sticking with OEM wheels. Or a 275/40. Not as many good tires available in that size though
04-17-2014, 01:18 PM | #5 |
Rep 6,734
Richbot is the person I had in mind when I stated that some Auto-crosser's run super wide tires on OEM wheels.
I would choose 255/40/18 front and 275/40/18 rear tires but.... as Rich said, there aren't many tires available in that size. Due to the tire availability limitations I would personnally stick with OEM sizes and choose Michelin PSS for street use or, if you want something wider with more grip, then I would go with Yokohama AD08R's. The AD08's will look at least one size wider because they run very wide and square. That would actually be a great option in OEM sizes. The Bridgestone RE11 and Hankook RS3's are also available in OEM sizes. I would choose the AD08R's given those options but be prepared for a shorter tire life.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 04-18-2014 at 11:52 AM.. |
04-17-2014, 11:24 PM | #6 | |
Rep 1,251
2013 Scion FR-S
04-18-2014, 01:44 AM | #7 |
Rep 5,329
i have a semi slick 235/40 and 265/35 , the actual section width is much wider with a semi slick. They sit how a road tyre of 245 and 285 widths would do.... heres my 260 oem 18" albeit on a different platform.
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
04-18-2014, 04:04 PM | #8 |
Rep 1,251
Anyone know what this set up is?
2013 Scion FR-S
04-18-2014, 05:42 PM | #9 |
Stop the hate, get a V8
3851
Rep 8,625
Wider is not better, as others have said. You can't really have it both ways: as you go wider, the performance benefits shrink and steering feel goes way down, especially for a street-driven car.
My advice is to stick with the stock size or maybe go 10mm wider front and back. BMW selected that particular wheel & tire setup for a reason (i.e. they test it extensively). If you really really want wider tires, buy new wheels that are wider. The 359M/ZCP wheels are wider and can take beefier tires. Most of us run 255/275 on those for a nicely-squared sidewall.
Past: 2011.5 M3 sedan ZCP |
04-23-2014, 08:04 AM | #11 |
Rep 280
I was greedy and went with 265/30-19 and 275/30-19 on my 220m. While not 18's the widths are the same.
I think I should have stuck with the stock sizes instead. I did give up a bit of steering response but not enough to lose performance . i am quicker with these vs michelin pss on autox course for sure. Ad08r have very stiff sidewalls. Im sure that is the only reason I get away with it. |
04-23-2014, 10:48 AM | #12 |
Rep 115
Well for me I want to get the Michelin A/S 3's for colder weather and for OEM 18's you have to go up a size for the rears to 275/40ZR18 because they don't sell it in 265/40ZR18, go figure. Assuming should also bump up the fronts to 255 as well.
04-25-2014, 02:19 PM | #13 |
Rep 1,123
275 Rears and 255 Fronts on the style 219s
2008 E92 BMW M3 MR/BB 6MT
|Gintani Supercharged|Gintani X-Pipe|Stack Gauges|Volk TE37SL|BC Racing Coilovers|Nitto NT05R |BMW Performance Spoiler|BMW Performance Steering Wheel|BMW Performance Side Gills + Grilles|Mode Carbon V1 Endurance|IND Tri- Stitched Shift + Brake Boot - 566WHP, 371WTQ | |
04-26-2014, 03:03 AM | #14 |
Rep 5,329
incredible looking car.... these wheels look so awesome on these track cars!!
08-14-2015, 01:33 PM | #16 |
Rep 3,482
They shouldn't rub, no. The set up is similar to the 359 wheels with 255/275 (aspect ratio adjusted for 19" wheels). It won't rub.
BMWCCA:518970 |
