11-01-2017, 04:31 PM | #1 |
Rep 531
265 or 275 on a front 9.5 inch wheel?
With a 295 in back what are the pros and cons of a 265 and a 275 in the front on a 9.5 inch wheel?
E92 M3 - Alpine White - Carbon Roof - 6 SPD - Speed Cloth - No NAV/EDC - Meisterschaft - Signature Forged |
11-01-2017, 05:42 PM | #3 |
Rep 1,216
I run 275/30 on the front 9.5" VFF103s and the turn in is great. Can't really think of negative effects from them to be honest although I don't track so wouldn't be able to tell you how they perform there.
2011.5 E90 M3
LeMans Blue |
11-01-2017, 07:25 PM | #4 |
Rep 531
How does the 275 look on the 9.5? Does it fit well, ie not too fat looking?
11-01-2017, 08:24 PM | #5 | |
Rep 1,216
2011.5 E90 M3
LeMans Blue |
11-02-2017, 09:12 AM | #6 |
Rep 1,673
I run 275 PSS on the 9.5 and it is not chunky at all, the 295 on 10.5 is more square than the 275 on 9.5.
Yes the car is filthy but here ya go, 275 PSS on 9.5
Electronics Junkie, Engine Builder.
11-02-2017, 10:46 AM | #7 |
Rep 531
Awesome! Exactly the info I was looking for. You da man
11-06-2017, 06:46 AM | #9 |
Rep 3,337
What offset is the 10.5 rear wheel you're using?
Current Stable:
11-06-2017, 07:08 AM | #10 |
Rep 5,550
I'm also running 275 on a 9.5"-wide wheel. The tire fits great on the wheel. The only downside is clearance between the tire sidewall and spring collars on some aftermarket struts. I'm currently running JRZs with 2.25"-Dia springs and have no clearance issues with a 275 tire on a 9.5et22 wheel.
11-07-2017, 03:25 PM | #12 | |
Rep 531
11-07-2017, 05:35 PM | #13 |
Rep 5,550
I believe the KW CS use a 60 mm-dia main spring + tender spring which puts the collar right at the tire sidewall. I think a 5 mm spacers is required on a 9.5et22 wheel or the use of a different length main spring without a tender spring.
Not sure about the Ohlins R&T. They use 60 mm-dia springs but no tender spring so I'm not sure where the collar sits relative to the tire. However, a 60 mm (2.36") spring and collar will have less clearance than a 2.25" spring and collar |
11-08-2017, 07:03 AM | #14 |
Rep 10,616
I run 265/35/18 and 295/30/18 on 18 x 9.5/10.5. Used to run 285/35/18 rears and think that size fits a little better and may return to it. Have rubbed the 295 a few times. 275 fronts seem like they may not fit as well. This car is a driver for me -- I don't want rubbing or high wear alignment to tilt the wheels in so they dont rub.
11-08-2017, 05:12 PM | #15 |
Rep 1,089
19's or 20s? what rears width, tires and offset? I'm assuming 19's if you're running a 25et. I'm going 20's with 34 and 305s! Same rims btw. I'm excited.
F80 M3 HRE FF04 275/305.
01-03-2018, 07:09 PM | #17 |
F15 daddymobile
2350
Rep 3,510
01-03-2018, 09:05 PM | #18 |
Rep 3,965
275s all the way. I am on a 10" front but the more tire you can fit under the front the better it is.
Dave
01-10-2018, 09:53 PM | #20 |
Rep 6,659
