08-20-2014, 10:36 AM | #1 |
Rep 3,675
Anyone Drive The Early Gen Porsche Cayman
anyone drive the earlier gen porsche cayman.. i have been reading reviews on them mostly 2008's and they appear to be pretty good performers. more or less thinking of a track machine but wanted to know if anyone had some hands on experience..wonder how they compare to the e92. i obviously know they are less power but are light weight..
08-20-2014, 11:05 AM | #2 |
Rep 53
Ive known a couple people that have owned them and, at the time, said that they were a truer track car than a 911 (excluding GT3 of course). Ive never driven one myself so this is just hearsay. I have read some articles that back this up though as the person writing it said that the Cayman is a very balanced car due to the more MR design over the 911 and quite agile.
08-20-2014, 11:10 AM | #3 | |
Rep 3,675
08-20-2014, 11:28 AM | #4 |
Rep 1,381
I've driven a 2008 base Cayman with Tiptronic. It was rather underwhelming and didn't feel anything special. Good car, but lacked power (maybe Cayman S is better), and the handling was good, but didn't feel much better than a S2000 or 370z I had driven earlier. You pay quite a premium for no other reason than it has a Porsche badge on it. Very overpriced car IMO. I'd get a Corvette at that price tag.
If you want a cayman for the track, get a 2009 or newer. They are far more durable and reliable. The older models were unreliable. They tend to overheat and burn up the powersteering system on the track. Not to mention the engine burns a lot of oil and also tends to experience oil starvation and possible engine failure during prolonged high g corners. Maintenance in general on all Porsches is a serious PITA. Everything is buried deep within the centre of the car and covered by a gazillion body panels. So even the basic maintenance and repair jobs take quite a bit more work because of how inaccessible everything is. |
08-20-2014, 11:36 AM | #5 |
Rep 5,506
I drove the older Cayman and Cayman S. Great handling cars. It feels so light on its feet and feels much more connected than the M3. Cornering is sublime, much more neutral than the 911 which tends to understeer under throttle. All it really needs is a LSD, and then it would be a exceptional car. The new Caymans have optional LSD and the previous generation had a LSD in the Cayman R. If I could get a Cayman R for a decent price, I'd go for it. You can tell Porsche purposely made the Cayman slower so it wouldn't compete with the 911.
When I was looking for a car, it was between the Cayman S and the M3. I ended up with the M3 because it was easier to find pre-owned and it was more practical. But if I didn't need every day practicality, I'd pick the Cayman hands down. It feels much more sporty and fun than the M3 despite having less power.
Auto Detailing Enthusiast!
08-20-2014, 11:40 AM | #6 |
Rep 1,312
I owned a 2006 Cayman S. Loved it! Handling, feel, and just the poise was on another level. Nothing at the price point comes close and the newer 09s were even better, and the current gen even better than that.
For a sports car, you dont get much better than the way it feels and sounds and of course you have the Porsch quality/F&F. If you can get a Cayman R, thats the best way to go unless you buy a brand new one. Dynamically, it is far superior to our M3s, or anything BMW for that matter. Last edited by Wolfinwolfsclothing; 08-20-2014 at 11:46 AM.. |
08-20-2014, 11:41 AM | #7 |
Rep 6,734
I have a 987.2 cayman which has the DFI motor (motor change made in '09). The early cars have a less reliable motor that has oiling issues and IMS bearing problems. I personally wouldn't consider a 987.1 for those reasons. I lost a 996 motor due to oil starvation so I have experienced the downside of that motor personally. If you do get a 987.1 you should plan on adding a dry sump system IMO.
I have considered turning our 987.2 into a track car as they seem to do well for that purpose. The interseries cayman race series is based on the 987.2 cars.... And the DFI engine and PDK trans seems to perform very well. I have not had our Cayman on the track but when driven hard on the street it understeers badly. Despite all of the "neutral handling" hype it receives. I know that it could be set up to handle gloriously with some suspension mods. But in order to get some camber, and adjust for the impacts of suspension geometry changes when lowering, you need Gt3 lower control arms, rear toe links, and coilovers at a minimum... Then I know I would want drop links, possibly sway bars, rear lca's... $5k+ later it would be where I want it. Then I would want to add a LSD... I haven't ruled out going this route but once you start doing the math a 996 or 997.1 gt3 starts looking less expensive because it has the goodies from the factory... suspension work done out of the box, ideally factory race seats, etc. I would still have less into our 987.2 than I do in my M3 so it's not all bad. I do however enjoy driving my M3 more but I also have a lot of work done to it. The question is would I like the 987.2 more if I spent the same money on it?
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 08-21-2014 at 11:07 AM.. |
08-20-2014, 11:44 AM | #8 | |
Rep 3,675
08-20-2014, 11:49 AM | #9 | |
Rep 3,675
by the way i got your pm about the wheels... tossing around the thought and will get back to you...
08-20-2014, 11:58 AM | #10 | |
Rep 6,734
Let me know about the wheels... They are in perfect condition, not a scratch on them, and never used on the track.
'23 X7
08-20-2014, 02:08 PM | #11 | |
Rep 6,734
I currently own a Cayman S, have owned a 996 911 (POS), my dad has a 993 tt (after replacing the trans and diff at 30k miles it's running great - $20k+ repair), I have driven my friend's 996 gt3, 997 tt, 996 tt, etc. They are great cars but each of them has it's weak points. I like them but honestly I have had much better luck with BMW's from a reliability standpoint. Our current Cayman has been very reliable but the handling is definitely not boner-worthy with the OEM suspension....
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 08-20-2014 at 02:14 PM.. |
08-20-2014, 02:19 PM | #12 | |
Rep 3,675
08-21-2014, 08:33 AM | #13 | |
Rep 1,312
I have owned 2 Porsches, a 911 and Cayman S, and between my father and cousins probably another 10-12 Porsches all of which have been much better than the BMWs we've owned. Look at dependability and reliability reports, and initial quality, where Porsche since the 997 has been ranking either the top or close to it, and BMW unfortunately has been mediocre at best and generally below industry average. BWM just has to recall 160,000 6 cylinder turbo engines. Their cars have been terribly unreliable and got worse since they went to turbos. |
08-21-2014, 09:02 AM | #14 | |
Rep 12,309
I'm not saying the new BMW's are perfect (I take reliability very seriously). To say that "Their cars have been terribly unreliable" is just false IMHO. Those I6's are some of the most bulletproof engines out there, and they are a breeze to work on compared to doing DIY's on a 911 for example. If you want to bring up recalls, how did that GT3 recall feel? This is where I think you don't understand the rest of us. Like Slicer said, I've never met anyone that drinks so much Koolaid from 1 brand. But where you are wrong is that you assume the rest of us for some reason don't like Porsches. On the contrary, they are one of my favorite car mfg's and strive to own a 997 GT3 one day. I really don't understand why you are here on a BMW forum either, yet alone why you drive one.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
08-21-2014, 09:47 AM | #15 | |
Rep 1,312
2012, 2013 2014, Porsche ranked in the top (#2 for '12, '13, and top 10 for '14), whereas BMW was below industry average in all of those years. So bascially with the GT3, 5 out of ~800 had issues. That is .00625% I would almost guarantee more M3 percentage wise had rod bearing problems which BMW refuses to acknowledge. Lets not forget the 458 italia...12 out of about 800 went up in flames. And to the contrary, I know most here love Porsches, and aspire to own them. 2004-2013, vehicles to avoid, of them X5 and Mini Cooper are ranked worst of the worst. http://consumerreports.org/cro/2013/...cars/index.htm Last edited by Wolfinwolfsclothing; 08-21-2014 at 09:55 AM.. |
08-21-2014, 10:16 AM | #16 | ||
Rep 3,675
e30 sold 19,576 e36 sold 71,279 e46 sold 85,000 the above are mass production figures and include special editions e30 sport evo ...sold 600 e36 gt sold 406 e46 csl sold 1389 and the e9X has sold 31,700 since 2007 most being coupes! im not sure where porsche stands for annual figures but i know if we were to bring up gt3 or their top end model sales they will be much lower. my point is the 2 really cant be compared ...JUST MY 2 CENTS
08-21-2014, 10:37 AM | #17 | |
Rep 6,734
To be clear, I like Porsche, I chose to buy another one to replace the 996 that had engine failure... I almost left the brand but gave them another chance. Their 2009 and newer DFI motors are a huge step up in reliability over their old engine architecture. Their Metzger motors have always been great but they aren't without fault. Heard of failing coolant line fittings? Every brand has issues, some worse than others... Porsche has great initial quality survey results as of late... That's great but take your blinders off and recognize that they are not perfect. Lastly I might not have said anything if I thought you made an effort to contributing to helping others on this forum. Unfortunately all I see you post is your delusional perspective on all of porsche's perfection and BMW's shortcomings. The OP asked about the gen 1 cayman and all you have to say is that porsche makes the greatest car in the world and he should get one because it blows away all BMW's in every measure... How about adding some actual advice about what modifications the car needs to be the track performer he is looking for? Even if I bought a GT3 I would expect to need to address the coolant fittings and the LSD (OEM LSD doesn't hold up well to track use). If you don't think a 987.1 Cayman needs any modifications to be safely run hard on the track then you have no clue. I think you should spend a little less time reading consumer reports and magazine road tests and more time researching real world track testing. Head over to Rennlist, there is a lot of great information on that forum. Sorry.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 08-21-2014 at 11:10 AM.. |
08-21-2014, 11:43 AM | #18 | |
Rep 3,675
WOLF YOU MAKE ME WONDER IF YOU HAVE ANY TRACK EXPERIENCE OR EVEN MORE SO HOW MUCH EXPERIENCE YOU HAVE WITH M3'S ...
08-21-2014, 11:46 AM | #19 |
Rep 3,675
by the way consumer reports states porsche in fact has had numerous issues with their blinker fluid and muffler bearings....i belive it 100% AS I READ IT IN http://www.consumerreports.org/cro/index.htm
08-21-2014, 11:54 AM | #20 |
Rep 5,506
Lol .. porsche reliability. All car manufacturers have issues, some more than others. I'd say most German cars are not very reliable. Lots of electrical issues and some mechanical ones.
If we wanted reliability, we'd all be driving Hondas and Toyotas. My Camry with 200k miles still runs like new with no issues.
08-21-2014, 12:01 PM | #21 | |
Rep 248
To the OP - I had the pleasure of driving a 2006 Cayman S (6 speed manual with min. options) for about 6 weeks and several thousand miles a few years ago. Absolutely wonderful car. Great balance, and all the road car most drivers could realistically ever really use. Personally, I'd focus on the later DFI equipped cars but the Cayman is a very well balanced car that still provides a great deal of every day usability. |
08-21-2014, 12:05 PM | #22 | |
Rep 1,312
The IMS issues is well know but it is relatively rare - which is why they never did a recall for it. Never warranted a recall such a rod bearing in the e46 m3s. I ran my Cayman S hard at the track during the period I had it and never had any issues besides worn tires. I am well aware of certain issues it had during that generation. The M3 needs work to be run hard at the track too. Just as an aside, there was also a study done of the most cars from any brand still operating and on the road today, can you take a guess as to which that would be? |
