10-06-2009, 11:35 AM | #1 |
Rep 10
Hoisting hardtop using roof rack mounts?
Hello folks. This is my first post. I just bought my first Bimmer-a 2002 M3 convertible.
The wife can't help me remove the hardtop so I am rigging a hoist in the garage. There are the four mounting points for attaching a roof rack. I want to use brackets bolted to these points to lift the top. I've actually made the metal brackets and they have holes for rope to go through. I will pull straight up by using bars that span the width of the mounting points. Has anyone hoisted their removable hardtop this way? Has anyone mounted a roof rack instead and used to it for hoisting the top? I guess I have a minor concern about tweaking these threaded mounting pads since the roof is aluminum. However, the roof is not that heavy and the mounts are designed to hold roof racks which could have loads/objects mounted on them that would be stressed from wind force, if nothing else. Thanks PS: bought the wife a 2010 525xi, with M sports package, too. |
10-06-2009, 12:19 PM | #3 |
Rep 10
Where is e46 convertible section?
I don't see an appropriate forum for e46 convertibles. Certainly coupe owners are not going to be lifting their cars by the roof mounts!
How do you get a moderator to move something, anyway? |
10-06-2009, 12:29 PM | #4 |
Rep 1,314
What he is saying is that there is no need for detachable hardtop for the latest generation 3-series, and you are in the latest-gen M3 section. The current convertible (E93) has a hinged hardtop which folds into the trunk. Your odds of finding someone here who had a hardtop for the E46 convertible are slim.
You might try here: http://www.m3post.com/forums/forumdisplay.php?f=75
10-06-2009, 12:33 PM | #5 | |
Moderator / European Editor
1494
Rep 6,755
Best regards, south
10-06-2009, 01:40 PM | #7 | |
1494
Rep 6,755
Best regards, south
10-09-2009, 07:15 AM | #8 |
Rep 10
Update: ordered Thule brackets
I still want to know if anyone hoists their removable hardtops this way.
I just ordered the Thule rack brackets. I want to use it to lift the hardtop off my convertible. Using them. I will connect them with hard maple. The top is 80 pounds. That's only 20 pounds per bolt or mounting point. Doesn't seem unreasonable to me.
Look at that S car go! Before the M3... |
05-22-2011, 11:11 AM | #9 | |
Rep 5
Hey Scargo, did you get anywhere with this? I was thinking of doing the same, just wondering if the threads will hold safely.
06-03-2011, 04:18 PM | #10 | |
Rep 9
Hi Scargo, You can buy the official hoist and frame from BMW for quite a lot of money. I have one and it is great except when you bang you head on the bottom of the suspended hardtop! There are 4 eyelet bolts which you screw into the threaded nuts concealed on the hardtop roof then a frame clips on the eyelets and the frame is winched by hand with the hoist using nylon rope. |
