01-23-2014, 05:18 AM | #1 |
Rep 300
Volume needed to bleed to each wheel
I've searched but have not come up with the answer.
When bleeding a e90M3 with a pressure bleeder, how much volume do you need to push through each wheel to ensure a complete flush? I'm sure it's the highest to the passenger rear wheel and the lowest to the driver's side front wheel....but what are the volumes? Anyone know for sure from experience using ATE Blue? |
01-23-2014, 07:47 PM | #2 |
Rep 8,075
Drives: 11 E90 M3 Individual
I run about 1pt through the R/R to get suck out all of the fluid in the line and the bottom of the master cylinder. But that might be too much.
2018 F30 320iX Melbourne Red
01-23-2014, 08:33 PM | #3 |
Rep 2,792
I do about 150 mL per wheel. I also use a turkey baster to empty the reservoir.
And if I am swapping pads (usually the case), I open the bleeder and push the piston in first to ensure that I get as much of the old fluid out of the caliper (where it really matters) as possible. Then you really only need to run enough through to flush the line. Since the inlet (hose) and the outlet (bleeder) are so close to each other I am not confident that the bleeding process clears all of the old fluid out of the caliper.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
02-13-2014, 10:47 AM | #5 | |
11817
Rep 23,187
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
02-18-2014, 04:24 PM | #7 |
Rep 294
You cannot vacuum bleed, it's terrible. I've tried with my Mityvac and it's super frustrating and does not work.
2012 X5 35D - Platinum Gray / Cinnamon Options: Sport, Tech, Cold Weather, comfort seats, leather dash, high beam assist, lane-departure warning, soft-close doors, two-row, self-leveling suspension, hi-fi stereo
Tracks driven (in any car): Nürburgring Nordschleife (05/2011), LeMans (ok, just the public part), Eagles Canyon Raceway, MotorSport Ranch Cresson, COTA Austin |
02-25-2014, 10:45 AM | #9 | |
Rep 4,001
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
