03-05-2017, 01:42 PM | #1 |
Rep 336
Rubbing on stock suspension and stock wheels
Hello everyone.
I've been getting a rubbing sound on the driver side front during moderate to great compression. I wasn't sure what the sound was at first and took it to the dealer many times to get the tech to look at the struts. However everytime, they told me they found nothing wrong. Today however, I found a hole directly on top of the front driver side wheel in the liners. I subsequently checked the passenger side and there were some signs of rubbing as well but not nearly as severe and definitely no hole. I'm running OEM 220M wheels with 245/35/19 & 255/35/19. Pretty much oem spec tire size except rear is slightly smaller. My hypothesis right now is that there is too much suspension travel due to bad struts perhaps? Has anyone else experienced a similar problem? Updated with an inked pic to show the damage. Update Mar. 9th 2017: Took it to the dealer and their conclusion was that there is no mechanical defect. When I asked for their reasoning, I was just told this was what the technician said. When I asked to speak to the technician over the phone, I was simply told "no, we don't normally let the customer speak to the technician." I'm going to try and escalate this issue BMW Canada... Clearly something isn't right here Last edited by Absurdium; 03-09-2017 at 05:15 PM.. |
03-05-2017, 08:11 PM | #2 |
Rep 12,724
i can't see a whole lot in the pic, but you shouldn't be rubbing with those specs. does your car feel bouncy when you go over a dip? edc?
03-05-2017, 08:47 PM | #3 |
Rep 336
Yeah my car is on EDC and ZCP suspension. It doesn't feel particularly bouncy but I've noticed the car tends have a very pronounced "lean" into the front left and right side during cornering.
03-05-2017, 09:13 PM | #4 |
Rep 12,724
i'm not 100% sure what triggers an EDC light, but i would imagine there could be a scenario where it wouldn't trip the light. try pushing down on the front corners of the car above the strut. see if one side behaves or bounces different than the other. maybe do the same thing while running through the different EDC settings.
03-06-2017, 12:11 AM | #5 | |
Rep 336
03-06-2017, 04:24 AM | #6 |
Rep 12,724
thats my initial thought, but i could be wrong. maybe you have a cracked spring... that would certainly cause issues, but not necessarily an edc fault. the car is balanced enough that it may mask the cracked spring until the car really leans on it.
03-06-2017, 09:20 AM | #7 | |
Rep 336
Will update once I get some results, in case anyone else has the same problem. |
03-06-2017, 02:08 PM | #9 |
Rep 5,484
Please point to where the bad man touched your fender liner, that potatocam looks like a bunch of normal holes to me You could have perished bumpstops allowing the wheels to travel too far. Broken swaybar endlink would allow too much roll, that coupled with the bumpstops being worn out could do it
roastbeef11584.50 |
03-06-2017, 02:32 PM | #10 |
Rep 988
Could be something else rubbing like the front felt covers behind the bumper air ducts. These frequently get torn and maybe air at speed is pushing it down far enough to rub on bumps and turns but moves back out of the way when stopped.
03-06-2017, 02:42 PM | #11 |
Rep 5,484
There are enough fasteners elsewhere on the liner to the body that even if the undertray is gone it shouldn't move that much way up there by the strut something else is rotten in denmark
03-06-2017, 03:07 PM | #12 | |
Rep 336
03-06-2017, 03:09 PM | #13 |
Rep 336
I'm not sure this is the case as there is some slight signs of rubbing on the other side too. I don't think the liners on both side would fail like that at the same time.
03-09-2017, 05:14 PM | #14 |
Rep 336
Update: Took it to the dealer and their conclusion was that there is no mechanical defect. When I asked for their reasoning, I was just told this was what the technician said. When I asked to speak to the technician over the phone, I was simply told "no, we don't normally let the customer speak to the technician." I'm going to try and escalate this issue BMW Canada... Clearly something isn't right here
03-20-2017, 02:21 PM | #15 |
Rep 336
So after doing diagnosis from two dealerships, it turns out the issue was a sagging fender liner that wasn't installed correctly. Unfortunately I had to pay out of pocket for the repair as the liner is considered a trim piece. However the good news is, the rubbing has since gone away and I no longer get anxiety over every little dip
Hope this helps anyone who encounter the same issue. |
