12-06-2014, 01:34 PM | #1 |
Rep 137
AD08 R tyres choice
With not that many tyres size to choose on AD08R, what would be the best choice for 18 inches?
Suspension: KW V3 wheels size: 18x9.5 et22 / 18x10.5 et22 245/40-18 255/35-18 255/40-18 265/35-18 265/40-18 285/30-18 295/30-18 Beside 245/40 & 265/40 .... what is the next best size if I want to go wider tires since I have 9.5/ 10.5 width wheels? Thank you for your common/ advise. |
12-06-2014, 02:08 PM | #2 |
Rep 1,286
I can't give you any specific advice as to those specific sizes but I can tell you based on the 19" sizes I purchased is that the AD-08R tends to run significantly wider than Michelin or Bridgestone so be careful with fitment, i.e. possibility of rubbing.
12-06-2014, 10:48 PM | #3 |
Rep 137
I'm consider 255/35-18 & 285/30-18......but
255 is 0.7 inch less than stock & 285 is 1.6 inch less .... more importantly is the rear has shorter diameter than the front, which is the opposite from stock. If Yoko is wider than other brand like Michelin, will 285/30 or 295/30-18 hit my rear fender as I will lower the car with KW-V3? Really want to know what size & the results of those who is using AD08R... Last edited by testdriver; 12-07-2014 at 12:38 PM.. |
12-07-2014, 06:38 AM | #4 |
Rep 1,286
The rear is where I had my problem. Went from Bridgestone RE-11 in 275/35/19 to Yokohama AD-08R in same size and it's much wider and rubbed on my driver's side rear after the change. Had to raise the car 1/4" on that side (not optimal but had no choice) which helped but it's still going to be a problem on the track.
12-07-2014, 08:49 AM | #5 |
Rep 6,734
Ad08's aren't available in good 18" M3 sizing. Most run 265/35/18 front and 295/30/19 rear. The problem is that 295/30/18 is a full 1" smaller diameter than OEM. I would choose a different tire brand that is available in 285/35/18. My favorite 18" tire sizes are 275/35/18 and 295/35/18. Unfortunately you're Volk wheels are too aggressive for 295/35/18's. I chose 275/35/18 and 285/35/18 Hankook RS3's when I had Volks.
'23 X7
12-07-2014, 09:34 AM | #7 | |
Rep 6,734
Michelin PSS would be a good street option and it's available in 265/275/285-35-18 sizing
'23 X7
12-07-2014, 12:38 PM | #8 |
Rep 137
Mostly for street but I will goto track day..... here in Asia, track temp in spring time can easy reach 30C above (summer time is even worst). Therefore, PSS may not be the best choice in that case. RS3 may be good, but the tyre shop here actually dont carry it....
I'm wonder how bad will that be if using 295/30/18 which is a full 1" smaller diameter than OEM.... and being shorter than the front tyre in diameter |
12-07-2014, 07:26 PM | #9 |
Rep 6,734
I personally don't see the point of buying 18" wheels and then buying tire sizes appropriate for 19" wheels (sidewall height). You might as well get 19's...
'23 X7
12-08-2014, 07:39 AM | #10 |
Rep 5,483
Nothing wrong with the 295/30-18 on the rear of an m3, especially paired with the 265/35 up front. I've used that size before in competition and was not killed. A little better gearing and a little worse forward bite than the taller tire I normally ran in the rear, but the ad08 is so much better than most street tires it would still be a big improvement over PSS for track use. It will not ruin the car. Tire size is not near as critical as it is sometimes made out to be, if it could ruin a car's handling all by itself we'd all be greasy smears on the side of a tree as soon as we took the first turn with a square setup...
Is the BFG Rival available there?
12-09-2014, 08:36 AM | #11 |
Rep 137
You have a good point..... you just remind me by using Sq set up as an example of we don't always have to keep or closely follow the "factory set up".
Thank you |
12-09-2014, 02:07 PM | #12 | |
Rep 6,734
'23 X7
12-09-2014, 02:33 PM | #13 | |
Apex Everything!
976
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
