11-29-2022, 10:30 PM | #1 |
Rep 6,771
Drives: 2016 BMW i8
I'll start.
Stock comp package suspension and wheels with upsized 255 35 19 F and 275 35 19 R Michelin Pilot Sport 4S tires. GC camber plates with -2.3 front camber and -1.8 rear camber. No spacers.
11-30-2022, 03:49 PM | #2 |
The WEEBM3
469
Rep 780
Tire Size: F: 275/35/18, R: 295/35/18
Tire Brand: Michelin Super Sports Spacers: No Suspension: BILSTEIN B6 With Stock Springs Alignment: F: -0.8, R: -0.8, Toe: 0.0
BMW E90 Alpine White Slicktop Stripped 6M 03/2008
IG: @Richneerd |
11-30-2022, 05:05 PM | #3 |
Rep 1,002
Drives: 2007 Z4 M Coupe 2012 e93 M3
Wheels Klassen M52
F-19x9xET16 R- 19x11xET28 Tires MICHELIN PILOT SPORT 4S STAR BMW F- 255/35/19 R- 275/35ZR-19 I think it will look better if I lower it a bit more! |
Longboarder3436.00 DrFerry6731.50 |
11-30-2022, 10:39 PM | #4 | |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
Pheonix380.50 |
12-01-2022, 11:04 AM | #5 | |
Rep 1,002
I am a bit stretched on the rears with 275/35/19 on 11" wide wheels so thinking it might look even better if I tuck them in a little more. However, functions over looks so I probably just leave it as is. |
12-01-2022, 04:12 PM | #6 |
Rep 1,097
Drives: Melbourne Red e90 M3
Wheels: Apex ARC-8
Front: 19x9.5 +22 Rear: 19x10.5 +22 Tires: PSS 265/30/19 285/30/19 Front -2 Rear -1.8 5mm spacer in front
6MT | 11:1 Forged 4.1L | ESS-G1 | KW ClubSport | Sparta 380/355 BBK
Longboarder3436.00 GcD128.50 |
12-01-2022, 08:25 PM | #7 |
IG: krapm3
58
Rep 933
BBS LM
19x9.5 +26 19x11 +21 PS4S 265/30 295/30 Bilstein B16 No spacers Slight rubbing in the back with dips
2007 E90 AW 335i -ZSP/6MT- Delivered: 4/2007 SOLD: 3/2012 ETS IC - Stett CAI - AE Exhaust - UUC SS - Morr VS8 - Mtech kit IG: krapm3 2010 E90 SSII M3 -ZPP/ZTT/6MT-Found: 5/2012 Turner Testpipes/Stage 2 - Corsa Exhaust - Bilstein B16 - BBS LM - BBK - AutoSolutions SSK Last edited by krapnoj; 12-01-2022 at 08:34 PM.. |
12-01-2022, 11:04 PM | #8 | |
Rep 1,002
I was having the same issue with rubbing with 295/30/19. Next time you could go down to 285/35/19 and most likely no more rubbing. I was gonna do 285 but have some concerns since my offset is more aggressive. |
krapnoj57.50 |
12-03-2022, 04:35 PM | #9 |
Rep 36
ZCP 359 wheels with stock sizing 245/35/19 and 265/35/19 on PS4s, 18mm front spacer an 12.5mm rear spacer
Lowered on Bilstein B16 Damptronics. No rub, no scrape, no bottoming out anywhere in the great state of NJ too. Fastest I've hit a dip on the highway was 140 mph and no rub or scrape either. Nothing on the track either! Some of you guys should go lower!! |
12-04-2022, 10:20 AM | #10 |
Rep 38
Wheels: Enkei NT03
Front: 18x10 +25 Rear: 18x10 +25 Spacers: 5mm Front 15mm Rear Tires: Evo Front: 275/35 Rear: 285/35 ST XTA Last edited by Zero Signal; 12-12-2022 at 02:35 PM.. |
12-07-2022, 06:50 PM | #11 |
Rep 10,601
Stock ZCP
Stock 359M 15mm front and 12mm rear spacers Always thought I would get TE37, FI, or LM’s but as time goes on the more I think I’m sticking with these. Might consider doing a square 359M setup one day. |
