      12-31-2009, 11:51 PM   #1
Scott@Radar-Mirror.com
Scott@Radar-Mirror.com's Avatar
75
Drives: 2016 BMW 550i
V1 Rear View Mirror System - DIY install for E92 M3
I recently helped Niels install his V1 Rear View Mirror System in his E92 M3 - here's a write-up of the install.
Preparing for install -
Main V1 unit has been hidden inside the rear headrest, V1 concealed display is integrated into the factory mirror and Valentine's remote audio adapter will be installed to allow full control of the system.
In order to hide the cord coming out of the headrest a 1/4 inch hole will need to be drilled and cord routed as illustrated
Run the cord from the back of the seat all the way to the front of the cabin as shown
Remove the AIRBAG plastic clip
Remove the Torx bolt and then remove the A-pillar cover by pulling gently toward the center of the car. There are two clips securing the A-pillar that will pop loose
Remove the sun visor and sun visor clip as shown
Pull down on the center of the headliner and with both hands reach in to release the map light console. The console is held in place by two metal tabs
The V1 hardwire adapter included with your radar detector will need to be connected to a power source that cycles on/off with the ignition. The green/white wire shown works fine. **Note the metal tab inside V1's blue power tap is a little big for the wire we're using and will not make a solid connection. I removed a 1 mm section off the insulation of the wire and soldered the wire to the power tap.
Ground the hardwire adapter as shown and plug the red wire into the power tap
We will now run a phone cord from the "Main" port of the hardwire adapter across the headliner, down the A-pillar and through the dashboard to meet the cable that was previously installed under the dash
Open the cover on the side of the dashboard
Beginning from the bottom of the dash run a piece of safety wire through the dash as shown
attach the safety wire to the end of the cable and pull it through the dash. **Note it will be easier to run the wire if the connector is cut off the end of the phone cord. You will need to crimp a new connector on - make sure the orientation of the new connector matches the one that was cut off or the unit will not function. You can see four wires yellow - green - red - black.
The cord that is connected to the "main" side of the hardwire adapter is plugged into the "Power In" port of the audio adapter. The cord connected to the main V1 unit inside the headrest will be plugged into the "Power Out" port
Re-install the rear view mirror and route the cord through the front of the headliner. The cord from the mirror will be plugged into the "Accessory" port on the hardwire adapter.
Reconnect all of the factory wiring to the map light console. All of the required wiring connections are now complete. BEFORE buttoning up the car turn the ignition on, power the radar detector on with the remote audio adapter and make sure the display illuminates inside the mirror and the external speaker on the remote audio adapter is functioning. If you do not see the display or cannot hear the unit power on something is wired incorrectly or the hardwire adapter is not installed properly.
Re-install the cover onto the rain sensor and replace the other items that were removed and this will conclude the install, enjoy. :thumbsup2:
      01-01-2010, 12:15 AM   #2
10M3MAN
10M3MAN's Avatar
Drives: 2006 Nissan Altima SER
      01-01-2010, 12:35 AM   #3
///V\3Dude
I Drive Slow To Save Gas :D
///V\3Dude's Avatar
Drives: 08 M3, MY11 STi
seems tough to install! but looks very good!
      01-01-2010, 05:32 PM   #4
carri0n m3
Drives: 2016 x5M
this is fantastic, looks really awesome
      01-01-2010, 06:00 PM   #5
gr8000
gr8000's Avatar
Greece
72
Drives: E92 M3 - DCT
Very clean work - excellent!!
I would appreciate it if you could take some time to respond to the following questions please as I am very interested in concealing properly my V1:
1. Why does the V1 need to be hidden all the way back in the headrest? Can it not be hidden, say, in the space above the driver's feet or in the glove compartment, or are these not ideal locations for good reception?
2. Do you have any detailed DIY instructions for placing the unit into the rear headrest?
3. Do I assume correctly that the V1 is in this case not used as a laser warning devise (only radar)? I say this because the unti is hidden in the headrest with no way for the laser sensors to have direct line of sight out of the front and rear windshields.
4. How did you do the display installation in the rear view mirror? Any detailed DIY instructions? Any hardware needed for this and if so where can I get these from?
Many thanks!!
      01-01-2010, 06:46 PM   #6
AceHollywood
Drives: 07 328i/08 X5/09 E92 M3
Looks great! Have you ever tried to install the V1 in the center ceiling "console" where the rear most dome light is located?
I recently chaged to LED lights and when changing the bulb, it looked like there might be space for a stripped out V1. I have a CF roof, so no moonroof to worry about.
Anyone ever tried this?
-Joe
2009 E92 M3
www.suhrelaw.com
      01-01-2010, 07:32 PM   #7
leeor
Drives: 2010 Blue Prius III
So, what exactly goes under the headrest?
Is this a prebuilt mirror?
Where to the actual sensors go?
Nice install tho!
      01-01-2010, 07:49 PM   #8
Big Windy
Big Windy's Avatar
Drives: None
install looks good! one question: why not place the V1 in the driver's side head rest instead of the passenger side headrest? placing it on the left would prevent you from having to run the cord between the two seat partitions. i imagine with your setup that you are going to have an issue when folding the seats.
      01-03-2010, 01:42 AM   #9
Robwe46m3
Drives: 2010 E92 Ruby Blk M3 Individua
So how do we get (or make) the actual mirror with the integrated display?
      01-03-2010, 12:57 PM   #10
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
Good Job ! This is how I did it ...
      01-03-2010, 01:47 PM   #11
75
Many thanks!!
Sure..
1. The radar detector will work fine as long as there is no metal obstructing the sensors. Placing it in the glove box or inside the dash would significantly affect radar reception.
2. Don't have detailed instructions but here's a few pics
3. Correct. Most people get a laser jammer.
4. Integrating the V1 display inside the mirror is a PITA. Please shoot me a PM and I will let you know where you can have it done if you're interested.
-Joe
I haven't tried this yet but would be worth looking into.
Nice install tho!
See pics above regarding the headrest. The mirrors are professionally built and unfortunately not a simple diy.
It could just as easily be placed in the driver side headrest. I use the passenger side b/c there's less interference.. the steering wheel, instrument cluster, etc.. is less in the way. The seats fold down fine without restriction.
Shoot me a PM and I'll let you know where you can have the mirror done.
