      08-16-2009, 02:19 PM   #1
hdpt00
hdpt00's Avatar
12
Drives: Mo-Ped
e92 Side Gill Removal Part 2...
They're still fvcking stuck... anyone in the Phoenix area that can do this for me?
Thanks.
      08-16-2009, 02:26 PM   #2
JCtx
Drives: No BMW yet
Can't somebody who has done it shoot a freaking video of this?
Words just don't help on this, as you found out; you need to see how it's done. Good luck. And if somebody helps you, hopefully you can shoot the video yourself and post it on the DIY section. Take care.
      08-16-2009, 04:24 PM   #3
CantDrv55
NJ = guido white trash losers
CantDrv55's Avatar
India
12
Drives: '09 Jerez Black M3
There is a video already, it's not all that helpful. I can't get mine out either. I ended up with a small 1mm spot where the paint didn't take too well to all the attempts.
http://www.m3post.com/forums/showthread.php?t=170882
I gave up for now before I damage something. Quite annoying to say the least.
      08-21-2009, 11:26 PM   #4
hdpt00
hdpt00's Avatar
12
Drives: Mo-Ped
bump for help
      08-21-2009, 11:29 PM   #5
frankzlin79
frankzlin79's Avatar
Drives: 2018 M3
Mine came out fairly easy. Just use more force! Don't be afraid to break the tabs off the stock unit...you're replacing them anyway, right? Just remember that the black, plastic portion comes off with the side marker.
      08-23-2009, 12:54 PM   #6
VelocityM3
Brian
Drives: Alpine White E92 ///M3
Squeeze as hard as you can. Then start wiggling harder and harder until you can eventually pull the bottom toward the sky and it will just "pop" right out. Maybe you gotta hit the weights!!.... Remember to not pull the unit too far away from the car before disconnecting the electric cord.
      08-23-2009, 05:23 PM   #7
montreal red
chris
montreal red's Avatar
Drives: White Boat
i just did this yesterday... the part i find really hard was seperating the side grills from the black plastic plug ( this is after you have removed the whole thing from the fenders)... i needed to use a lot of force there and i actually bent the plastic tabs while seperating the chrome side grill from the black plastic plug.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      08-27-2009, 02:43 PM   #8
STALKER
Drives: 997.2 GT3, Golf R
These were a pain in the ass to get out.
I taped the area up, and used the screw driver to pull out one end, and then kept pulling till it came out.
      08-27-2009, 03:36 PM   #9
artifice
artifice's Avatar
Drives: 2008 E92 M3
Just wrap up a small flat head and start at the corner closest to the door and work your way along the bottom in like 2-3 inch increaments lifting/squeezing with your non-screwdriver hand till the bottom pops out... Done.
      08-27-2009, 04:32 PM   #10
BHairsto
BHairsto's Avatar
Drives: 2016 BMW M2
2016 BMW X5 35d  [0.00]
I've had had no success with the "squeeze" method in the DIY, either -- and I'm no weakling. I temporarily gave up on this install for fear of breaking something or scratching the surrounding paint by using too much force, but will return to it once I get my courage up again.
      08-28-2009, 05:40 AM   #11
RI55
Drives: 09 E92 M3, 03 RS6
Just did mine. It did take some force. I used the squeeze and pull up method. It felt like I was gonna rip the fender off, but came right out without anything breaking.
As another poster said, the tough part is actually separating the gill from the black plastic thing.
      08-28-2009, 10:31 AM   #12
hdpt00
hdpt00's Avatar
12
Drives: Mo-Ped
BIG SHOUT OUT TO ADAM @ VIVID. His crew got my gills out yesterday using a tiny ass screwdriver to unclip these things. After a month or two of waiting I am finally de-chromed.
      08-28-2009, 11:20 AM   #13
vividracing
vividracing's Avatar
Drives: E90 M3, F30 335i, F80 M3
Glad we were able to take care of you Brandon!
Those things were definitely trickier then I expected. You have to get that car washed and get some pics up!
Travis Williams
Shop ALL BMW G80 | G82 Parts Here!
480.966.3040 ext 318 Travisw@vividracing.com
PM, Email, or Call Directly for aggressive BMW Member Pricing
