      06-21-2017, 03:35 PM   #1
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
Talking ..::psi::..E92 M3 + Harrop Kit!
407.617.0372 | Email Us | Visit PSI
IT SEEMS THAT MOST THING'S IN AUSTRALIA ARE DEADLY...
Luckily for us, the Harrop kit isn’t deadly, but it sure makes some killer power!
The Harrop TVS1740 kit was designed specifically for the S65 V8 powered E9X M3. Engineered & manufactured in Australia, this is the world’s first positive displacement supercharger for the S65 engine. Now, if you are the least bit familiar with the S65 platform, you know how brilliant it is. However, it tremendously lacks low end torque. Thanks to the guys over at Harrop, we now have a solution.
This kit was so well engineered, it compliments the S65 E9X M3 platform in every way. The FDFI (front drive/ front inlet) design helps keep this beauty looking as OEM as possible with minimal restrictions in the bay. While the torque and top-end power improvements complete the drive-ability of this already spectacular car.
We had the pleasure of installing this kit on a completely stock E92 M3. Simple install. Non-invasive design. A little fine tuning … and we had ourselves one particularly amazing driving machine, with a little extra kick!
Dyno Results: 525HP & 372TQ
DrFerry6728.50
      06-21-2017, 07:46 PM   #2
pooyab
pooyab's Avatar
330
Drives: 2011 BMW M3 2020 BMW M5C
2011 BMW M3  [0.00]
Originally Posted by Sean@PSI View Post
... Dyno Results: 525HP & 372TQ ...
whp and wtq correct?
Interlagos Blue/Speed Cloth | BayOptiks DTM Headlights | Alpine Stage 2 | KW Clubsport | Resonated X-Pipe | Eisenmann Race | StopTech BBK | TE37SL | YFCM CF Driveshaft | Hotchkis F/R Sways | F/R Endlinks | Turner Control Arms and Front Tension Bushings | Powerflex Diff Bushings | Turner Solid Subframe Bushings | MS Underdrive Pulley and Intake | Alpine DCT Tune | Karbonius Intake | Carbon Roof (TBD)
      06-21-2017, 08:09 PM   #3
h4nh
h4nh's Avatar
Drives: 09 SC E90 M3 / 13 F10 M5
2009 E90 M3 (superc ...  [10.00]
2013 M5  [0.00]
Very nice.
      06-22-2017, 09:20 AM   #4
Sean@PSI
Sean@PSI's Avatar
      07-04-2017, 06:13 PM   #5
MShift
OG
MShift's Avatar
217
Drives: MW '13 E92
most bizarre thread.
DrFerry6728.50
6ixSpd6014.50
      07-07-2017, 03:12 PM   #6
pooyab
pooyab's Avatar
330
2011 BMW M3  [0.00]
Good people of the board, looks like the S65 Dyno Database is still being kept up by the secret elves. Links are below. I was able to find two Harrop TVS Super Charger entries -> and one of them (1st row in screen shot below) appears to be on a stock E92 M3. See the screenshot and S65 dyno database below links. And now the silence will be deafening again.. Why do I even bother with this board? Maybe I am bored.
S65 E92 M3 Dyno Databse
http://www.bmwdynodatabase.com/DynoDB.php
or
http://www.s65dynos.com/DynoDB.php
Putting blower on stock car makes 493whp?
DrFerry6728.50
      07-30-2019, 02:38 AM   #7
Ashley_rj
Ashley_rj's Avatar
31
Drives: e90 M3 2009 harrop s/c
I had the harrop s/c fitted to my stock car with a k&n filter and new rod bearings. Peak kw 364 and torq 505 Nm. The throttle actuators died about 2000km after the s/c went in (after a track day). Since they have been refurbished by rebuild (uk) car has been a treat! Very happy with how it’s going. With the new hp I have warped my rotors at the track day (using pagid rs1 pads) so a break up grade will be the next step. I have also splashed out on some 18” Apex ec-7’s with 295 Michelin cup 2’s on the back. Can still get sideways on the motorway when changing up into 4th on a cold day though!
I ll try and up load the chart.
DrFerry6728.50
      08-08-2019, 10:20 PM   #8
Ashley_rj
Ashley_rj's Avatar
31
I ll bare that in mind! exhaust is on the cards... after my wedding and probably some new breaks!
2009 e90 M3 Harrop s/c
2006 golf GTI stage 1
2018 Triumph Street triple RS
1999 e36 M3 convertible-sold
      08-08-2019, 10:44 PM   #9
Ashley_rj
Ashley_rj's Avatar
31
how do I add my dyno chart to the dyno database? I cant see any way of adding it??
      05-16-2020, 09:18 PM   #10
Ashley_rj
Ashley_rj's Avatar
31
Originally Posted by M3Post View Post
Well at least according to this M3post below that was linked in the S65 database. The 525rwhp Sean@PSI (the O.P.) mentioned at the bottom of post #1 was replicated by a Markert Motorworks customer's car, but that was on a HARROP equipped E92 M3 with BPM Sport SC tune, Full Akra system and NO cats:
http://www.m3post.com/forums/showpos...67&postcount=1
and here
http://www.s65dynos.com/showDyno.php...ype=1&dynoID=2
and this chart
http://www.bigdynodatabase.com/DynoG...BILLCRUISE.jpg
I am curious M3 post, do you have a dyno chart for your harrop? Also I noticed on the above charts they are suggesting 6.5psi of unverified boost. I have a P3 Gaige which surprisingly does tell me boost numbers and the highest it gets to is 5.
      07-16-2020, 07:58 AM   #11
Tigamilla
Drives: BMW E92 M3
Thanks for the data in here - it is certainly useful for people like me weighing up whether to pull trigger on a Harrop kit that will see track time in the UK....
DrFerry6728.50
      10-05-2021, 09:59 AM   #12
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
You're welcome.
      10-05-2021, 04:27 PM   #13
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Perhaps there's a boost leak somewhere such as one of the throttle body rubber boots or perhaps the elevation above sea level affecting atmospheric pressure? Either could reduce the peak boost seen on the gauge.
https://www.garrettmotion.com/news/n...r-air-density/
Tags
e92 m3, harrop, precision sport, psi, winter park
