      05-05-2015, 06:33 AM   #1
yangin
Drives: M3
launch control rpm
Ok guys i understand that you can adjust lc rpm with cruise control lever but i cannot for the life of me get it to adjust.
I have the flag up and then start pushing pulling and moving the lever in every direction and nothing. I then try with flag up and floor the accelerator and play around with cruise control lever and again nothing.
Can someone give me an exact step by step guide to get it to launch at 3500rpm?
Cheers
      05-05-2015, 11:54 AM   #2
s14_kev
s14_kev's Avatar
367
Drives: E90 M3, E30 M3
You need a tune to get it down to 3500 RPM
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner
      05-05-2015, 06:12 PM   #3
yangin
Drives: M3
Can I get it down at all without a DCT tune? I have done a search and apparently I can but I have my doubts
      05-06-2015, 10:09 AM   #4
Patrón
PAZUZU
Patrón's Avatar
Drives: '15 M4
2015 BMW M4  [0.00]
2009 BMW M3  [10.00]
Cheers
I believe Kevin is correct. I too tried lowering the rpm for the launch control (with the cruise stalk) and could never get it to adjust.
i since then installed a dct tune and now have a 3,500 launch. I have not tried to lower it with the cruise stalk.
2009 M3 DCT ESS625+ SOLD
2015 M4 BSM/Silverstone F4LCON
@texasMclub IG @jagemoets
      05-07-2015, 01:08 AM   #5
yangin
Drives: M3
I believe you are right.
Anyone that has successfully adjusted with cruise stalk have comments? I see a few old posts on the forums where people have indicated they have done it
      05-12-2015, 11:06 AM   #6
M3lbournE92
I do it all the time idk why you guys are having such problems. With my gts dct software, the cars set to 3500 but with my friends stock software dct he can go from 5500 rpm to 4k I believe. Anyway to adjust the rpm pull the cruise control stalk towards you to lower the rpm and push forward to up the rpm. You have to keep doing it, every time you want to lower the rpm it goes down by 100. So to go from 5500 to 4500 you have to pull the cruise control stalk towards you 10 times.
      05-12-2015, 11:47 PM   #7
yangin
Drives: M3
I am assuming this is with the flag up? And do you have the accelerator pressed to the floor while doing this?
      05-13-2015, 12:47 AM   #8
M3lbournE92
Yes you have to have it pegged the whole time
      05-13-2015, 04:01 AM   #9
yangin
Drives: M3
Ok will try. Geez they made it difficult
      05-13-2015, 07:15 AM   #10
Properstyle
Drives: 2011 e90 ZCP m3
a tune is not need to adjust the speed or rpm of the launch, only if you want it to be super low like 3500 rpms
engage launch control
keep your foot on the brake so the car doesn't roll forward. push the pedal to the floor you should be at like 5500rpms then pull the cruise control toward you mulitple times or hold it and the rpm will start to drop. I've done it in my car with out tune.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD
1994 300zx 2jz Swapped slicktop- The toy/track car
      05-15-2015, 07:15 PM   #11
yangin
Drives: M3
Hmm doesnt work for me maybe because I have a 2008...
      06-28-2015, 08:13 AM   #12
STG 305
STG 305's Avatar
Australia
Drives: E90 M3
But if you touch the brake at anytime while LC is engaged the LC disengages...
      07-03-2015, 09:34 PM   #13
yangin
Drives: M3
Ok guys i recently got the gts dct tune which lowers lc rpm to 3500rpm.
Car still struggles for traction to the point it renders lc useless.
Could i have an issue with the bushings or something else?
      07-03-2015, 11:00 PM   #14
V1.47fan
Drives: TheArtist formerly known as M3
What do you have for tires?
      07-04-2015, 08:30 PM   #15
yangin
Drives: M3
Previously bridgestone re05a now nitto nt01. Soon getting hankook rs3 couple of weeks
Search this Thread:
Advanced Search
