05-09-2012, 12:37 PM | #1 |
Rep 100
Drives: VO 1M
AUTOcouture Motoring - P3 GAUGE GROUP BUY!
P3 Boost Gauge - for 335i | 335xi We are starting a group buy and as a introduction to becoming a P3 Dealer Pricing as follows 10 minimum qualifies at 15% off retail 15 minimum qualifies at 20% off retail The Retail on the P3 Gauges $ 409.00 Our GB Pricing is $ 369.00 Let the races begin Ideally filling our form out would be best. HERE - Precisely Color Matched Seamless integration with the BMW red interior lighting including automatic dimming to match dash brightness. Upgradable Firmware Easy to install firmware upgrades to add new features and functionality as they are released. Monitor Live Engine Data Boost pressure* (BAR or PSI), intake air temp, coolant temp, throttle blade position, exhaust gas temperature and more. Built In Performance Timer Automatic start and stop 0-60 timer for evaluating changes to your car's performance after modifications or tuning. Diagnostic Data Interpretation & Reset Read and clear diagnostic trouble codes (DTC) to reducing trips to the dealership. - 3x Analog Inputs for High Precision Sensors Add additional functionality by plugging in more sensors to gather more performance data while you drive. Standard Features High-resolution boost/vacuum display Vacuum tubing for ACTUAL n54 manifold pressure Peak Recall for all modes 15 second "run record" record/playback- Battery voltage display Precisely color matched to BMW interior lighting One-touch manual dimmer or auto dimmer using dimmer line 2 Universal 0-5v analog inputs for Meth/AFR/Etc. Optional Boost(on digits)/Meth(on bargraph) combo display Plug and Play - includes all installation parts Optional add-on comes pre-installed in OEM Vent "On the fly" config menu for user settings: - Lockout/Display off mode - Configurable Auto or Manual dimmer - English(PSI) or Metric(BAR) selection - Adjustable boost display resolution (1psi 0.5psi or 0.1psi) - Vacuum Bargraph enable/disable - Enable/Configure optional analog inputs - Ambient Calibration for boost sensor - Enable Meth flow/Boost-Meth combo display Last edited by Sales@AUTOcouture; 06-05-2012 at 09:37 AM.. |
