08-02-2017, 12:43 AM | #1 |
Rep 4,163
Oil Temp - How is it measured?
According to OBD2, the E9x M3 actually doesn't have an oil temp sensor. It has a water temp sensor.
So, how is the oil temp on the gauge measured? Any idea? |
08-02-2017, 12:44 AM | #2 |
Rep 7,541
It does have an oil temp sensor in the oil level sending unit.
Oil temp isn't an OBD II specific function.
BanjoPaterson160.50 |
08-02-2017, 09:48 AM | #4 |
Rep 2,907
Drives: 2011 E93 M3
Check out this document. It'll explain all you ever wanted to know about the oil condition sensor (which collects the oil temp data).
http://www.meeknet.co.uk/e64/oil-sensors.pdf |
08-02-2017, 12:08 PM | #5 | |
Rep 7,109
Doesn't say anything about the sensor's need of time in order to generate a value (other than when replaced/module re prog'ed)). To me suggest the oil level Carly gives soon as ignition is on could be true, and if so quite helpful. Thoughts? Thanks |
08-02-2017, 12:25 PM | #6 |
Rep 2,907
Drives: 2011 E93 M3
The oil sensor knows if there is oil in the crankcase sufficient at least for "short term engine start". The system does not display a reading immediately after startup as not only will the sump level decrease as oil is distributed withing the block and takes time to calculate level averages, but also due to condensates within the oil that hamper accurate readings until they're burned off. Therefore the system waits for as long as needed for consistent/accurate measures before displaying on the screen. Some cars read within seconds, some take many minutes- it depends on each situation.
If Carly reads an oil level before it's shown on the iDrive, I would assume that it is interpreting the raw sensor reading, but that is only my educated guess. |
08-02-2017, 12:30 PM | #7 | |
Rep 7,109
Thanks |
08-02-2017, 04:31 PM | #8 |
Rep 1,097
Drives: Melbourne Red e90 M3
with a thermometer
6MT | 11:1 Forged 4.1L | ESS-G1 | KW ClubSport | Sparta 380/355 BBK
08-04-2017, 02:45 AM | #10 | |
Rep 7,109
Cheers |
