09-03-2012, 07:34 PM | #1 |
Rep 159
Angel eyes don't work sometimes?
I feel a bit stupid right now because I can't find the search option on the mobile app and I don't have access to any computer right now so hopefully I don't get flamed for asking this.
I just realized one of my angel eyes keeps going on and off every once in a while. I was wondering if anyone knew the reason or a fix for this? This started happening a day ago. When I start the car it normally doesn't work and by the time I stop driving it's back on again. |
09-03-2012, 07:43 PM | #2 |
Rep 4,107
No error messages? I've had angel eyes go bad in my 550 and got error messages... Was simply a bad bulb both times which was changed by the dealer under warranty.
2021 X3 M40i
09-03-2012, 07:57 PM | #3 | |
Rep 159
09-03-2012, 08:04 PM | #4 |
Rep 4,107
Ahh. Sorry, didn't realize they were not OEM angel eyes. Afraid I won't be much help!
2021 X3 M40i
09-04-2012, 01:02 AM | #5 |
Rep 159
So I did a quick test and it seems the issue is somehow effected by the gas pedal? I push the gas pedal down and let go real quick and the angel eyes would flash on and go out after a second. Tried pushing the gas pedal down longer and it stayed on for longer before going out again. Any ideas? Does this possibly have to do with the resistor?
09-04-2012, 08:31 AM | #7 |
_______
169
Rep 1,088
I have Alpines and you shouldn't get any fault codes if installed correctly. As for your issue, check the grounding point. A bad grounding will cause the lights to on and off erratically.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
09-04-2012, 09:41 AM | #8 |
Rep 1,883
Drives: 2011 E92 M3
Check your install, something isn't right or is loose
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel |
09-04-2012, 11:06 AM | #9 | |
Rep 159
I was a bit confused too. I saw on the forums alpine aren't supposed to give errors but i went to the dealership because I was getting a rear taillight error and they said it was caused by the angel eyes. |
09-04-2012, 01:07 PM | #10 | |
Rep 514
My emails to Apline to try to trouble shoot a solution were initially answered and then ignored. After a month of no response from them...and continued intermittent functionining of the passenger side angel eye...I got fed up and removed their kit. Good luck getting any customer support from them.
2011 E92 M3 | Melbourne Red | Black Novillo w/Carbon Leather Trim | M-DCT | Competition Package | Premium Package 2 | Convenience Package | Enhanced Premium Sound | Heated Front Seats 2004 E46 M3 | Silver Grey | - Retired |
09-05-2012, 10:11 AM | #11 | |
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
09-05-2012, 11:55 AM | #12 | |
Rep 117
--Wes |
09-05-2012, 04:13 PM | #13 | ||
Rep 159
09-05-2012, 04:15 PM | #14 |
Rep 13,093
09-08-2012, 05:13 PM | #15 |
Rep 896
I had Alpine HIDs in also and they seem to work for about a year before they start crapping out on you. Bottom line is I removed them and put in Luxs. I would recommend against buying HID kit from Alpine.
09-09-2012, 02:25 PM | #16 |
Rep 159
ii brought it to a nearby shop and they told me its most likely the resistor thats causing the problem. I dont know anything about electrical connections and all but he said something about its not generated the correct voltage because of the resistor and that the angel eyes will only work when it sees a certain voltage. Im going to try asking for a replacement resistor or just add the additional on if they give it to me. I know adding a second one will reduce the resistance so im hoping this will fix the problem.
09-10-2012, 01:10 PM | #17 |
_______
169
Rep 1,088
One of mine was going out a while ago and Alpine sent me upgraded resistors. How old is your kit? It should have come with the new resistors because I think they just made the upgraded resistor the standard.
09-12-2012, 10:21 AM | #18 |
_______
169
Rep 1,088
Coincidently both of my angel eyes went out yesterday. I checked the inline fuse and the plastic around the metal was melted. I think it was resting against a really hot part of the engine bay.
09-12-2012, 03:15 PM | #19 |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
09-12-2012, 03:19 PM | #20 |
Rep 13,093
09-12-2012, 04:12 PM | #21 | |
Rep 159
I contacted Alex on monday and he said something about a failsafe component that keeps shutting it off. With my case it works fine when the ignition is on but once i start the car thats when the passenger side turns off. He seemed very confident it was a bulb issue so ill be getting a replacement soon. Ill keep this post updated incase anyone else has the same issue. |
09-13-2012, 11:48 AM | #22 |
_______
169
Rep 1,088
It was the passenger side for me too when they shipped me the updated resistor. The melted fuse was the culprit of the latest outage. Replace and working like a champ.
