06-12-2013, 07:06 PM | #1 |
Rep 1,359
Independent dyno ESS tuned M3
So I recently took my car to the dyno (Dynojet). The guy working was not very knowledgable, but a very nice person though. No rpm’s or torque curve, but that’s what I have available where I live. At least I got the whp (STD), and AFR.
Car: 2011 e90 M3 DCT Current Mods/fuel: ESS Akra Evo tune V2 + 240 OE software upgrade Akrapovic Evolution exhaust Dinan underdrive pulley BMC filter 93 AKI Results were pretty consistent with 4th and 5th gear pulls (worst and best pulls within 2-3 hp at the most). Best it did was 382.90 STD. I wanted to convert that to SAE and found a conversion calculator (http://wahiduddin.net/calc/calc_cf.htm). Conditions (reported on dyno chart) Temp: 92.89F Pressure: 29.84 in-Hg Humidity: 52% Vapor pressure (calculated with temperature): 1.55 (http://www.srh.noaa.gov/epz/?n=wxcalc_vaporpressure) With this data I calculated a Dyno Correction factor of 1.057 X 382.90 (STD whp) = 404.72 whp SAE Are my calculations correct, or am I way off? No matter what the HP is, the car is running GREAT!! Thanks Roman and AJ!!! Updated post with crappy iPad pic
2014 E63 AMG-S
2012 C63 AMG (P31) - gone 2011 E90 M3 FBO - gone Last edited by GIdriver; 06-12-2013 at 08:57 PM.. |
06-12-2013, 07:33 PM | #2 |
Rep 3,456
Drives: Harrop E90 M3
Doesn't the under drive pulley need to be swapped for the stock pulley? Otherwise you under drive the supercharger which causes a low boost condition. I'd swap that back to oem and go dyno again.
Which kit are you running? Did you measure boost? |
06-12-2013, 07:49 PM | #3 |
Rep 1,359
The car is NA. It has ESS' Akra Evo tune Version 2. And yes, if I were to get a sc kit, I would need to go back to stock pulley for the reasons you have explained.
2014 E63 AMG-S
2012 C63 AMG (P31) - gone 2011 E90 M3 FBO - gone |
06-12-2013, 07:59 PM | #4 |
Rep 5,396
You are confused, std always reads higher than sae
Sae is more accepted. http://m.corvetteforum.com/c6-tech-p...ml?styleid=132 |
06-12-2013, 08:10 PM | #5 | |
Rep 1,359
So I am waaay off. lol!!! Thanks for clarifying. Those are two different forms of correction. So I corrected an already corrected value?
2014 E63 AMG-S
06-12-2013, 08:14 PM | #6 | |
Rep 1,254
Your SAE numbers will be about 5% lower than the STD corrected results. |
06-12-2013, 08:15 PM | #7 |
Rep 5,396
Yea what it seems like you did was calculate sae from the std, but assuming that the std numbers were actually uncorrwcted.
Basically, sae would be about 4-5% lower than the std numbers you recorded |
06-12-2013, 08:19 PM | #8 | |
Rep 1,359
2014 E63 AMG-S
06-12-2013, 08:28 PM | #11 |
Rep 1,359
Thanks! Stock 220m wheels, stock size PSS tires.
2014 E63 AMG-S
06-12-2013, 08:30 PM | #12 |
Rep 1,359
Thank you, sir.
2014 E63 AMG-S
06-12-2013, 08:40 PM | #13 |
Rep 1,947
Let me help you out with some real numbers. You gave 382.90 whp STD.
Temp: 92.89F Pressure: 29.84 Humidity: 52% Based on those numbers, STD correction was 1.0541. First we need to get back to your uncorrected numbers by dividing 382.90 by 1.0541 = 363.248 whp uncorrected. Next we need to apply SAE correction to this uncorrected value. Based on your weather above, SAE correction is: 1.0257. So, your SAE corrected results are 363.248 * 1.0257 = 372.58. I hope this helps. |
06-12-2013, 08:49 PM | #14 | |
Rep 1,359
2014 E63 AMG-S
06-12-2013, 08:51 PM | #15 |
Perception is King
131
Rep 1,703
So what i can figure your crank HP is about 439HP which seems low to me for your mods, it mite be the High temps and humidity but you should be a little over 451 crank HP.
Perception and Reality are Two totally different Things.
06-12-2013, 09:01 PM | #16 | |
Rep 1,359
FWIW, the guy said this was the highest number he's seen on a E9x m3. Said they usually do 340-350 whp on that dyno, so I think it did well.
2014 E63 AMG-S
06-13-2013, 07:35 AM | #18 | |
Rep 5,396
what does matter is that it was a different dyno. as always mentioned, results from different dynos cannot be compared. they are never calibrated exactly the same, etc.... |
06-13-2013, 08:44 AM | #19 |
Rep 10,616
Despite the correction factor, temperature can make a difference. For example, if it is hot enough that your ECU is pulling timing, the correction factor will not compensate. It will compensate only for the quality of the air -- not how your ECU is responding to that air. Assuming your ECU is not adversely reacting, the correction factor is pretty good.
06-13-2013, 09:42 AM | #20 | |
Rep 5,396
seems like the conditions were not extreme enough to result in this, specifically since the car is NA. but something to consider, good post. |
06-13-2013, 10:23 AM | #21 |
Rep 10,616
93F is hot and these cars are actually pretty sensitive, timing could have been down -- especially if there was insufficient airflow during the dyno run (not enough fan). The ultimate dyno run would include data logging so you would know for sure.
06-13-2013, 02:16 PM | #22 | |
Rep 5,396
I do not see any of those things in this dyno run, so I would venture to suggest that no significant timing corrections occurred during his run. JMO |
