11-20-2010, 06:17 PM | #1 |
Rep 71
Oil Level Sensor Fun
I've changed the oil in other BMWs (you know, the kind with a dipstick) over 50 times with no drama. My first oil change for the E90:
Did I mention that it takes 20 minutes to get oil up to measuring temperature when ambient is < 50 degrees fahrenheit (provided you're not running air through the oil cooler by actually driving)? "Joy" is way down my list of emotions. P-cars have dipsticks - right?
Current: E36 M3 ('98), E46 M3 ('05 ZCP), E90 M3 ('11 ZCP), GT3 RS ('07) Last edited by Polarcharger; 11-20-2010 at 09:36 PM.. |
11-20-2010, 07:13 PM | #2 |
Rep 222
I feel your pain, man - there is no substitute for a dipstick, period.
Believe it or not, there are a few on this board who will argue that the 'e-stick' is superior because it's idiotproof. Well, IMHO, the idiots in this case are the BMW engineers. |
11-20-2010, 10:21 PM | #3 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
Not having a Dipstick is just stupid....
11-20-2010, 11:37 PM | #4 | |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
1. Full drain (both plugs) and replace filter. 2. Add 8.8 liters. Not 8.7 liters. Not 8.9 liters. 8.8 liters. 3. That's it. Next time I drove it, level indicated top bar, just like it did before I changed it and just like it has since then. I'm in no way defending the lack of dipstick. I agree with everyone else, it's just pointless and stupid that there isn't a dipstick. I'm just saying if you drain it all the way (let it drain for awhile to make sure you got it all), you should put in exactly 8.8 liters. (Liters, not quarts). Last edited by MysticBlue; 11-21-2010 at 12:13 AM.. |
11-21-2010, 12:44 AM | #5 |
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
Sorry to go OT: Polar, when are you going to get an E30M3 to round out the fleet? I thought I was bad by having an E36M and an E92M
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
11-21-2010, 07:36 AM | #6 |
Rep 71
Maybe someday. Perhaps I should replace the E90 with an E30 so I can change the oil without excessive grief.
Current: E36 M3 ('98), E46 M3 ('05 ZCP), E90 M3 ('11 ZCP), GT3 RS ('07) |
11-21-2010, 08:21 AM | #7 |
Rep 751
With all respect to the OP and others, if you add 9.5 quarts of oil, knowing that the drain is never going to be complete, an overfill should not be a surprise. If you add 8 quarts or so, drive it a bit to full operating temperature, you can then get a sufficiently accurate reading to complete the job. With 8 quarts added, the engine is going to have plenty of oil for lubrication and acceptable temperature under normal conditions.
11-21-2010, 03:45 PM | #8 |
Rep 282
wow, this sounds more like some crazy science experiment than just changing the oil haha
brings back memories of doing titration experiments in chemistry... ahh, the good ol' times... |
11-21-2010, 04:00 PM | #9 | |
Rep 1,887
11-21-2010, 04:40 PM | #10 | |
Rep 751
11-21-2010, 05:49 PM | #11 | |
Rep 3,928
11-21-2010, 06:01 PM | #12 |
Rep 751
Right. I allow a small fudge factor for what's in the filter. But my goal is to not overfill. I'd rather add a little over a few days than have to drain some out. No need to be anal about getting it absolutely full. These cars will do fine running a quart low until you get it full.
11-21-2010, 06:27 PM | #13 |
Rep 483
Drives: e92 M3 DCT
May I ask why you're changing your own oil when it's included in the maintenance plan of the car? Do you do it more frequently, or just hate your dealer?
2006 e53 X5 4.8is (sold)
2009 e92 M3 2008 E63 AMG |
11-21-2010, 06:33 PM | #14 |
Rep 1,887
11-21-2010, 06:37 PM | #15 | |
Rep 1,887
If I was leasing and turning it in after 2 or 3 years I wouldn't bother. |
Sinatra_M339.00 |
11-21-2010, 06:51 PM | #16 |
Rep 71
Thanks for all the input. Note I did drain simultaneously from both plugs for 40 minutes - immediately after oil reached operating temperature. Filter and "o"/crush rings were replaced. All measurements were taken while car was level.
I've since added another 300 mL (up to 8.8L) and the on-board reading hasn't moved from 1/4 (1/3?) green bar (driven to operating temperature twice). I'm now entertained by the fact that I've spent more time on one oil change than on any six previously - and am discussing oil changing "technique". I must be archaic, but I've done about everything that can be done on an E36 (and several other cars) and never thought I'd be writing about changing oil. FWIW BMW North America, my next car will have a dipstick.
11-21-2010, 06:54 PM | #17 |
Rep 263
Are you guys changing the oil hot or cold?
2011 E90 M3 ZP2 ZCV ZCW ZCP (for teh fastAr)
2005 LGT, AVO380 Turbo, a zillion other mods, ECU tuning by me. |
11-21-2010, 07:17 PM | #18 | |
Rep 71
If you really want an earful about BMW "no maintenance", check the E36 and E46 M3 forums. Note the E30 guys actually had a real plan back in the day (and BMW cars of that era held their values). Rant over.
11-22-2010, 08:43 AM | #19 | |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
I'm in the 7500 mile change interval club as well. Mine is a lease. BTW, I'm planning to run a 50/50 mix of Redline 0W-40 wt and 30 wt race oil for the winter. Can anyone give a REAL technical reason why this would be a bad idea. It will come out as soon as temps get back over 45 degrees and I'm certain the oil won't see temps higher than 200 degrees during the winter. I'm expecting significant reductions in friction and know I'll have more than enough detergent for a new engine to go less than 7k miles.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
11-22-2010, 10:05 AM | #20 | |
Rep 263
11-22-2010, 10:53 AM | #21 |
Veni Vidi Vici
89
Rep 2,750
You mean the same bearing loads that crapped out so many S54 engines with the 10W-60 TWS in them?
Are any racing teams running 10W-60 TWS? They spend a lot more time than I do at 8400 rpm; with oil temps closer to 250 degrees. I'm just saying that I can't see running 10W-60 during the winter.
12-29-2010, 07:40 PM | #22 |
Rep 1,497
Classic case of german overengineering..seems like the BMW engineer's need to come up with something new for their performance balance scorecard every year. Sad!
