09-28-2015, 07:21 PM | #1 |
Rep 2
TPMS problem
Hi all
first time to post, the TPMS malfunction has been bugging me for a while. Drove about 15 miles, malfunction happened. Mostly just go to work and off from work. Sometimes park over night reset it and sometimes not. Sometimes it just becomes normal itself but will not too long. This is 2011 m3 sedan with comp package in fremont ca. Is there a recommended shop to fix this near fremont or must go to dealer ? thank you |
09-29-2015, 12:38 AM | #2 | |
Rep 473
If it's not that, then it may be the receiver in the wheel well.
2011 e92 JzB 6MT
Akrapovic Evolution, ESS Tune, KW V3 |
10-04-2015, 02:05 PM | #3 |
Rep 6,723
Assuming all pressures are over 32 psi and you reset the tpms properly, any good tire shop worth its salt will have a tpms reader. The reader is contactless. They should just hold it next to each wheel and get a reading, or not.
To replace, some shops can just break the bead and replace the sensor without having to dismount/mount. If the shop doesn't carry your tpms, you can order it and pick it up from Apex race parts. |
Tags |
2011 m3 sedan, tpms |
