Steve Thomas BMW
      04-26-2010, 11:36 AM   #1
MNm3
MNm3's Avatar
Drives: 2009 Le Mans Blue e90 M3
Road Paint on Car! How to remove?
Its springtime again here in the Midwest and they began to re-paint the lines in the road.
I'm pretty sure I must have driven over a freshly painted line because there is yellowish paint spatter right behind my left front & rear wheel wells. Obivously, I have tried to hand wash with soap and car sponge and it did not come off, not the first, second or third time. I've had bad luck with cleaning wax and having it scuff the clear coat.
Does anyone have a solution to this that will not ruin the clearcoat or paint job?
2009 E90 Le Mans Blue M3 6MT De-Chromed, AiB V3, Rogue SSK, Brembo BBK, Eibach Pro Kit, Eisenmann Race Black, ESS Tune, MS Filter. 1998.5 Titanium Silver E36 M3 Coupe NASA GTS2 Race Car.
      04-26-2010, 11:41 AM   #2
FruitCake
Taiwan
-271
Drives: '10 E92 M3
clay bar and do it quick.
like TODAY
      04-26-2010, 12:00 PM   #3
MNm3
MNm3's Avatar
like TODAY
Unfortunately its been on there awhile and I just have not gotten around to doing anything about it yet... busy season at work. Will that still work even though its been there ahile?
      04-26-2010, 12:04 PM   #4
FruitCake
Taiwan
-271
Drives: '10 E92 M3
give it a shot.
use alot of lube and keep at it but dont rub too hard.
read the instructions.
      04-26-2010, 02:41 PM   #5
MNm3
MNm3's Avatar
I'll give it a try and see what happens. Thanks for the advice
      04-26-2010, 02:50 PM   #6
BCA
Drives: 2015 M3
Depending on how big the "specks" of paint are, you might try Stoner's Tarminator first. Clay should take care of it if the spatters are small, though. Whatever you end up doing, be sure to re-seal/wax afterwards.
2015 ///M3 | BSM/Full Black/CF | DCT | Silver 19s | Executive | Lighting | DAP | Adaptive Suspension | HK | Enhanced USB | Tint
Past BMWs: 2014 550i, 2013 M3 ZCP, 2012 535i, 2011 E90 335i, 2009 E90 M3, 2008 X5, 2006 330i, 2004 330i
      04-26-2010, 05:39 PM   #7
MNm3
MNm3's Avatar
Specks are no larger than the tip of a pencil, maybe a bit larger. I'll give both things a try and see what happens. I have to wait for more clay, all out of good stuff.
      04-28-2010, 08:25 AM   #8
quality_sound
8 tracks of madness
Drives: Slowly
Clay, if that doesn't work 3M adhesive remover and soak the piss out of it. If that doesn't work, soak a rag with it and see how you can get it to stay against the paint. All that really is is lighter fluid so it won't hurt the paint but it might need to soak in for a while.
      04-28-2010, 10:10 PM   #9
MNm3
MNm3's Avatar
Thanks. New Clay bar comes in tomorrow and I'll give it a shot and let you all know how it goes... you know just incase you guys ever need to get road paint off your car.
      04-29-2010, 04:33 AM   #10
quality_sound
8 tracks of madness
Drives: Slowly
With the size of the drops you got you should be fine. I got roofing tar off of one of my brother's cars a few years ago.
      05-14-2010, 04:21 PM   #11
MNm3
MNm3's Avatar
I tried the clay bar and it did not work. The paint specs will not come off and I don't want to rub hard with the clay. Next up is the 3M adhesive remover... more to come
      05-14-2010, 05:08 PM   #12
Griz
Drives: 2010 BMW Escort Type M
Goo off, and possibly some plastic razor blades. If you need to borrow an orbital buffer afterwards, just drop me a PM.
If you want to take it to a professional detailer, look for RaskyR1 over at autopia. I've never had any work done by him, but the work he's posted up is pretty damn impressive.
Search this Thread:
Advanced Search
