11-16-2017, 05:01 PM | #1 |
Rep 1,003
Drives: 2008 E90 M3 DCT Silverstone II
Hi all, hoping someone can help point me in the right direction or just tell me I'm an idiot and point me in the right direction afterwards...
I have a 2008 E90 M3, and the driver's side rear door lock actuator seems to have crapped out. I can still open the door from the inside, and then from the outside once its unlocked. However, I can only lock the door with the keyfob. Does not let me unlock. Makes a short vibrating/multi-clicking noise but fails to push the lock pin up. Does anyone know where I can get a replacement for the driver's side rear door lock actuator? Majority I see online are for the front door. Thanks
Current: 08 E90 M3 DCT SSII w/ BE RB Swap, H8 Lux 180s, MS Drop-in AF, CF spoiler, CF diffuser, OEM CF leather trim, CF DCT paddles, Custom DCT flatbottom wheel, MirrorTap 9500ix, RockAuto rotors, Hawk HPS pads, AMS ECU 93 Oct Map Tune, GTS DCT update, Slambo custom undertray
11-17-2017, 04:03 PM | #2 |
Rep 1,003
Did I post this in the right place?...
11-18-2017, 05:27 AM | #3 |
Rep 724
The only other possible sub forum is cosmetic exterior/interior. I found a DIY on the front door lock. Also check out real OEM, they have diagrams and part #s.
DIY: Repalce door lock actuator http://www.m3post.com/forums/showthread.php?t=1037871 |
SDPLV493.00 |
11-26-2017, 04:45 PM | #4 | |
Rep 1,003
11-27-2017, 08:04 AM | #5 |
Rep 724
You may want to put your specific VIN into RealOEM, to see if there were any changes.
https://www.realoem.com/bmw/enUS/sho...diagId=41_1634 |
12-06-2017, 12:23 AM | #6 |
Güdentyte
1156
Rep 1,196
I replaced the driver rear door lock actuator on my e90 335i a couple months back. Part # 51227202147. It’s interchangeable to most bmw models. Took me a while to find the correct part number but this one should fit the e90 m3. Bought a new one on eBay for about $70.
Here’s a good DIY vid:
CURRENT - 991 GT3 | Future Classic 1M | Model 3 | T4R TRD Pro Lime Rush
SOLD - MB M2 CS | SMB F80 M3 CS | E90 M3 | E90 335i | E46 M3 Vert | E39 M5 | E34 525i |
