07-12-2015, 03:50 PM | #1 |
Rep 36
E92 m3 rear shock mount
Hi all,
Looking for some more options on rear shock mounts for the e92 m3 chassis. Installing mcs shocks and need something for a 12mm shaft. Only two options I found were power flex and akg. Was hoping to find a spherical mount but having no luck finding any. Anyone know if some other options? |
07-15-2015, 10:30 PM | #2 | |
Supreme Allied Commander
3842
Rep 54,352
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
07-18-2015, 02:13 AM | #3 |
Rep 36
I've quickly learned this. When it's time for a rebuild I'll see if mcs can build me an eye to eye rear damper. For now I've used akg with some cnc machined washers. For anyone doing this in the future neither of the rear shock mounts mentioned above come with the washers you need. Off the shelf washers which have a ID of 12mm arnt actually 12mm. They are on average 13.5 for clearance. That's a little to much slop and not all of the washer rests on the shock shaft shoulder. Some people just drill the OEM mounts and call it good. I used 6061 aluminum and machined a set. Specs for anyone that wants them are 50mm OD 12.3mm ID. I went with 6mm thickness which does remove 1\4 inch of shock travel but running 900lb springs in the back minimizes the risk plus I added bump stops and mcs dampers have a lot more travel than oem anyways.
