03-08-2010, 10:13 PM | #1 |
Rep 613
Any caliper upgrades out there that use the stock rotors?
Anyone know of any caliper upgrades that work with the factory rotors? The factory rotors are a good design and size, the calipers however are a different story.
03-08-2010, 10:18 PM | #2 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
The calipers are fine. They could use solid bushings, but otherwise are fine for all but endurance racing.
The rotors, on the other hand have inadequate cooling due to the way the rotor is connected to the hat with pins. If you want a brake upgrade, just go to the Bimmerworld website and get the Performance Friction kit. |
03-09-2010, 02:19 PM | #3 |
269
Rep 6,093
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
A solid brake upgrade would be some premium Stoptech/Centric (ie: our Frenetiks) slotted (drilled if you do not track) rotors with SS brake lines, synthetic fluid and some good aftermarket pads such as Hawk HPS, Porterfields, Stoptech St. Performance, Cool Carbon, etc etc
03-09-2010, 03:02 PM | #4 | |
Rep 12,999
03-12-2010, 04:52 PM | #5 | |
Brake Maven
Rep 229
If the aluminum hat is not bolted solid to the iron disc, the advantages of heat dissipation are lost. This is one of the advantages to a strap drive disc assembly over a traditional full-floating assembly. The straps serve as another thermal conductivity path, although certainly not better than a bolted 2-piece arrangement. However, decoupling is achieved with no moving parts, rattling or periodic maintenance. Chris |
03-15-2010, 11:05 AM | #6 | |
Veni Vidi Vici
89
Rep 2,750
The Audi RS6 used huge rotors with 8 piston Brembo brakes and had horrendous brake overheating issues. As soon as we replaced the pin type rotors with a conventional design, the majority of overheating problems went away. |
