      08-24-2010, 10:44 PM   #1
哇靠M3
Taiwan
85
Drives: e92 M3
2009 E92 M3  [9.00]
DCT: getting into D1 after reversing?
I find it annoying that sometimes after I reverse my car and I need to quickly get back into drive mode, but the car will get into Manual 1 instead of Drive 1.
Do those who have DCT have this issue? Is the car suppose to be programmed to go into Manual 1 or Drive 1 on first toggle to the right?
      08-24-2010, 10:49 PM   #2
atomicdoc
Drives: '17 M4 Vert ZCP,
Mine goes to D1
      08-24-2010, 11:02 PM   #3
Pillzilla
Drunk before 11AM
Pillzilla's Avatar
Drives: 07RDX,11E90M3,14X3 35i
2011 E90 M3  [8.50]
2014 X3 35i  [0.00]
Mine goes to either D3 or S3. Mostly S3. It's seems to be random. I'm not sure what it's programmed to do.
      08-24-2010, 11:08 PM   #4
哇靠M3
Taiwan
85
Drives: e92 M3
2009 E92 M3  [9.00]
yeah, i think ti's pretty inconsistant. i realize that it doesn't always go to D1 after toggling away from reverse
      08-24-2010, 11:46 PM   #5
kpneverdies
Drives: AW M3 E92 2010
u guys have the latest software.
if u guys reverse completely and change gear, it goes to S.
if u guys change gear while it's still reversing, it goes to D.
      08-25-2010, 12:48 AM   #6
m3rav4civic
Drives: 2011 E93 M3
For me, what's annoying is the lag time. Shifting from R, it takes a solid 3 or 4 seconds to engage any other gear
      08-25-2010, 01:43 AM   #7
BB_cornelius
Drives: 2010 E93 M3 AW/FR
There might be a problem with yours or something. Mine takes less than 2 secs.
      08-25-2010, 01:48 AM   #8
Finnegan
Dog Listener
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
How recent is your software version? I had mine updated last week (side effect of alarm coding) and it's much faster now. It was like an eternity before (that was with last last December's version), but it's much faster.
      08-25-2010, 05:08 AM   #9
Radar10
Radar10's Avatar
Drives: '11 ///M3
I have noticed that if i have been driving it around in D then reverse, when i put it back it will go into D. Like wise if i was in S, or if i have not been driving it around in D very long.
      08-25-2010, 07:31 AM   #10
Shake-N-Bake
Drives: AW/FR e92 M3
Mine just goes back to whatever I had it in prior to me putting it in reverse; if S then back to S, if D then back to D. Mine is an '09 and I do not have the latest software.
      08-25-2010, 07:44 AM   #11
mkoesel
Moderator
Drives: No BMW for now
You say "back into" above, so am I correct in interpreting that this means you are backing up after already having driven the car in D mode for some time?
In any case, the fact that you mention "sometimes" makes me think that you are experiencing a similar (though, slightly different, from your description) buggy behavior that myself and a few others are.
Neither, actually. On the first right click of the lever after the engine is started, it should go to S3. On the second click it should go to D mode, and be in whichever drivelogic setting you had last used for that mode. So if you were last in Drivelogic setting 1 for D mode (D1), then it will go to D1, yes. But if you were last in Drivelogic setting 4 for D mode for example, then it would go to D4.
      08-25-2010, 07:46 AM   #12
mkoesel
Moderator
That's a bug and its not quite random (although I've since found that it is not quite as cut and dry as outie has described):
http://www.m3post.com/forums/showthr...61#post7786161
      08-25-2010, 08:00 AM   #13
Pillzilla
Drunk before 11AM
Pillzilla's Avatar
2011 E90 M3  [8.50]
2014 X3 35i  [0.00]
Good info thanks. Now I know I'm not crazy.
      08-25-2010, 09:23 AM   #14
SchnellM3
Digger
SchnellM3's Avatar
Drives: 03 E46 M3
That's what mine does, but on the first start of the day after backing out of the garage it goes into Manual first. Which I suppose is alright because then I'll drive her harder on the back roads
2009 E92 M3 /// Melbourne Red /// Fox Red /// M DKG
Full Innotech Exhaust - DINAN Intake - IND Engine Bay Appearance - IND Hand Stitched Boot Covers - and much more....
      08-25-2010, 11:38 AM   #15
raiste
Time is the fire in which we burn.
raiste's Avatar
Drives: 2015 SSII M3
Neither, actually. On the first right click of the lever after the engine is started, it should go to D mode, and be in whichever drivelogic setting you had last used for that mode. So if you were last in Drivelogic setting 1 for D mode (D1), then it will go to D1, yes. But if you were last in Drivelogic setting 4 for D mode for example, then it would go to D4.
Unless I'm misinterpreting what you are saying, mine doesn't do this. On the first right click after starting mine goes to S3. On the second click it goes to the last D setting I used.
      08-25-2010, 11:46 AM   #16
mkoesel
Moderator
You're right. I wrote it backwards. I will fix my post. Thanks.
      08-25-2010, 11:49 AM   #17
outie
Drives: 2022 Porsche Taycan GTS
Yes, first click should be S3. 2nd click is Dx where x=last D mode being used.
