12-18-2008, 06:15 AM | #1 |
Rep 71
Strange noise from the MT
Yesturday, while i was waiting my garage gates open, i turned the music off, and for the first time heard some strange low mechanical noise comming from MT. It took me a bit of time to recognize and understand what was it. I placed my ear on/near the shift knob, certanly it have become more clear. The noise apears only when MT is engaged somehow (in neutral gear with clutch engaged, when driving slowly in first gear), its like the noise of rotating shafts or gears. I understand that some noise must be, but sould it be heard by me in total silence (music off, clima off)? In my previous car (Impreza STI) there was no such noise, maybe i havent heard it because there are a lot off other noises, i dont know. In other cars as well.
I also tried to rev, the noise increased only a little. So is it normal, will it disappear after i will have my 2000km/1200m maintanence done or i will have problems with it? For now i did only about 1200km, but in 100% order with running in recomendations. Thank you for your answers in advance) |
12-18-2008, 09:01 AM | #3 |
Rep 369
LOL.. and the little snowflake comes up on the dashboard for a second or two...
its a warning it below freezing out... i think warns you at 36 degrees and below (f) .... I came from an STi too, ALL the M's are noisy at idle, sound diff with the clutch engaged and not.. its an M-motor, the're all noisy AND AMAZING..
2008 E92 M3 (03-08-2008-first delivery)
JET BLACK on BLACK w/Carbon Leather, 19's, Tech, 6spd.. |
12-18-2008, 09:35 AM | #5 |
Rep 237
The snowflake comes on at 37 because of two reasons. Bridges can be frozen because of no warming earth underneath, and if it's 37 and you drive through a valley, a simple 100 foot elevation change COULD mean that you will experience some 32 or lower conditions even when the majority of your locale is a tad warmer @ 37 degrees.
Not lame, might save your oily hide from certain death in a 415hp RWD car with summer tires.. |
12-18-2008, 09:39 AM | #6 | |
Rep 237
(seriously though, that is NORMAL for a 6MT tranny. Sounds like there is no fluid in the system and you are hurting things? NOPE, all is fine. Learn to like that sound. M cars have had it for years. You are hearing square cut gears - more performance from that type of gear but kinda loud. Understand that you are hearing what M3 race drivers hear.) |
12-18-2008, 09:40 AM | #7 | |
Rep 754
12-18-2008, 10:57 AM | #8 | |
Rep 2,279
'09 Interlagos Blue E92 M3 (sold to a good home)
12-18-2008, 01:00 PM | #9 | |
Rep 237
Have you never driven a Mercedes, Audi, BMW? Even VW. The little snowflake icon comes on in the high 30's. ALWAYS. From every german manufacturer. It's not lame, it's not silly. It might even be a German DOT regulation. It's simply letting you know that icy roads are possible in your area. Stop whining and go save your $14/hour paychecks so you can actually go get a M3 and stop masquerading as an owner. |
12-18-2008, 01:59 PM | #11 | ||
Rep 754
The reason that it's probably 37 is because the sensor cannot be accurate - and in my experience it's not. So it's a silly little warning to allow for tolerances in the temp sensor. Don't try to get all scientific about it or buy BMW marketing BS. I made my comment mostly based on this quote: Quote:
12-19-2008, 12:35 AM | #13 |
Rep 237
12-19-2008, 12:59 AM | #14 |
Rep 636
According to the Owner's Manual:
"Outside Temperature Warning When the displayed temperature sinks to approx. +37F/+3C, a signal sounds and a warning lamp lights up. There is an increased risk of black ice. Black ice can also form above +37F/+3C. You should therefore drive carefully on bridges and shaded roads, for example, otherwise there is an increased risk of an accident." It's there to hopefully save your butt. A very nice feature to have on the car. On my E46 M3, I checked my car's temperature sensor against a very accurate thermometer, and they both always read within 1 degree of each other. The thermometer sensor is quite accurate. It's also designed to read temperatures dropping much faster than reading temperatures going up. So on a cold day with the car in a warm garage, as soon as it goes outside, the temperature will quickly drop to ambient temperature. On the other hand, in the summer when the garage is cooler than the outside temperature, the thermometer is much slower to rise to the ambient temperature. It does this since if the car is outside in the sun, the sensor could be heated by the sun to over, say 120 degrees when it's, say 85 degrees outside. When you parked your car earlier in the day it might have been, say 60 degrees. When you start up your car, it'll probably still read 60 degrees for a long time rather than 120 degrees so as you drive, the hot temperature sensor will settle slowly to 85 degrees. It is a nice instrument for temperature and they have thought it through. |
12-19-2008, 07:43 AM | #16 | |
Rep 754
12-19-2008, 10:48 AM | #17 | |
Rep 237
So let's enjoy the snowflake (it's Christmassy), watch for black ice, and have a beer! |
12-19-2008, 11:23 AM | #18 | |
Rep 754
12-19-2008, 07:18 PM | #20 |
Rep 5,448
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
