Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Cars for sale/wanted/trade
BPM
      04-02-2021, 07:10 AM   #1
tac1
Drives: M3
2005 Silver Grey E46 M3 Manual
USD 1.00
Car is now being auctioned at: https://bringatrailer.com/listing/2005-bmw-m3-65/
Please email: SGE46M3@gmail.com
2005 E46 M3
Silver Grey Metallic Exterior
Black Interior
6-Speed Manual
Cold Weather Package
Premium Package
Xenon Headlights
Harmon-Kardon Sound System
VIN: WBSBL934X5PN62577
Mileage: 60,830
Walkaround:
Startup:
Changes From Original:
Motor: OEM engine control unit and intake system replaced with a mixed CSL solution. Genuine MSS54 HP ECU programmed with CSL firmware. CSL carbon airbox with carbon trumpets manufactured by Karbonius mated to an OEM CSL intake flap and OEM CSL air shut off valve and crankcase vent. CNC stainless steel MAP sensor conversion kit by Kassel paired to a Bosche sensor pre-terminated with TEFZEL motorsport wiring and Viton o-rings.
Shifter: OEM shifter replaced by an upgraded Ultra Class kit by AutoSolutions. Thicker lever and a teflon lined uniball replacing the pivot ball. Motion ratio is 25% reduced from OEM. Shaft is 13mm taller to account for the paired 13mm shorter OEM ZHP shift knob.
Steering: OEM steering rack replaced with OEM ZHP (Yellow Tag). The 13.7:1 published steering ratio results in 14.5:1 ratio in the E46 M3, a reduction from the OEM 15.4:1 ratio.
Suspension: OEM springs and dampers replaced with Bilstein B12 Suspension. The monotube, inverted, gas pressurized dampers paired with progressive springs result in a lowering of 0.25” less than OEM measuring at 14.25” front and 13.75” rear from ground to fender.
Spacers: Wheel spacers and extended lugs by Future Classic were added in front (18mm) and rear (15mm).
Lighting: OEM yellow side markers were replaced by OEM clear side markers. OEM headlight corner lenses were replaced by Depo black interior housing corner lenses. OEM yellow front bumper reflectors were replaced with Silver Grey.
Interior: OEM Brushed Aluminum trim was replaced by OEM Titan Shadow. OEM shift knob was replaced by an OEM ZHP shift knob.
Battery: OEM battery replaced with lightweight OEM CSL Battery.
Refresh @ 50k Miles:
Drivetrain:
* New Engine Mounts [11812283798]
* New Transmission Mounts [22322282340]
* New Universal Flex Disc [26112226527]
* New Steering Coupler [32301094703]
* New Tie Rods Left & Right [32112228785 + 32112228786]
* New Steering Reservoir [32416851217]
* New Brake Fluid [81220142155]
* New Transmission Fluid [83222339221]
* New Differential Fluid [83222282583]
* New Steering Fluid [CHF11S]
Motor:
* New Spark Plugs [12120022902]
* New Alternator [12317837981]
* New Fuel Filter [13327831089]
* New CSL Airbox Air Shut Off Valve [11617833647]
* New CSL Crankcase Vent Hose [11157833649]
* New CSL Intake Flap [11617833498]
Suspension:
* New Front Control Arm Bushings [31122229857]
* New Rear Trailing Arm Bushings [33326770817]
* New Front Upper & Lower Spring Pads [31331091233 + 31331096664]
* New Rear Upper & Lower Spring Pads [33531136385 + 33531094518]
* New Front Sway Bar End Links [31352283441]
* New Rear Sway Bar End Links [33552283743]
* New Front Upper Strut Bearings [31331090612]
* New Rear Shock Mounts [33522241450]
Wheels:
* New 18x8 Style 67 Front Wheels [36112229950]
* New 18x9 Style 67 Rear Wheels [36112229960]
Exterior:
* New Headlight Lens Covers [63126929565 + 63126929566]
* New Fender Grilles [51132694607 + 51132694608]
* New Hood Grilles [51138208683 + 51138208684]
* New Front Bumper Guides [51118195295 + 51118195296]
* New Rear Bumper Supports [51127895643 + 51127895644]
* New Windshield Cowl [51718232894]
* New Windshield [FW2457 GGY]
Interior:
* New Cup Holders [51168217953]
* New Center Console [51168218305]
* New Center Dashboard Air Vent [64228363199]
* New Floor Mats [82110136311]
* New Cabin Air Filter [64319071935]
* New ZHP Shift Knob [25117896886]
* New Shift Boot [25111434426]
Additional Notes:
* 3 owner car, clean title, all paint and bodywork original.
* Located in New York, 50k refresh by Matrix Integrated in Oregon.
* 2 keys, 1 valet key, window sticker and user manual included.
* Front bumper PPF remains. Fender and hood PPF removed at 50k.
* Driver side rear wheel has two curb marks, see photos.
* Rear bumper on driver side has indent, see photos.
* Driver side rear rubber window trim has tear, see photos.
* Michelin Pilot Super Sport tires have approximately 25% tread life.
* Subframe, rod bearings, and vanos all original, no known issues.
Full Album: https://photos.app.goo.gl/RJcheDSUv1dbQp7J9
      04-02-2021, 09:47 AM   #2
kar_ma
Drives: 2016 WRX Limited
Price?
      04-02-2021, 09:50 AM   #3
porsche5k
Drives: Porsche 911
Silver Grey is one of the best colors for the E46 M3, especially since it was offered on the CSL. GLWS, you won't need it.
      04-03-2021, 01:21 PM   #4
mrm3too
Pump that Bass
98
Drives: E36, Model 3, Cayenne S
This thing is stunning, should go quickly.
1995 E36 AA M3
F80 M3 X Volk TE37s
