10-28-2020, 08:31 PM | #1 |
Rep 264
The battery options
Hi guys!
My car just got 86k miles I think it will be nice to change the battery now! My car do not have idrive I wonder is there any other battery that is lighter than OEM battery but can still use as daily driver? Appreciate all helps! |
10-29-2020, 11:55 AM | #2 |
Rep 6,637
could get a lighter redtop battery if you get the bimmerworld kit to install it.
10-29-2020, 01:47 PM | #3 |
Rep 142
You can go to a smaller reserve AGM battery like mentioned above. You can also switch up the chemistry and look at Lithium options from companies like Braille, Deka, Antigravity, Odyssey. Having had a lithium on my R1200GSA, there are pros and cons to the lithium options so just do some research.
-Kai
10-29-2020, 02:19 PM | #5 |
Rep 21,727
I went with the Antigravity. Direct bolt in and uses the factory mounting points. Ended up saving 43lbs over the stock battery.
10-29-2020, 06:57 PM | #6 |
Rep 18,823
Drives: BMW
Antigravity has nice options like its own integrated START partition in which you'll never be stuck with a dead battery again.
Simply press a button on the battery or remote and you have your own jumpstarter - no cables needed.
