10-28-2020, 01:18 PM | #1 |
Rep 89
Is this oil or DCT fluid
I just bought a e90 M3 yesterday and I saw a spot of oil on the ground this morning. The spot is towards the front of the car. I smelled it and it didn’t have a smell. The previous owner told me that the cars oil pan gasket has not been replaced yet. Is this oil or could it possibly be DCT fluid.
10-28-2020, 01:42 PM | #2 | |
Rep 3,411
Check both plugs.
10-28-2020, 02:03 PM | #4 | |
Rep 3,411
The concern is if that plug is stripped its ~$1500 for a new oil pan, possible other solutions as well depending on severity. The pan is aluminum and I believe it's easy to cross thread the plugs and strip the threads or even crack the pan. I think the DTC bottom cover is prone to weeping, not dripping. But I would defer to DTC owners.
10-28-2020, 02:26 PM | #6 | |
Rep 89
10-28-2020, 05:32 PM | #10 |
Rep 7,113
If you have access to a lift ypu can even peek in under the DCT cover and see if there is a leak. Def if its big enough to spill over to the floor.
10-28-2020, 06:04 PM | #11 |
Rep 89
10-28-2020, 07:06 PM | #12 |
Rep 553
Looks too far forward to be DCT and the looks of it .... it looks like oil. What part of Md are you in?
Daily: 2010 Venza
Grocery Getter: 16 Q50 Red Sport Track: Top Gear or Grand Tour Concealed Weapon: 11 BMW e92 M3 DCT ESS G1 |
10-28-2020, 08:45 PM | #13 |
Rep 89
10-28-2020, 08:59 PM | #15 |
Rep 553
[QUOTE Why?[/QUOTE]
If you were close was going to look at it to try to pinpoint it. Hope you find the source of the leak!
Daily: 2010 Venza
10-28-2020, 09:07 PM | #16 |
Rep 89
10-28-2020, 09:17 PM | #17 | |
Rep 3,411
Definitely find the source or that leak.
10-28-2020, 09:23 PM | #18 |
Rep 2,160
That's a lot of oil to be dripping overnight, definitely not a DCT leak because the transmission is located further back. Under the DCT pan is a felt/plastic cover that acts as a drip collector, so even if your DCT was weeping fluid it's mostly caught and will pool in that plastic undertray.
I didn't even know both my DCT E9x M3s had leaking mechatronic covers until I I dropped that plastic tranny cover and found DCT fluid pooling, the bottom of the car was bone dry. My guess is a stripped oil drain plug like some have mentioned, unfortunately, that could potentially be a nightmare repair. |
PACarGuy683.50 |
10-28-2020, 09:40 PM | #19 |
1919
Rep 1,889
No way that's DCT fluid. The puddle is literally below one of the oil drain plugs.
10-28-2020, 09:44 PM | #20 |
Rep 89
10-28-2020, 10:15 PM | #21 |
Rep 258
It should be that the drain plug has been peeled off. Purchase this TIME-SERT M12 X 1.50 metric drain plug repair kit. It can be solved. good luck!
10-28-2020, 10:36 PM | #22 | |
Rep 553
Bowie! Happy to help. Just pm if you want a hand
Daily: 2010 Venza
