03-10-2020, 01:43 AM | #1 |
Rep 571
Upgrade HiFi to EPS: Need help
Hey Guys, So I just bought an 2011 E92 M3 about 2 weeks ago, and I see that I have the base HiFi system in it. I would like to do a simple upgrade to the EPS system, as I don't feel like doing a huge audio overhaul. Is everything plug and play? I'm under the impression that i need the following, please let me know if I have something wrong or missing anything... - EPS front door tweeters (2x) - EPS font door mid range (2x) - EPS rear door mid range (2x) - EPS rear door tweeters (2x) - EPS rear deck mid range (2x) - EPS rear deck tweeters (2x) - EPS subwoofers (2x) - EPS amplifier (2x) Also, is the center speaker the same and the EPS? Thanks in advance! |
03-10-2020, 09:47 AM | #2 |
Rep 451
I can't remember for sure regarding details on the amp or coding to recognize it and add the EQ settings to the system... but.... I did a full speaker swap over on my X3 from HiFi to esp and after adding a sub and amp I honestly don't see the need to worry about using an esp amp. (I seem to remember there are significant wiring differences between the two amps but I might be wrong)
The sound in the X3 is extremely clear now with the esp speakers as well as accurate, and the bass is better as well. I retained the hifi subs and use them more as mid ranges and let the sub do the heavy lifting. I think the esp in my M3 might be clearer at very loud volumes but I really don't ever turn it up loud enough to notice. Not sure how much of a help this is since it's not an M3 that I swapped speakers on but my advise would be to upgrade the speakers then take it from there. Start with front sound stage then move to the rear. I honestly wouldn't waste time or money on the rears if I had it to do again, they're just fill and not really noticeable anyway.
Instagram: @dasianoak
03-10-2020, 10:44 AM | #3 | |
Rep 571
03-12-2020, 08:22 AM | #5 |
Save the manuals!
6016
Rep 6,747
Far from PnP, the entire wiring setup is different HiFi vs EPS, it's a tonne of work.
The only viable option would be to use EPS speakers with an aftermarket amp. Honestly it might even sound better than stock EPS.
03-13-2020, 08:32 AM | #6 |
Stance to make her dance
708
Rep 2,002
As others have said, much easier aftermarket options. I recently did an entire install series on BavSound products. Completely plug and play. I had the Standard HiFi in my car and upgraded.
Check out my thread below: https://www.m3post.com/forums/showthread.php?t=1701861
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2022 G80 M3 6MT, FEMTO, BM3, KW, AWE, MAD, lots of carbon |
03-14-2020, 12:36 AM | #7 | |
Rep 571
thompsac25708.00 |
03-14-2020, 11:27 AM | #8 |
Rep 2,869
I am interested to hear from someone who upgraded from the Premium sound (Option Code S752A) to Bavsound. There is a claim for superior sound from same stock amplifiers. I understand the logic (not a cost limited option, better efficiency) but I do want to hear from someone that actually done the upgrade and if the "improvement" is noticeable on daily basis.
