12-29-2016, 10:51 PM | #1 |
Rep 259
First track build (e92 M3)
I bought a 2010 e92 M3 6MT a little over a year ago with 36,000 miles as a dedicated track toy. I decided to buy the car after I got into tracking with my2014 Mercedes E63 S model AMG. The merc was great on the track, faster then almost anything but it was really heavy so consumables got to be ridiculous. That is when I decided a used e92 M3 should be an additional car just for the track. I was nieve at first, thinking I could just upgrade brake pads and lines and get some r compound tires. In a short time, I had enhanced the track capability and completely killed the street ability of the car. I installed JRZ RS 2 way damper, eibach anti roll bars and had started to replace most of the rubber bushings with solid spherical bearings including the rear subframe and differential. I had installed a catless X pipe with Bimmerworld axle back (which sounds great) along with an ESS tune. I then had a custom diff with 4.10's done by Jim Blanton. The car was getting better but I had no safety and it was still heavy.
Now I have the car being fully built by Late Apex Fabrication in Fort Worth, Texas after I could not find anyone to do the job I wanted and in the timeframe I wanted in Arizona where I live. So back in November, off the car went. I mentioned I was nieve early on in buying the car and figuring a few mods would make it a suitable track toy. Initially, I set out to just do the cage and a few safety related items like harnesses, some type of fire suppression or just extinguisher and figured the rest would come later. Well that nieve (or maybe impatient) trait reared its head again and I am now in the middle of a pretty extensive build. I am sure I will forget many of the items but the bulk of the upgrades includes: Full cage tied into rear subframe and front strut towers Reinforced strut towers and rear shock towers Removal of all non essential interior pieces to include rear deck NASCAR bars on drivers side Cool shirt pro air and water for a cool shirt and helmet cooling M24 Electric power steering pump and new rack Delete the entire belt loop for the a/c and power steering Solid aluminum motor and transmission mounts Lightweight flywheel OMP Drivers and passengers seats Stilo intercom Engine is out so having rod bearings and valve cover gaskets being done. Greg Smith from Greg Smith Racing does a lot of work with Late Apex Fabrication so Greg is doing the motor work and helping on any unique mechanical items. Headers are being ceramic coated Do88 oil cooler, radiator and ps cooler (although might not need that now) Intrax 4 way Black Titan coilovers with ARC and spring adjusters Most likely going to a muffler delete with turndowns Safecraft drivers net Safecraft fire suppression system Schroth enduro harness for driver and profi II for passenger MA Shaw FRP doors (10lbs each) Optima battery (only 24 lb savings but no issues to deal with) Bimmerworld Carbon headlight blanks SPL Parts: front control arms, rear toe arms, camber arms, adjustable sway bar links, Thrust Arms PFC Z54 front kit with 11 pads Cantrell brake duct cooling kit Bimmerworld Headers and X pipe I am sure there are several things I am missing so will post again when I figure out what they are. I will also update with pics as the car progresses. The car started the build weighing 3,450. My goal is to get below 3,000 before driver. May not get there at the end of the initial build but one way or another it will happen. I have learned a lot from many of the forum members so figured I would share my build as well. Erik Lister from Late Apex has also been very knowledgable and has made some really good recommendations along the way. Last edited by FrostyAZ; 02-28-2017 at 09:34 PM.. |
12-30-2016, 12:36 AM | #5 |
Rep 777
Drives: E92 2013 M3
12-30-2016, 09:20 AM | #7 |
Rep 259
More pics
You can see the M24 electric power steering pump in this picture. Special thanks to Warp 10 for turning me onto this. Very happy to remove the belt driven pump and a/c compressor.
12-30-2016, 10:30 AM | #9 |
Rep 118
Drives: 340i
I'm also in az, would love to see this in person one day when it's completed. Build progress is impressive so far! Keep the pictures coming!!
now: 2017 340i M-Sport then: 2009 E92 M3 DCT |
12-30-2016, 04:36 PM | #10 |
Rep 2,527
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
Wow, what a monster build. Subscribed for sure.
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
12-30-2016, 08:30 PM | #11 |
Rep 259
Coilovers
Here is a picture of the Intrax coilovers. I am hoping they turn out to be worth it. Could not find many people in the US running them but they seem quite popular in Europe.
12-30-2016, 08:45 PM | #12 |
Rep 2,672
Epic! I can't wait to see the finished product, congrats on the build being well underway and glad you chose this car!
12-30-2016, 08:55 PM | #13 |
Rep 259
12-30-2016, 08:56 PM | #14 |
Rep 259
12-30-2016, 10:33 PM | #15 |
Rep 8,076
Drives: 11 E90 M3 Individual
You should be able to get under 3k lbs...wiring and sheet metal removals is a significant amount of weight.
Was this an idrive or non-idrive vehicle?
2018 F30 320iX Melbourne Red
12-30-2016, 10:51 PM | #16 |
Rep 1,718
Sub'd
12-31-2016, 01:27 AM | #17 |
Rep 2,806
Drives: '09 E90 M3 - IB
Looks like you have a solid plan in place. Can't wait to see how it progresses. Should be really nice when it's done!
Keep us posted! |
12-31-2016, 06:40 AM | #18 |
Rep 1,718
Where did you source the doors? M24?
12-31-2016, 07:17 AM | #19 |
Rep 1,848
12-31-2016, 08:41 AM | #20 |
Rep 936
Builds like this make me all giddy on the inside. Excited to see more
You'll find me at the track
BMW CCA Club Racing #905 Instagram: scottynotpippen |
12-31-2016, 09:17 AM | #21 |
Rep 259
Car was a total stripper. No I-Drive, cloth seats, no sunroof. I don't have the original sticker but I am guessing there was not a single option checked, which was exactly what I was looking for. The car had some mods already done to get my starting weight before the build at 3,450 but those mods maybe amounted to 50 pounds.
12-31-2016, 09:28 AM | #22 |
Rep 259
Doors are from MA Shaw, made in the USA. Price was very reasonable and Mike (owner) is a nice guy. It took them a little while to find the mold, he said there has been very low demand for E92 parts. They make a lot of lightweight Porsche and E36/46 parts. I have asked him to let me know me how many firm orders he needs to make new molds. Would be nice to have a source for reasonably priced lightweight body parts. I would like him to make a lightweight GTR vented hood. First I want to see how the doors look and feel when mounted.
