02-10-2016, 02:39 AM | #1 |
Rep 734
Car doesn't start. DME Problem. (SOLVED!)
Hi,
Car was in storage for the winter. Start car every couple of weeks and let it fully warm up fully. Do not have it on a battery tender, but the car does have enough battery. When i start car, it prompts me to reset date and clock, so i assume the battery ran flat. (i resetted the time and date). Tried to start the car regardless, the starter will try to fire it up, but the engine just doesn't crank up at all. When i put the key in, everything works, dash, lights, windows, radio, heated seats, rear defogger etc etc. The only thing that doesn't "work" is the engine doesn't fire up. Tried jumping it with another vehicle and a portable jumper but same thing, car starter will fire up, but engine just won't turn over. Pre-Storage i do have failing Throttle Body Actuators (both banks) that i am gonna be replacing when the car comes out of hibernation. Maybe they completely died and thats why the car doesnt start? Quite puzzled. I am currently charging the car on a battery tender that i borrowed from my buddy, gonna leave that on for couple of hours and maybe it IS a flat battery and thats it. Anyone can chime in will be awesome! Thanks! Edit* Checked battery voltage - at a very healthy 12.6V... >_<||| Edit again* Had the charger charged for 3 hours, tried to start again. Same thing, starter starts - but engine doesnt turn over. Weird thing is, the clock resetted again to 0:00. Do you guys think its a good idea to try to push start the car? (its a 6MT). Or should i just get it towed to the shop to check out? any idea whats wrong? Thanks!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon Last edited by kaede; 05-07-2016 at 10:36 AM.. |
02-10-2016, 06:14 AM | #2 | |
Rep 35
I store my car for the winter too. Now my car is still sleeping, but last year, I had a similar problem. But I tried it twice and than the engine fired up. It was a problem with fuel, because when the car stands for few weeks or month, the sludge falls to the bottom of tank. It could be a problem with fuel pump. Last edited by M-power CZ; 02-10-2016 at 06:20 AM.. |
02-10-2016, 12:23 PM | #3 | |
Rep 734
I did a and i saw someone had similar situation and it ended up being a fuse, will be checking all of them later tonight.
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
02-10-2016, 01:16 PM | #4 | ||
Rep 35
02-10-2016, 01:48 PM | #5 | |
Rep 734
As far as sludge in the fuel, i definitely agree that there will be impurities, but probably not what we'd associate with "sludge." Again, not an expert either on this field ALSO, your English is perfect! Thanks!! I have read many threads on M3 not starting here on m3post, most of the time other member's car completely dies, in my case, the starter is trying to start the engine but the engine doesn't budge. I dont think my engine seized (HOPE NOT). I don't have a ODB reader as well, so can't really pull codes. From what i have read though, other members have had success in replacing fuses and something to do with the crank sensor. Can't check the sensor but can definitely fiddle with the fuses to see if one of them went out. Any other people that can comment? Much appreciated! Thanks!
02-10-2016, 03:35 PM | #7 | |
Rep 734
Sure hope that is NOT the reason why... and IF it is, hopefully they didnt cause a LOT of costly damages.
02-10-2016, 07:08 PM | #8 |
Rep 1,389
Drives: 2012 E92 M3
When you say "the starter will try to fire it" do you mean you can hear the starter clicking but the engine does not crank?
Just cause the battery is reading 12.6V and lights and everything else is working, it doesn't mean the voltage is not dropping hard when you try to start it. Check the voltage while you are trying to start and see if its dropping a lot. I've seen a battery check out at 12+ volts and then when cranking go down to like 6-7 volts. Needless to say, I had to replace it. Also, starting the car every couple of weeks and bringing it up to temp is not enough to keep the battery charged. You have to keep it on a tender or drive it for a while to keep it charged. I stored my 330 every winter for 9 years and I was not able to keep it on a tender. I tried to take it out every 2 -3 weeks for about 30 or more. Last year the winter was really bad and I was not able to do that and ended up having to replace the battery in the spring. I did get 9 years out of the original battery so I guess that wasn't too bad. I'm trying to do the same thing with my M3 but have only been able to drive it 2 times since November and the last time i took it out I got the low battery warning.
12 M3 Interlagos Blue/Black
18 Jeep Grand Cherokee (Yeah, it's got a HEMI) 21 X3 Silver/Black(Wife's) 06 330i Monaco Blue/Black (retired) 02 X5 3.0 Topaz Blue/Black (retired) Last edited by Mr. BMW; 02-10-2016 at 07:17 PM.. |
02-10-2016, 08:08 PM | #9 | |
Rep 734
Also, if the battery is indeed just dead, wouldnt jumping the vehicle worked then? I am not sure. Hopefully it is just the battery, i am getting it towed to the shop tomorrow. Needed to get the Throttle body actuators replaced anyways + possibly replacing the Valve Cover Gaskets since the passenger side seems to be seeping. Wonder how much a new battery costs?
02-11-2016, 02:00 AM | #10 | |
Rep 35
But this is a different topic. I hope you will solve the problem soon. Let me know what was the problem. I cross my fingers!! |
02-11-2016, 02:18 AM | #11 | |
Rep 35
02-11-2016, 03:46 AM | #12 | |
Rep 734
I've arranged to get it towed to a reputable Indy shop where I was gonna get my throttle body actuators replaced anyways. Will update on here to let you guys know what's wrong. Hopefully nothing costly. Cheers ! Thank you everyone! |
02-11-2016, 01:00 PM | #13 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
With AGM batteries in particular (but it can happen with any battery), the battery gets to an age where it seems to charge fine on a tender (and displays normal voltage), but the ability to source any significant cold cranking current can suddenly fall off. So the car will turn on fine, the starter will engage and attempt to spin the engine, but nothing happens because the battery has high internal resistance and can't deliver current. The battery has gone south...
02-11-2016, 02:10 PM | #14 | |
Rep 734
Car is in the shop at the moment, haven't heard anything back yet. Fingers crossed.
02-11-2016, 10:03 PM | #15 |
Rep 734
Update: My mechanic didn't have enough time to look at the cause thoroughly today, but what he told me is that there seems to be no compression, and no fuel feeding to the engine.
Any thoughts as to what went? Maybe the fuel pump relay (heard that it is a semi common problem with the m3), and or some other electrical problems causing the fuel pump not to work? Or maybe the fuel pump died? Or maybe as someone mentioned above, sludge in the oil?!?????? (seriously, dont think thats the issue, but not ruling anything out as of this moment ><!!) Thanks guys!
02-12-2016, 01:26 AM | #16 | |
Rep 35
I don't think so, that the fuel pump died or it's a electrical problem. I still think, that the fuel system is blocked. But may be I'm wrong. Hope that they solve the problem today with minimal costs. I cross my fingers!! |
02-12-2016, 07:13 AM | #17 | |
Rep 1,256
Your story is contradictory now. Before you said the car didn't crank. If the car doesn't crank, then of course there won't be compression or fuel. |
02-12-2016, 08:14 PM | #18 |
Rep 2,442
Drives: 2022 M3 6MT
I wrote a very detailed post about how to properly store your car for winter. I've stored it now for several years without issue, and you can search the forum for my thread, but basically:
Fill the car up and use fuel stabilizer. You really need it on a tender. Starting the car periodically only makes it worse. You increase cold starts and wear on the motor. These cars have alternators that only charge the battery when coasting, so try charging it for a good few days and give it a go.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
02-14-2016, 08:45 AM | #19 |
Rep 2,301
In related news, I just changed my starter on my '09 with 125K miles. Car would sometimes not crank, until after a few tries. Would give a click, and then nothing! Very scary. Luckily this is one part that lets you know it's time without stranding you. But thanks BMW for burring it deep in there. Four hour labor job.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
02-14-2016, 08:54 AM | #20 | |
Rep 1,275
This. Stored my 2009 E93 for three winters and never had an issue with it in the spring.
2022 M4 Competition ConvertibleDravit / Tartufo Full / Carbon Fiber Exterior...loaded
2020 X5:MW/Coffee Extended Merino, M Sport, B&W....loaded 2007 X3: Sapphire Black / Black loaded 6 speed Gone: M3 E93 Silverstone II over Bamboo |
02-15-2016, 04:48 PM | #21 |
Rep 734
Update!
Car is fixed and up and running! Apparently the both Throttle Body Actuators DIED off completely and it wont allow the engine to start. After replacing both banks, the car fired up no problem at all! Checked the battery and it is in good shape as well. So glad that's the only thing that's wrong, was prepared to replace them anyways after hibernation. Sadly, according to my mechanic, there ARE traces of rodents!!! Q____Q||| He said there were some nuts and he vacummed it up. Also left a bit of a mess on the bottom of the engine bay. Question, I have never ventured below the M3 besides changing oil, is there a belly pan that i can remove to clean and wipe down the engine bay's bottom side? Will like to have it cleaned out to my best abilities. Thanks!
02-15-2016, 06:33 PM | #22 |
Woof!
352
Rep 1,323
Attached to the engine itself there is a metal pan that is easy to remove.
Once, while riding in a friend's hotrod show car, we started smelling an odor like burning paper. It turned out that a nest of shredded paper was down in the header collector pipes! We saw part of it drop onto the road in the rearview mirror looking like a rolling fireball. |
