10-21-2016, 09:25 AM | #1 |
Rep 110
Limp mode at 45k miles...HELP
have any of you had these codes show up after going into limp mode? 2011 DCT.
It's at the shop for several days now and would appreciate any help. I've already researched and I've come up with a few things like Vacuum brake booster, idle control valve/ controller, the hose connecting the intake manifold and controller could be deteriorating and causing small leak? Lastly...... A tuner/code shop guy said could be a "voltage" problem. I don't even know what that means. Any help is appreciated. |
10-22-2016, 10:06 PM | #2 | |
Rep 412
If the issue turns out not to be battery or battery cable related, code 2B0D often appears for the "Idle Control Valve" or "Idle Control Device" discussed in this thread here and in this thread here. If it is the Idle Control Device, BMW just extended the warranty for this part to 10 years/120,000 miles discussed in this thread here, so that would be a free fix at the BMW dealer. Last edited by Theodore; 10-22-2016 at 10:25 PM.. |
11-04-2016, 09:08 PM | #3 | ||
Rep 110
It ended up being the throttle actuators after all this!!!!!
Part is Covered under emissions at BMW |
12-01-2016, 11:41 PM | #5 |
Rep 110
27E4
01-01-2017, 04:25 AM | #6 |
Rep 683
