06-30-2013, 12:21 PM | #1 |
Rep 6
Fault Codes 27B1 and 274A, help please
Been having the same increased emission light coming on, it stays off once I clear it but sometimes a week later, or a month later it kicks again. The 2 below are the same faults I keep getting.
274A Lambda probe pump current synchronisation error before cat Bank 1 Error will cause a warning light Error is not currently present Test conditions have been completed Timeout 27B1 Secondary air system throughput bank 2 Error will cause a warning light Error is not currently present Test conditions have been completed Timeout It's also logged a 27AB and 2729 once over the past year. Primarly 27B1 and 274A. I'm stationed in Italy so the dealer isn't much help. Hoping someone can point me in a direction. yes, my car is off warranty. |
07-01-2013, 07:01 AM | #2 | |
Dingleberries
76
Rep 1,246
02-26-2019, 02:05 PM | #3 |
Rep 47
Have the same codes. Just pulled my oxygen sensor out on the right side and its black as night. was going to start screwing with the air pump but seeing this oxygen sensor come out so black makes me thinks the nose is not working right.
03-28-2023, 02:56 PM | #4 |
Rep 49
Drives: E46 & E90
bigmac102377 Resurrecting this old thread. I am having the same error codes. Did you find out what the issue was and solution?
'Brunhilda'
'04 E46 M3 6sp Vert 'Khaleesi' '11 E90 M3 DCT ZCP |
Tags |
emission, engine light, faults |
