Steve Thomas BMW
      05-31-2011, 12:09 AM   #1
Totti
Troll
Totti's Avatar
Italy
47
Drives: 2011 E92 M3
Tinting and automatic window roll down.
Hi guys,
What happens regarding this process? I thought you weren't supposed to roll down windows for a set period of time after tinting, but my BMW automatically drops the windows slightly when you open the doors.
Any way to disable? Or is it a non-issue.
BMW E92 M3 Coupe | Jerez Black | Fox Red Extended / Carbon Black Trim| Fully Loaded | Moonroof | 6MT | Gintani Sport
Originally Posted by ES_TRADER
Use the stick like u would a manual. If that doesn't work, put it in D mode and put both hands at 10 and 2. If that doesn't work, just sit on your right hand.
      05-31-2011, 12:14 AM   #2
mot
Drives: e92 AW M3 6MT
Originally Posted by Totti View Post
Hi guys,
      05-31-2011, 12:37 AM   #3
goto35
Drives: e46 m3 e92 m3
non issue just dont roll is all the way down
E92 coupe Premium/Cold Weather/Ipod/Lojack/Tint
      05-31-2011, 01:48 AM   #4
KIS
KIS's Avatar
Drives: 2015 Jaguar F Type R
Non issue, but limit getting in and out of the car for 24 hours.
      05-31-2011, 01:49 AM   #5
elp_jc
Drives: .
I'd say the window rubbing against the semi-hard rubber when closing the door is more dangerous than lowering the window even all the way down. Any decent tint job should extend the film below the window seal inside the door, so lowering the window is no longer an issue. If you lower the window all the way down, and the top of the window gets below this seal, the danger again is at the top of the film, when raising the window.
Anyway, what I did was not close the door completely (just first click, which doesn't raise the window) after the job was done for a couple of days, but it's not my DD. I'd leave it like that for a day, or at least the afternoon and night, and everything should be fine, especially now that's warm. Good luck.
      05-31-2011, 07:39 AM   #6
Totti
Troll
Totti's Avatar
Italy
47
Drives: 2011 E92 M3
Thanks guys.
      05-31-2011, 10:03 AM   #7
quadpipes
Drives: '11 E92 M3 IB,'16 F22 M235i EB
Hi guys,
A good tint shop will trick the car into thinking the doors are closed so the windows will be all the way up. I watched mine do it at the latch.
      06-01-2011, 08:20 PM   #8
Totti
Troll
Totti's Avatar
Italy
47
Drives: 2011 E92 M3
Ahh good point. Because the windows will be slightly down when the tinter opens the car, will they know to automatically account for this?
      06-01-2011, 08:27 PM   #9
elp_jc
Drives: .
That's a given, to slide the tint as low as possible without removing anything, but can't close the door like that. Again, the tint at the bottom of the window is not an issue when the job is done properly. Problem is at the top. And remember to 'open' the door so the window lowers before closing door. I left mine half-closed overnight, so window didn't roll up against the tint.
Search this Thread:
Advanced Search
