BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      07-17-2023, 01:50 PM   #1
AshwinLB
Drives: 2008 BMW 135i 6MT
AshwinLB's N54 135i 6MT Sparkling Graphite Metallic Build Thread
Hi all,
I've been meaning to start a build thread for my 2008 BMW 135i 6MT with a Sparkling Graphite Metallic exterior and Oyster interior.
Bought at 145,000 KM, and currently sits at 175,000 km. I've had the car since October 2020, which replaced my previous 2010 135i 6AT that I had for 3 years prior.
I will be backlogging start writing posts for each mod, so let's see how far I can go haha.
Here's the mod list so far:
(In Order of Installation, excludes maintenance items)
  • BMS Boost Side Oil Catch Can
  • BMS Vacuum Side Oil Catch Can
  • BMS Dual Cone Intakes
  • ER Chargepipe with HKS SSQ4 BOV
  • NGK 97969 Spark Plugs (0.022” Gap)
  • OEM Euro-Spec Blackline Tail Lights
  • Redline D4 ATF Transmission Flush
  • Teyes CC3 6GB Android Headunit
  • Rogue Engineering Solid Rubber Transmission Mounts
  • MMP 3” Downpipes
  • Genuine BMW Alarm System
  • Turner Vacuum Canister Relocation Bracket
  • Black M2 Kidney Grills
  • Apex 75mm Stud Conversion Kit
  • VRSF 7.5” Competition HD Intercooler
  • MHD Stage 2+ Tune
  • GTA Retrofits Custom-Built Headlights
  • Uro Aluminum Power Steering Pulley
  • eBay Crankseal Plate
  • Apex Wheels - 18x8.5et45, 18x9.5et58
  • General G-Max RS - 235/40R18, 265/35R18
  • BMS Black Cowl Filters
  • N20 3.5 Bar MAP Sensor
  • Nexsys B58 Coilpack Conversion (Eldor-branded)
  • PSM Carbon Fibre Trunk Spoiler
  • Plugged Headports
  • OEM Valve Cover (to retain cyclonic oil separators)
  • VTT Oil Cap Breather
  • VTT Billet Motor Mount Inserts
  • MaLo Billet Oil Filter Cap
  • Hydra Performance Cowl Filter Covers
  • MFactory Helical LSD w/ 3.46 Ratio
  • OEM Differential Bushings
  • NRW E82 Street Sunroof Delete
  • RTD v4 Carbon Chassis Mount Shifter
  • BMS Differential Support Brace
  • E9x M3 Steering Rack
  • E9x M3 Steering Shaft
  • OEM Tie Rods (135i spec)
  • Megan Racing Rear Toe Arms
  • Seals-It Rod End Boots
  • SPL Eccentric Toe Delete Kit
  • Morimoto XB 6000k Headlight Bulbs
  • Monroe 907984 Rear Upper Shock Mounts
  • Style 436M M235i Winter Wheels (OEM E9x 18” don’t fit with F8x calipers)
  • Continental VikingContact7 225/40R18
  • F8x Front Calipers with 370mm Rotors
  • Euro-Spec Under Dash Oddments Tray
  • Condor Speed Shop Solid UHMW Rear Subframe Bushings
  • Zimmermann Rear Blank Rotors
  • EBC Red Rear Brake Pads
  • UUC Stainless Steel Brake Lines (6)
  • Motul DOT 5.1 Brake Fluid
  • Clutch Delay Valve Delete
  • BMS Billet Vacuum Canisters (in relocated location with Turner bracket)
  • Seibon OEM-Style Carbon Fibre Hood
  • E9x M3 200N Hood Struts
  • E9x M3 Chassis Stiffening Plate
Suprgnat2317.00
Fishee1002.50
Afam28298.00
      07-17-2023, 03:30 PM   #2
WrathOTM
WrathOTM's Avatar
547
Drives: BMW 128i
That is a thorough list of mods. Very nice!
Mods to date: The list grows...
      08-10-2023, 09:31 AM   #3
Steve 1993
Drives: bmw m3 2017
Originally Posted by AshwinLB View Post
Hi all,
192.168.100.1 192.168.1.1
  • MMP 3” Downpipes
  • MHD Stage 2+ Tune
  • Plugged Headports
Attachment 3230923
Nice plan to start on a great ride ! best of luck
1addicts
