BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      09-20-2021, 10:00 AM   #1
Kisenwether
Drives: Limerock Grey M3 / Hellrot 1M
Over the last year or so I had become more and more interested in the 1M. I have had my e92 M3 for 8 years now and always was interested in the 1M as its basically just a smaller version minus the S65.
I started to read and do my research on doing a conversion from a 135 to 1M. As the prices of the 1M are getting higher and higher. I thought to myself if I bought a real 1M I would have a hard time modifying the car. I have a bad case of mod everything. I grew up in my fathers business of auto repair/body. In fact my e92 M3 is salvage title and I was able to do a father son project with him in 2013 on that car. After figuring I could convert a 135 to 1M for a lot cheaper and also viewed it as a time to go back to my dads business and do another project I started to get all the parts in order. I was able to order most of the body panels new and brackets/hardware required for the cosmetic conversion. The hardest part was the rear quarters, I wanted OEM. I know a guy makes fiberglass rear flares but I wanted it done with OEM metal panel. So i started that search and got extremely lucky a member not far from my fathers business (2 hrs) had a set in storage for 3 years and decided to sell. So i jumped on that and then had all the OEM body panels I wanted. I then decided to add a carbon fiber roof as the car had a sunroof. I went with RKP 2x2 Carbon fiber roof.
As far as the suspension I was able to find a full rear subframe drop out from a e92 m3. I bought a single piece aluminum driveshaft to adapt from n54 6mt to m3 diff. Reason for this is the manual transmission on the 1M is not that same length as the n54 transmission which makes the OEM 1M driveshaft not an option. I also picked up all new parts for the front suspension.
As far what color to paint the car, I was between a red or blue. I'm not the biggest fan of most reds but wanted to keep it OEM BMW color. So after looking at some red and blues I decided to go old school and do a none metallic color with Hellrot Red. Just for reference my e92 M3 is painted Limerock Grey Metallic. I don't like wraps and also like to have special colors.
Part way into the project I also decided to add e92 m3 seats. I found out they are almost identical outside of foam and seat material. Once I got my seats i saw the wiring was a little different so I swapped the seat harness and it was all plug and play with no errors in the car.
With currently living in New Mexico and my fathers business is in PA I decided to drive the car back 2,000 miles over 2 days and got started on the project. From start to finish this took us 16 days. I did about 85% of the work myself and the remaining 15% from my father. He mainly helped with the rear quarter removal and install along with the paint. I handled mostly everything else. He helped as much as he could but he also had a business to keep running. I worked on average about 12-14 hour days on the car.
UPDATE 10-8-23
Exterior:
-Front Lip Slek Style carbon 2x2
-Custom made carbon 2x2 rock guards for front wheels (was picking up rocks and hitting rear quarters)
-Custom made carbon 2x2 slim side skirt
-RKP 2x2 roof panel
-RZ style Carbon 2x2 Rear diffuser
-Genuine BMW Motorsports M2 CS-R wing in gloss carbon and gloss black uprights. (Bolts in like factory m2 cs-r car with minor mods)
-IND Gloss Black Front Grills
-IND Gloss Black Fender Markers with Light Tint lights
-IND Gloss Black M badge
-Gloss Black front and rear BMW emblems
Headlights:
-Carbon switchback eyelid - BavGruppe Designs
-LED halos - BavGruppe Designs
-Blacked out headlight
-Clear side marker lense
Wheels:
-Front: Apex EC-7 18x9.5 ET 22 with Toyo R888R 265/35/18 with silver center cap
-Rear: Apex EC-7 18x10.5 ET 22 with Toyo R888R 295/30/18 with silver center cap
-HR lowering springs front and rear
-Motorsport Hardware studs - 68mm studs with silver lug nuts front and rear
Brakes:
-Front - Maserati Brembo caliper convert to fit OEM 1M rotor - Designed and machined by myself
-Rear - Porsche Brembo caliper convert to fit OEM 1M rotor - Designed and machined by myself
-All runner brake lines replaced with Stainless steel
Interior:
-Coby Wheel - Gauge cluster dome in black Alcantara with grey stitch
-Coby Wheel - Dash trim
-Coby Wheel - Shift Boot
-Coby Wheel - E-Brake boot
-Door handles wraped in black Alcantara
-Door panels replaced with Grey Alcantara
-Center Console trim wrapped in Alcantara
-Gauge Lower trim wrapped in Alcantara
-Recaro Sporters GT - Grey Alcantara with Black Vinyl
-Recaro sliders
-Custom brackets to center seats - Designed and machine by me.
-Weight ZHP shift knob
-3D design ebrake handle
-OEM electric steering wheel
-Bimmerworld Aluminum Pedel set
-Venoxy 1M gauge replacement
-Element 50 Fire Extinguisher
-OEM Arm rest delete kit
-P3 Analog boost gauge installed in AC vent
-SW motorsports half cage finished in satin grey. (Bolt in cage, company is based in UK)
-Rear seat delete panels finished in OEM matched carpet - Designed and made by me.
-Black suede headliner and A,B,C pillars
Engine/Drivetrain:
-Speedtech Bottom mount single turbo kit with recirculating dump
-Garret GTX30756-R with T-51R mod
-Mac Solenoid with stainless AN lines
-7.5 inch Stepped intercool
-335D charge pipe
-335D relocated coolant reservoir
-335D relocated Power steering reservoir
-M3 OEM cowl conversion
-Titanium hardware all throughout engine bay
-Paint matched Engine cover
-Tial blow off valve
-BMS intake with 750cc port injectors
-Phenolic spacer for intake manifold for heat transfer reduction
-Fuel-it Flex fuel analyzer
-BMS methanol dual nozzle kit (only using to reduction IAT)
-BMS Methanol Tank 1.25 gallon tank installed in trunk
-JB4 with MHD
-JB4 Port Controller
-JB4 Meth controller
-JB4 Anti-Lag
-JB4 2-Step
-Tune by DocVu running full E85
-Custom YFCM Carbon driveshaft (first one for 1m conversion)
-Rogue Engineering Delrin Shifter bushings
-Tuner Motorsports rear shifter bushing
-OEM Muffler with custom OEM vacuum exhaust valve and 90mm stainless exhaust tips
Appreciate 13
      09-20-2021, 10:05 AM   #2
Kisenwether
rjeserved
Appreciate 7
Fakemike369.50
Petro135452.50
bobowar1353479.00
overcoil3075.50
Afam28298.00
BMWWorld234.50
jsigone90.00
      09-20-2021, 02:29 PM   #3
asbrr
Drives: 2014 335ix M-Sport
Hellrot looks STUNNING on your car. Bravo
      09-21-2021, 07:55 AM   #4
Petro135
Drives: 2008 135i E88
2008 BMW 135i  [0.00]
Beautiful... Nice job!!!
      09-21-2021, 03:07 PM   #5
drwillb
BMW Fan
drwillb's Avatar
Drives: e30 M3, e30 M3, e46 M3
Outstanding. Glad to see the parts reaching their full potential.
2012 135i Mods: air scoops, CP, K&N filter, PS1, ADE FMIC, BMW PE, JB4, 1M front body, full M3 suspension front and rear, M3 brakes front and rear, M3 rear subframe and LSD
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i
      09-21-2021, 04:01 PM   #6
Kisenwether
Thanks again for the parts! So glad i went the OEM route for the rear quarters, was more expensive but in my eyes the right way to do it.
      09-22-2021, 08:49 PM   #7
Dbelveal
Drives: 2019 M2C, 2008 E90 M3
2019 BMW M2C  [10.00]
2008 BMW M3  [0.00]
This things looks awesome! Can you tell me more about your driveshaft modification? I also have the N54 6MT transmission and I was trying to figure out if the slack could be taken up in the center carrier without modifying a 1M factory driveshaft.
      09-23-2021, 02:23 AM   #8
CharsadehBEAST
Drives: Minivan
GOALS! Absoltely stunning and will be a true 1 of 1
Are those aftermarket 1m side mirror caps, factory caps or did you buy the whole 1M OEM assembly?
      09-23-2021, 09:02 AM   #9
Kisenwether
I went with a whole new setup from Seems Legit Garage, he makes adapter plates one for the transmission side and one for m3 diff side. The adapters convert it from BMW bolt pattern to a standard 4 bolt driveshaft. The driveshaft itself is a 1 piece aluminum shaft.
This photo was just a mock up to check everything, yes its missing a bolt, yes its not flat to diff. This was just at test fit to check length and bolt alignment.
overcoil3075.50
selbyp93163.50
      09-23-2021, 09:03 AM   #10
Kisenwether
They are oem 1m mirror assemblies. They didn't have the exact ones to match my options of the car (none in US or Germany with no ETA of restock) so I got as close as i could and swapped some electronics inside the mirror housing.
      09-23-2021, 07:53 PM   #11
Dbelveal
2008 BMW M3  [0.00]
Thanks for the lead on the aftermarket driveshaft! Seems like a much simpler solution.
      09-26-2021, 09:04 AM   #12
MN.BIMMER
No Cop No Stop
MN.BIMMER's Avatar
Drives: 2012 BMW 135i
Wow, looks absolutely stunning. Keep that thing forever!
Current Garage!
2012 BMW 135i - 6MT w/ OEM 550i clutch & MFactory LWFW, Pure Stage 1, MFactory LSD, VRSF Catless Downpipe, JB4 w/ MHD BEF
      10-03-2021, 12:45 PM   #13
e80two
self-admitted lurker
e80two's Avatar
Drives: 135i
CF roof ftw!
      10-14-2021, 11:09 AM   #14
Yeineken
Yeineken's Avatar
Drives: '11 135i M Sport
'11 135i  [8.20]
'16 Ford Hatchback  [0.00]
'15 X5  [10.00]
Beautiful build.
      10-15-2021, 07:48 PM   #15
Gray_Panther
Gray_Panther's Avatar
1555
Drives: 128i
Amazing build! I love it!
2012 BMW 128i 6MT Deep Sea Blue Metallic
      10-20-2021, 04:23 AM   #16
willin11
Drives: F87 M2
Whoaaa that's a whole beast mode right there. Love it man!
      10-27-2021, 10:08 AM   #17
Yeee82
Drives: A Vehicle
subbed for sure. Keep it up.
      11-07-2021, 01:12 PM   #18
Kisenwether
Brakes are done, some photos added to oringal post.
      11-10-2021, 09:30 AM   #19
wootloops
wootloops's Avatar
356
Drives: 2013 E92 M3 Lime Rock Park
This has to be one of the best looking E82s I've ever seen
      11-11-2021, 09:44 PM   #20
Kisenwether
Appreciate it, but still more to come for this! Just going at it slowly.
      11-12-2021, 12:50 PM   #21
gringoloco
Drives: BMW 135i
It’s a beauty!
      12-03-2021, 12:20 AM   #22
71velle
71velle's Avatar
11
Drives: f30 bmw
great build. now sell me the e92 since to get it back with the e46.
btw thank you that car has been great.
1addicts
