06-10-2014, 12:54 AM | #1 |
Rep 3,742
Square vs. staggered setup for track
Looking to get a set of track wheels and assumed I'd get a square setup. But a few very excellent drivers whom I respect immensely seem to prefer a staggered setup and have me reconsidering.
My impression is that a square setup reduces understeer and therefore makes the car more tail happy which would seem to make the car navigate better around tighter, twistier tracks. The downside is that it might be less stable at speed and more prone to have the tail come around on you. By contrast, it's my impression that the staggered setup would be a little more stable at speed and less prone to having the back come around on you. Handling aside, the obvious advantage of the staggered setup is being able to rotate tires. I thought I'd get some more feedback opinions on the subject. I'm particularly interested in people who tried one and went to the other and can therefore provide a comparison. Note that I will be running camber plates and coil overs, so the suspension will be pretty well dialed. Not sure if this negates some of the effect of the understeer inherent in a staggered setup. |
06-10-2014, 01:39 AM | #2 |
Rep 9,032
Just keep in mind this car doesn't understeer like the E46 did. Staggard is probably better for ultimate balance, but square just makes so much more sense. My buddy with an E46 runs square and he just brings one extra wheel to track events in case he gets a nail or flat while driving to the track. I have my full set of street whees in the back seat while, or vise versa if I drive up a day early. It's a pain to load the wheels.
06-10-2014, 08:41 AM | #3 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
My philosophy. Don't reduce grip in favor of achieving a balanced handling.
Say, if the only way to go full squared means you'll have to run skinnier tires in the rear due to clearance issues, then it makes no sense to run squared, since it's easier for the driver to adapt to the difference in grip between the front and the back. However, the E9X seems to be able to accommodate very wide tires up front, unlike it's predecessors. So if the current setup can accommodate square setup without giving up grip in the rear to do so, squared setup does have it's advantages. Having said that, unless you fall within that tiny sliver of drivers who can expertly keep their tires at the optimum slip angle as described by billj747 here in this forum, obsessing over staggered vs squared has little real world applications.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
06-10-2014, 09:06 AM | #4 | |
11817
Rep 23,187
06-10-2014, 09:30 AM | #5 |
Rep 542
I'm thinking abt running square tire sizes on my stock ZCP rims for track duty--probably 265s. Not too big for front rim width & ability to swap @ tire shop after a few DEs.
Although, I would give up some slight understeer tendency to have a more stable car @ the limits--since I'm there every lap (except the warmup) lol. Like the OP, I'd like to hear from advanced/instructor level drivers on the square setups, that have gone that route.
* '11 E71 X6 M MCB
* '16 Z51 M7 C7 Corvette--SCCA Solo/DE Weapon * '90 Corvette ZR-1 (Fast) |
06-10-2014, 09:54 AM | #6 |
Rep 284
Drives: '13 Melbourne Red E92
Debate Input
OP - Went through this exact debate through the winter and was on the fence until I ultimately pulled the trigger on a staggered set for track and autocross. My body of work (switching from OE) is only two events so far (3 hours of track time, 12 AutoX runs) but I've been very happy with the results.
Can't help you on the square comparison having not had it since my E46 days, but like you are hearing, I relied on the advice of those with greater experience in the E92. Key points were the fact that staggered is the way most race teams go, the "tail happy" point, giving up some on AutoX in return for a better track car where I hope to spend more time. Just on the math so far this season, that's borne out - 3 hours vs. about 12 minutes. Finally, tires are way less expensive that body work. Reducing the chance of the "big one" while I get more comfortable at the limits in a staggered setup was important. |
06-10-2014, 10:53 AM | #7 |
Rep 106
I went with square apex 10" with 275/35 nitto01 setup and much prefer the
balance over staggered. Dials out the push and makes it much easier to rotate the car through the corner with slip angle. I don't find it too tail happy or unstable at higher speeds. In fact I like the square 18 setup so much that I'm thinking to sell my oem comp 19" wheels to get a new set of street wheels to run square all the time. It's really a driving style preference, talked to advanced drivers from both camps. I started out learning with staggered which was probably helpful. Recommend you try both at some stage. Axis
_____________________________
2001 E46 Race Car - S54 Swap - Moton Suspension - CAE Shifter 2011 E90 M3 - ESS VT2-625 Supercharger - Stoptech Trophy BBK - Ohlins Road & Track - MP Exhaust |
06-10-2014, 10:55 AM | #8 |
Rep 1,711
I prefer staggered set up for e9x m3. As someone mentioned, these cars dont understeer like e46, and you can dial understeer completely out with c.plates and coilovers. On the other hand, you should always fit widest tires possible in the back for altimate rear grip. You dont want your car loose in 90+ mile corners.
06-10-2014, 12:12 PM | #9 |
Rep 6,734
I have not tested a square wheel/tire set but I have also not felt the need. I always run 275's in the front and I have ran 285's and 295's in the rear. Tires are certainly a big component to handling but, as others have stated, there are other factors. I noticed some understeer on certain corners with my Hankook RS3 275/285 tires on the track. I added a Mode Carbon GT4 front splitter (awesome product BTW) and went to 275/295 BF Goodrich G-Force Rivals. I didn't experience any understeer with the new set-up. It could be attributed to better tires with more ultimate grip (maybe I wasn't reaching the top end of the front grip threshold with the Rivals) and the added front downforce from the splitter. I will soon be adding a Mode Carbon GTS rear wing. I will be curious to see if the added rear downforce from the wing results in a re-introduction of understeer at the limit.
I understand the motivation to run a square set for the ability to rotate tires but I have found that as long as I keep the front to rear stagger equal to or less than 20mm then there isn't a huge amount of understeer. Bear in mind that I'm a decent driver but certainly not putting down top lap times. More experienced drivers may see things differently.
'23 X7
06-10-2014, 01:06 PM | #10 |
Rep 542
Even drivers that put a race suit on for a living all want the same thing as we do in a car--confidence...
If a car is too loose & nervous approaching the limit, then any help, that grants extra rotation, will still (in most cases) end up w/ slower lap times than a car w/ very mild push, that can be driven more comfortably @ the limit. Randy Pobst will preach this all day long--and look @ his creds ;-) |
06-10-2014, 01:32 PM | #11 |
Rep 3,742
Thanks for the replies everyone. I really appreciate it. It looks like there is no easy answer here.
To clarify, if I went with a square setup, it would likely be 18x10" w/ 275 tires. If I went staggered, I'd probably go 18x9.5 front and 18x10.5 rear. Not sure on tires, but either 265 front and 286 rear, or 275 up front and 295 in the rear. Either way, I'd maintain the 20 mm delta between front and rear. My impression even before I started this thread was that some of the people who advocate a square setup are also very much into autocross which, for whatever reason, I'm just not into. Perhaps it would make me a better drive on the track, but I just have a hard time getting excited about the idea. After reading the above and thinking about it, I am really leaning toward going with the staggered setup. Perhaps the most important thing for me is maintaining confidence in my car. Nothing would kill my enthusiasm faster than losing confidence in the car, be it the breaks or the handling. I am thus perhaps willing to give up the more neutral handling and ability to rotate tires of the square setup for the increased confidence of the staggered one. |
06-10-2014, 02:56 PM | #12 |
Rep 3,334
I have my M3 setup with a Dinan front sway bar and the alignment pins out for max negative front camber, toe at almost zero. It is setup like that for SCCA F-street class type autocross legality. For F-street competition, I have to run stock width wheels also, so while I have 275/35-18 BFG Rivals all around, they are mounted on 8.5/9.5 wheels...in other words a tad pinched up front, but they work fantastic. With the front bar, camber setting, and square Rivals, the car is very well balanced.
Last season, since the 275 Rivals weren't available, I ran 245/40s all around. Switching to the 275s all around, two things were immediately apparent: much better rear traction on track out from the apex and/or element; and noticeably improved braking especially from high speeds (90+). Not much of a surprise of course. I also have a set of 10x18 wheels with 275/35 NT-01s which I use a CCA events. The car by no means is too loose with my setup, likely due to the larger front bar which really helps in many ways including putting down power coming off tight turns/elements. On a totally stock M3, I could see the possibility of it being too loose with just changing to a square tire/wheel setup. I've not tried that combo, but it given how well my car is handling setup like it is (nicely controlled rotation with heavy trailbraking, still easy to rotate the tail with throttle as needed on track out, etc), it wouldn't surprise me that a stock car with just square wheels/tires isn't the best idea. FWIW, almost 40 years autox, 34 years track experience. I've run a square setup on my E39 M5 since it was new almost so long ago, but that car has a much more understeering balance than the E9x M3 not to mention an additional 400 lbs and 52/48 weight distribution. It transforms the handling the M5 beast (which comes stock with 8/9.5 245/275 setup). Tire rotation to extend wear life is hugely beneficial of course too. Regards, Chuck
Current Stable:
06-10-2014, 03:13 PM | #13 | |||
Havin' a blast!
125
Rep 4,847
I've run 70 track days with both staggered (in the beginning, mainly because I was using OE wheels) and eventually squared, and squared doesn't exhibit less handling that us non-pro's can detect. One thing to consider is, the wear rate on front tires at the track is substantially higher than that of rear tires (opposite of what happens on the streets). I would estimate at nearly 3-to-2 ratio - i.e. 3 sets of fronts for 2 sets of rears. Given that, being able to rotate the tires has a substantial economic advantage. Get into heavy amounts of tracking and you'll find out pretty quickly how the tire expenses become one of the biggest on-going expenses. Another thing to deduce from this wear rate is that the fronts do much more work than the rears. So, wouldn't we want as much meat on the front as possible?
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
06-10-2014, 03:18 PM | #14 |
Rep 1,679
06-10-2014, 11:30 PM | #15 | |
Rep 4,488
06-10-2014, 11:34 PM | #16 | |
Rep 4,488
And frankly, unless the OP is competing, if it turns out that square feels better or more fun even if staggered is faster, then there's a case to be made for square. HPDEs are about having fun, not setting records. And if square turns out to instill more driver confidence, then square could be faster for most people even if an absolute pro would be faster on staggered.
06-10-2014, 11:43 PM | #17 |
Rep 2,400
Have never run square so can't really speak to that, but run a staggered setup, but with an aggressive offset in the front 19 x 9 ET 20 (stock ZCP is ET31) and less aggressive in rear (19 x 10 ET 20 vs ZCP ET25). That 11mm difference in front felt like it dialed out 60%-70% of the understeer and car feels much better on track, so something to consider in terms of widening the actual track of the car without increasing tire size.
06-10-2014, 11:48 PM | #18 | |
Rep 4,488
06-10-2014, 11:48 PM | #19 |
Rep 328
hmmm i am thinking of running 255/40r17 squared next season for the track, the savings are huge over a 275/17 or 18inch setup, think 250 - 350 in savings.
And before people say 255 is too narrow, the c64 507 which is 250kg heavier then the M3 and much much more powerful uses 235f/255r tires. |
06-10-2014, 11:54 PM | #20 | |
Rep 1,711
06-11-2014, 07:15 AM | #21 | |
Rep 1,388
Even if a square setup offered absolutely NO handling advantage over staggered, I would STILL do it so I could move tires around to even out wear and prolong the life of the set. Whether you track a lot or you don't, if you're not a professional I think this aspect of the square setup alone should be enough to sway you in that direction.
E90 M3 Space/Fox/6MT
E92 335i BSM/Saddle/6MT - Sold |
06-11-2014, 08:06 AM | #22 | |
Rep 4,488
The ability to rotate tires (and running smaller tires in the rear) also saves cash, and less cash spent on tires means more to spend on track days.
