      04-01-2018, 04:16 PM   #1
Weyne Masters
Brazil
79
Drives: M3 LIME ROCK VT2-625
Custom Cans For FI
Iam looking for Custom Can for FI Engine.
      04-01-2018, 06:22 PM   #2
Visceral
Visceral's Avatar
363
Drives: E90 M track mule, cars n bikes
How do these mass-produced ones not fit the bill?
Shredicus529.00
tigermack474.50
6ixSpd6014.50
IMG1122.00
      04-01-2018, 07:40 PM   #3
Shredicus
Shredicus's Avatar
529
He needs thicker ones... for FI.
Maybe with the right kozy though...
Visceral363.00
      04-02-2018, 07:07 PM   #4
jcolley
Drives: 328
Having spent a few years looking at cams for the S65 and S85, I've not seen anything specific to an FI setup. For that matter, I've had a hard time even buying cam blanks to have them custom ground. For the S85 TT build I'm working towards, I'm just using Schrick street cams. They offer higher lift, but the increased duration really isn't as necessary.
Finding a tuner willing to work with them and optimize exhaust cam strategy is challenging on the OEM DME as many, many iterations of reflash are needed to find what works. This is more of a concern with a turbo than SC though as you're not trying to preserve spool with the SC.
      04-02-2018, 07:24 PM   #5
Weyne Masters
Brazil
79
Thanks for share your experience,
About ECU the car has Syvecs ECU,and it's easy to tunning(I mean it's possible to do it).
So Schrick has 2 option for S65 286 or 292.
Wich one you would.
Car engine Project
Carroll Rods H
JE Pistons 11:0
JE especial Pin's
Struds
Vortech V2-TI 18 lbs boost
Radium Fuel sistem
10 AN Fuel Rail
5 Walbros
2200 CC fuel injector
Progressive Nos
Headers long tubes.
And the main Fuel is METHANOL.
And we are looking to break 900 WHP
      04-02-2018, 07:51 PM   #6
jcolley
Drives: 328
Wich one you would.
Car engine Project
Carroll Rods H
JE Pistons 11:0
JE especial Pin's
Struds
Radium Fuel sistem
10 AN Fuel Rail
5 Walbros
Progressive Nos
Headers long tubes.
The Syvecs will make VANOS tuning far, far easier.
There is a 3rd set of Schrick cams that aren't talked about much, but made for solid lifters and removes the hydraulic lifters. If I were building the heads for a track focused motor, I would use stronger valves springs, dump the HVAs and go to solid cam followers, and look at bumping the revs up. I'm hoping to be able to use a larger intake valve on my project as well.
      04-02-2018, 07:54 PM   #7
Weyne Masters
Brazil
79
Wich one you would.
Car engine Project
Carroll Rods H
JE Pistons 11:0
JE especial Pin's
Struds
Radium Fuel sistem
10 AN Fuel Rail
5 Walbros
Progressive Nos
Headers long tubes.
Wich one you would.
Car engine Project
Carroll Rods H
JE Pistons 11:0
JE especial Pin's
Struds
Radium Fuel sistem
10 AN Fuel Rail
5 Walbros
Progressive Nos
Headers long tubes.
We are doing for DRaG Racing! And 1/2 mike Racing!
And off course Street application!
And we looking Tu bump the revs up 9000 RPM (Gear Box Limitation)
      04-03-2018, 01:46 AM   #8
OM VT3
OM VT3's Avatar
140
Drives: 2011 e92 zcp m3
If there was enough people interested in s65 we could split cost of the cams I know someone who would make them.... probably could get blanks made and you guys can do what you like
      04-03-2018, 07:06 AM   #9
deansbimmer
deansbimmer's Avatar
3751
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
I'd be interested in the custom cam grinder also. Right now all I have is a shop that welds the lobes on an OEM cam and regrinds them to spec.
      04-03-2018, 07:12 AM   #10
Weyne Masters
Brazil
79
Nice !
You have my support!
      04-03-2018, 05:29 PM   #11
///M3Fresh
Drives: E90 M3
Out of curiosity, what is the benefit gained from the extra 500rpm? You don't think you can get to the 900whp without cams?
2009 E90 M3 DCT IB Slick Top | 2017 911 Carrera White 7MT Slick Top | 2003.5 E46 M3 CB SMG | 2005 Audi A4 USP Black 6MT
