03-28-2018, 11:21 PM | #1 |
Rep 274
Having a little 'increased emissions / close gas cap' issue
Soo I seem to be getting a 'close gas cap' light when driving, which is later followed by an 'increased emissions' light after time / miles. I got a new gas cap & replaced the DTML pump. I am still getting 'close gas cap' message.. argh
My scanner reads a p0442 code which says 'small evap leak detected.' Do you guys think it may be the fuel breather valve? ( I did get bearings & spark plugs done recently.. thought id throw that in there ) M3's at 36k miles - pre-LCI Any advice would greatly be appreciated! (my smoke test didnt show any obvious leaks)
08 BMW E92 M3 - Silverstone II - DCT - Eisenmann - H&R - Macht Schnell
03-29-2018, 07:14 AM | #2 |
Rep 3,726
Drives: 2018 M2
The fuel breather doesn’t throw a code and when it goes its doesn’t leak it just stops sending fuel vapor to be used. Also you’d have symptoms like a bouncy idle or stalling. Did you clear the code when you put in the new cap?
///Master83.50 |
03-29-2018, 07:24 AM | #3 |
Rep 274
I cleared the code Saturday with my Autel Scanner and within 5 miles of driving 'close gas cap' illuminated again.. I'll have to drive the car to work today / tomorrow and see if i still get the 'increased emissions' after. And i don't have a bouncing idle.. What a headache
03-29-2018, 08:37 AM | #4 | |
Rep 3,726
Drives: 2018 M2
03-29-2018, 08:53 AM | #5 |
Rep 252
You mentioned clearing the code Saturday then driving the vehicle 5 miles.
Did the vehicle sit overnight and you drove the vehicle at a later date? The fuel level has to be at a specific level and ambient temperature has to be within a certain specification before the vehicle will run an evap leak test. If you drove right away that would lead to another issue causing a leak code not an actual leak. |
deansbimmer3750.50 ///Master83.50 |
03-29-2018, 09:15 AM | #6 | |
Rep 274
I haven't been driving the car much at all due to the weather.. But I drove the vehicle home which is about 15-17 miles after clearing the code, then parked it in the garage & havent driven since. (Gas cap open illuminated within 5 minutes of driving). Looks like I should keep driving to get the evap sys. to run then?
03-30-2018, 06:34 AM | #7 | |
Rep 290
03-30-2018, 06:36 AM | #8 | ||
Rep 274
03-30-2018, 09:49 AM | #9 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
the gas cap is pretty cheap, have you tried replacing it?
03-30-2018, 09:55 AM | #10 |
Rep 274
First thing I did was get a new gas cap
03-30-2018, 09:56 AM | #11 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
damn it. then it's either your charcoal cannister or the gas tank evap under the manifold towards the firewall. it's not that expensive and should take less than an hour.
just read your first post, sorry i recommended the gas cap. for some reason our cars had problems with the tank evap part. it's really easy to change.
03-30-2018, 09:58 AM | #12 |
Rep 274
thanks, Appreciate your input. I was wondering if my charcoal canister is ok.. I checked the fittings / smoke tested, seemed fine. Are you talking about the Fuel Tank Breather Valve or the Fuel Pressure Sensor?
03-30-2018, 10:00 AM | #13 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
i use to have the symptoms of the breather valve problem where my tank fill up would stop during the fill process. i would run race gas every once in a while and that would fix the issue. OR i would put a bottle of techron once or every other month.
///Master83.50 |
03-30-2018, 11:00 AM | #14 | |
Rep 3,726
Drives: 2018 M2
Patrón544.50 |
03-30-2018, 11:11 AM | #15 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
is it possible to clean the cannister?
03-30-2018, 12:10 PM | #16 |
Rep 3,726
Drives: 2018 M2
