05-08-2014, 11:55 AM | #1 |
My master volume goes to 11
59
Rep 467
Thoughts on Pennzoil Ultra 5W-40 or 10W-60 oil
Anyone try these? Any thoughts? I am due for a change. I searched the forum and Pennzoil is not mentioned much! The Ultra looks impressive and BMW is switching.
Car is 2009 with 26K miles. Daily driver in all weather in the northeast. No track. Work is only several minutes away so a ton of cold start miles! Thanks for the advice. I will be doing a Blacktone this change fwiw. No warranty as of now as well. So, stick with Castrol Edge Pro (not sure I ever had this stuff, it replaced the original TWS) or try Pennzoil in either 5W-40 or 10W-60. Or go to Mobil One 0W-40. The huge amount of cold start miles is what has me concerned. Oil has been changed every year (5K miles) like clockwork at the dealer. Thanks!
1987 Buick Grand National, 2009 BMW E90 M3, 2016 Audi S6, 2018 MB E63S AMG, currently in 2021 M5 Competition
05-08-2014, 12:04 PM | #2 |
Bad Lieutenant
232
Rep 3,517
I don't believe BMW is switching out TWS, but rather the other BMW-branded oils (5w-30, etc.)
05-08-2014, 12:11 PM | #3 |
Rep 1,381
Why don't you walk to work or take public transit? The way you drive your car is really the worst abuse you can do to it. Repetitive cold starts and short trips. Not enough time to charge the battery. Not enough time to heat up the oils in the car and boil off any moisture or acid forming. Way too much wear and tear.
Maybe you should use German Castrol 0w30 instead given your short trips and cold starts. You need the thinnest oil you can use since the engine remains cold for most of its operating life. |
05-08-2014, 12:18 PM | #4 | |
59
Rep 467
Suburbs and I work in a suit. Plus I am always running late. Car is easier, to be honest. I have gym stuff in my basement for working out.
My useage is why I am thinking the 0W-40 route may be appropriate. Appreciate the comments btw! Quote:
05-09-2014, 09:06 AM | #6 |
Stop the hate, get a V8
3850
Rep 8,625
BMW is switching to SOPUS (Shell/Pennzoil) for their private-label oil, that's all.
Pennzoil Ultra 5w40 is a great oil and is one of the only ones using their new GTL basestocks. I wouldn't hesitate to use it. It's one of the few oils that I feel can really compete with Mobil 1 0w40.
Past: 2011.5 M3 sedan ZCP |
05-09-2014, 02:33 PM | #8 | |
3850
Rep 8,625
You should not be letting a car sit there to warm up. Horrible for a whole slew of reasons. Just start it up, wait a moment for the RPMs to stabilize, and drive off slowly.
05-09-2014, 06:52 PM | #9 | ||
Rep 890
05-11-2014, 02:41 PM | #10 |
Rep 934
I combined PU 5W-40 with Ceratec to help with cold weather startups and wear. I just replaced the oil and sent it to Blackstone for analysis, I only had in for less than 1500 miles it but I was curious to see the additives and wear. I changed to Liqui Moly 10W-60 and the car feels different...it doesn't rev up as fast as before. I will definitely go back to PU 5W-40 after a few track sessions this summer.
05-12-2014, 02:08 AM | #11 | |
So Kewl Guy
49
Rep 619
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
05-24-2014, 07:48 AM | #12 |
59
Rep 467
Well, I am changing the oil and plugs today. Since summer is here, I am using the Edge Pro Castrol 10W-60. I'll get a Blackstone and see how things are. I can always pop in 0W-40 in the winter.
Hoping the plug swap is noticeable. Over 5 years of cold start beating on these.
04-04-2015, 01:11 PM | #13 | |
Rep 342
Drives: 2015 F85 X5M
EDIT: Nevermind, realized you were the same OP from the Ceratec post. Read your response there and it seems like you didn't have any problems with the 5w-40 and Ceratec? I'll have to consider this as an option. Ultra Euro 5w-40 is practically the same price as TWS.
