04-04-2009, 11:43 AM | #1 |
Rep 1,432
Exhaust Rattle
Hey Guys,
I have tried trying to single out the rattling on my car for a while now and its driving me nuts. I have an X-pipe and an ACS race muffler box. I started to have this problem after a long B-Road drive, plenty of high RPM load holding and shifts. It was an amazing drive. But after that day, I had an unusual noise. On cold start, I dont hear any of the rattling. But once its warmed up, I am experiencing some engine rattle noise at low RPMs. The sound is like metal vibration or tapping noise and it sounds like something is loose when accelerating. I've noticed when driving at a constant speed with the RPMs around 2000 in any of the gears for example in 3rd or 4th gear around 50 -60 km/hour and you apply the gas quickly there is a metal rattle noise until you reach 3000 RPM or more. The sound is not apparent if the revs are higher than 3000 RPM and applying the gas quickly and shifting at a higher RPM range. The sound is minimal if the gas is applied slowly from 2000 RPM and allowing the RPM to climb slowly. The M3’s are a higher revving engine but with acceleration at cruising speeds and low RPMS shouldn’t make such a noise? Should it? I tried checking my undercarriage, re-tightening and checking for clearances and all seems ok. Any ideas?? Thanks in advance guys!
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust| |
04-04-2009, 12:04 PM | #2 | |
Rep 1,061
2015 F82 YMB M4 (Feb 28th ED, re-deliveried on Apr 18th) |My 2015 YMB M4 ED Journal 2008 E92 SSII M3 Coupe (Sold) | My long gone 2008 E92 SSII M3 2002 E39 SG 530i (Gone) |
04-04-2009, 12:06 PM | #3 |
Rep 1,432
I have a slight drone but this is metallic clinging sound. Sounds something loose or hitting but cant figure out what it is. Checked it a few times but clearances look ok.
04-06-2009, 09:44 AM | #5 |
Rep 1,432
Do you have an xpipe??
04-06-2009, 11:17 AM | #6 | |
Rep 2,872
It sounded like I had a ring of 20 keys clipped onto something under the car but only when letting off the throttle quickly from higher RPMS Nice to hear the other x-pipe guys find this normal on their cars. I went down there, and nothing appeared to be loose |
04-06-2009, 12:03 PM | #7 | |
Rep 1,432
04-06-2009, 05:47 PM | #8 |
Rep 1,311
I'm probebly way off but have you looked with a bright light all around the exhaust pipes/muffler for any cracks? I wonder if after the pipes warm up enough and you start to excelerate through those lower rpm's as the vibrations will be lower frequency, if it's causing the metal to "jingle" then as the vibe's speed up, it cancels out the sound or at least drowns it out. Just an idea.
04-07-2009, 11:11 AM | #9 |
Rep 1,432
Fixed the problem!!! Its the brace holding the mid section. One of the screws was lose and when the exhaust warmed up, it was hitting the heat shield. Put in another washer there to further push the heatshield in and the sound is gone!!! Feels like I have a new car!!!!!!!!!!!!!!!!!!!!
04-07-2009, 12:25 PM | #10 |
Rep 1,311
You know what? This sounds crazy but i also today heard the same thing on my exhaust driving in the local area about 30mph low rpm's. It sounded like something dangling, infact I though someone tied a soda can to my car. I can't belive I heard it today for the first time after this post. I had the window down and heard it. So now I'm gonna go put it on a rack and check it out too. This is crazy. Glad to hear you found it, give me some hope.
04-07-2009, 12:35 PM | #11 | |
Rep 1,432
04-07-2009, 05:17 PM | #12 |
Rep 1,311
yep, that has got to be it...I hope. I'll have to put it on the rack tomorrow and let you know. Sure would be real strange if it turned out to be the same thing.
04-07-2009, 09:10 PM | #13 | |
Rep 1,432
Cheers!
04-08-2009, 01:26 PM | #14 |
Rep 1,311
Well what ever that noise was it's gone now. I put the M on the rack today and checked everything out underneath. Everything is tight, exhaust is tight, no rattles, etc. So what ever it was it's gone. Definitely didn't hear anything like I did yesterday driving around. Maybe it was some stones or something.
09-06-2009, 02:38 PM | #15 |
GOT M
15
Rep 138
OK it's my turn. After installing my Riss Racing exhaust I've had a "vibration" in the car. It gets bad enough between 2k-3k that you feel it everywhere. (in the seats, shifter, peddles) I've looked up under the car and don't see the exhaust touching anything anywhere. I've also touched the exhaust while running and it seems that there is a lot of vibration coming from the CAT to secondary CAT area. In this area is also some kind of "guide rod" attached to the rear of the transmission. I'm guessing this is where the vibration is traveling into the car from.
1. Is it normal the exhaust upgrades increase vibration in the exhaust to do Resonance? 2. Can I move the "guide rod" to eliminate the path the vibration is taking into the car through the transmission.
09-06-2009, 05:31 PM | #16 |
yodog
197
Rep 5,025
I Have the RR xpipe with hfc. I haven't noticed any vibration that came across as abnormal. You sure it isn't just the increased sound of the xpipe? Could you explain the "guide rod" more? I'll pay more attention for any rattles...
09-06-2009, 05:44 PM | #17 |
GOT M
15
Rep 138
I don't have the x-pipe, just the RR exhaust. The "guide" looks like a 1 inch piece of sheet metal that bolts onto the back of the transmission then bolts around the exhaust between the primary and secondary CATs. I'm guessing I could remove it with no impact, but want the "experts/M3 gods" to chime in. I defiantly don't think it is normal. I would swear it's touching somewhere, but I've looked. When the car is running you can feel the exhaust pipe near the primary CAT on the driver side vibrate pretty extremely.
09-06-2009, 05:47 PM | #18 |
yodog
197
Rep 5,025
Ah I wouldn't know, I replaced the stock primarys and secondaries. Maybe someone else can chime in
09-06-2009, 06:49 PM | #19 | |
Rep 2,736
‘23 RRS First Edition
'22 X7 M50i '18 R8 V10+ http://www.bimmerpost.com/forums/attachment.php?attachmentid=133578&d=1204654487[/IMG] |
09-15-2014, 09:55 AM | #20 |
Rep 65
I had the same issue on my 2012 BMW F30 Sport. Turns out it was the Exhaust Flap Actuator. Go figure. Hope this helps.
'12 Jet Black 328i 6MT Sportline
Originally Posted by JBasham Caddy ATS . . . finally, a decent rental car option. |
09-15-2014, 11:20 AM | #21 |
Bad Lieutenant
232
Rep 3,517
The M's don't have a flap in the exhaust, on either side.
09-15-2014, 06:28 PM | #22 |
Rep 7,541
The new ones do
