09-15-2011, 05:18 PM | #1 |
Rep 570
HPDE - Inflation Pressure ZCP
Anyone running a ZCP at HPDE events give some advice regarding inflation pressures? I realize it's a bit temperature specific, but I'm planning to run around 38 psi all around (+3psi over stock) and see how it is.
First time to a DE event w/a 19" wheel car and this set-up. Thanks! -Brian |
09-15-2011, 05:28 PM | #2 |
Rep 2,464
Start with stock or +3, and check the temps & wear after your first session. Use chalk if possible. Also see this: http://www.m3post.com/forums/showthr...2#post10428472
2011 MINI Cooper S
previous cars: E92 M3, Z4MC, Z4 Roadster, E36 328 Sedan |
09-15-2011, 06:13 PM | #3 | |
Rep 751
09-15-2011, 06:20 PM | #4 |
Rep 5,678
38 to 40 HOT works well IMO which means somewhere between 32 to 34 cold. If you intend to run 38 cold (which likely means mid 40s hot) the car will not grip well, will feel very nervous and you will completely wear out the centre of the tire.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
09-15-2011, 08:32 PM | #5 | |
Rep 353
09-15-2011, 08:39 PM | #6 |
Rep 957
I believe the OP means stock suspension/camber and stock tires. And it's his first time, so he's going to start relatively slow with not much extra heat in tires. If that's the case, it's better to start at 38 cold and then check pressures every other session or so to keep them slightly above 40 hot. Why so high - stock tires have soft sidewalls that roll easily with stock camber, especially if steering input is not smooth, which is typical for first timers.
You will not notice a tiny bit lower traction, but you will appreciate saving more of your tires and having somewhat sharper steering feel. |
09-16-2011, 09:00 PM | #7 | |
Rep 361
09-18-2011, 01:24 PM | #8 |
Rep 570
Feedback
Thanks for the inputs, guys.
It was a cold morning up in NH (49 degrees and warmed to around 60 degs), so a bit tricky w/inflation. I started out at 38 cold all around and seemed to do okay. However, hot temps got up over 42 psi, so I lowered to around 40 psi hot. Got a little more grip and tire wear seemed reasonable for a one day event. I'll continue to experiment, but the day was a lot of fun and the car is great. -Brian |
01-19-2012, 07:36 AM | #9 |
Rep 776
01-19-2012, 10:31 AM | #10 |
Rep 4,445
I ran Conti 3s at the Nurburgring and the tires performed fantastic.
01-19-2012, 03:06 PM | #11 | |
Rep 776
Have you ran a different tire on the same track that you could compare the contis to? I figured, with the power and weight of the e92, that the contis would start to get loose after a few laps. Also, the outright grip on the street is very underwhelming. This is consistent with the relatively high tread wear rating. Last edited by turbo8765; 01-19-2012 at 03:06 PM.. Reason: spelling |
02-02-2012, 12:42 AM | #12 | |
octane chick
79
Rep 1,187
Drives: ex-M
I went to AD08s and it was a different universe. Re tire pressures, I dont have notes from the Conti weekends. On the Yokohamas after much experimentation I found it best to start at 28-29 and aim for 36-37 hot. YMMV. |
02-02-2012, 06:50 PM | #13 |
Rep 776
