12-05-2017, 07:51 PM | #1 |
Rep 742
Angel eyes out. Replaced ballast/bulb
Hi, my passenger angel eyes went out recently. I thought it was the bulb but I switched the passenger side bulb with the driver side, and no fix. I then switched the driver side ballast to the passenger side, still no fix. I then completely removed the passenger headlight and plugged it into the driver side and it worked. What the heck is going on? Anyone ever experience this? Seems to be an issue with the wiring on the passenger side plug, any input will be helpful!
12-06-2017, 02:03 PM | #2 |
469
Rep 4,938
maybe look at the wiring to see if there are any shorts. i've seen it where the jacket of the wire will break off sometimes and the + and - wires will be touching.
12-06-2017, 03:04 PM | #3 |
Rep 742
Wiring on the passenger side plug? (Plug that plugs in behind the actual headlight). Wiring seems to be fine within the headlight since it worked on the driver side.
