01-05-2015, 09:57 PM | #1 |
Rep 1,973
First 1 to 2 shift grinds on a cold morning? 6MT
Recently the temperatures have been dropping and I've been getting a strange problem with the 6MT. So on the first drive of the cold morning, when I go from 1st to 2nd the gear will grind…but only once. I'm not shifting it extra fast or slow, just how you will start out normally, shifting around 2000 rpm. After that initial grind, it will go into gear perfectly like nothing happened. No other gear does this except for that initial 1 --> 2.
Car has 20k miles and never had an issue when the temperatures were warmer. Anyone else experience this? Would a trans flush solve this? I've searched but mostly came up with grinding at a high rpm shift only. Any input is appreciated.
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
01-06-2015, 06:28 AM | #2 |
Rep 488
Drives: 2011 E90 M3 6MT
Mine does it. 22k. Normal. I always shift extremely gently for the first 1-2 shift on cold mornings. And I try to let the car warm up for a minute or two with the clutch out to warm the gear oil a bit.
01-06-2015, 09:36 PM | #4 |
Rep 361
I have had the same problem since I got the car new. My fix on a cold morning now is to double clutch the first shift. That solves the issue. What's weird is I keep my car garaged so the tranny really isn't that cold. Only happens on cold mornings though. 2013 with < 20k miles.
01-06-2015, 09:43 PM | #5 |
Rep 1,973
Thanks everyone…good to know it's sort of normal although it shouldn't be. I'll try double clutching the first shift next time, hopefully that solves the problem!
01-06-2015, 09:55 PM | #6 | |
Rep 361
01-06-2015, 10:01 PM | #7 |
Rep 659
Drives: 2007 E90 335i / 2011 E90 M3
My E90 ZCP has this quirk, and that's even though it is stored in a heated garage, and has just a tad over 1000KM (600miles) on it. Not unlike the 2nd to 3rd notchiness I used to experience in my old S2000....
A |
01-06-2015, 10:15 PM | #8 | |
Rep 1,973
I also had a s2000 and still to this date my favorite car ever. The transmission on that car was worlds better than the m3 or any transmission in BMW's! I miss it terribly..
01-06-2015, 10:20 PM | #9 |
Rep 659
I miss my S2000 dearly as well. The M3 is about the closest I've been able to get to that visceral feeling since, and I vow to keep it forever. I'm becoming a bit of a pack rat and nostalgic with my vehicles, hence the M3's low mileage
A |
01-06-2015, 10:26 PM | #10 |
Bad Lieutenant
232
Rep 3,517
Rpm too low
01-07-2015, 01:25 AM | #14 |
Rep 7,541
Mine does it sometimes when cold
01-07-2015, 02:45 AM | #15 |
Rep 4,381
There is a shift speed that would not grind even if you had no syncro at all in the MT...you just need to find that speed...try slowing it down a little and ease it into 2nd.
01-07-2015, 04:30 PM | #16 |
Rep 1,198
Drives: 2021 F87 M2c. LBB, 6mt
This also happens to me. I have 19k on the clock.
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
01-07-2015, 05:32 PM | #17 |
Rep 105
Happens to me as well, 31000kms. After the first time I thought it was me, but then it happened a couple more times, and I searched the web, and found out its the tranny.
Will be changing fluid in spring (in storage for winter) and like others have said, shift SLOW when starting out in the mornings. It sucks we have to deal with it, but we do, and if you make it a habit to always shift slow in the mornings you will get used to it and will become habit, even when warm outside. |
01-07-2015, 06:57 PM | #19 |
Rep 1,973
So today instead of shifting from 1 straight to 2, I went from 1 to N to 2 and it didn't grind. It wasn't double clutching because I just kept the clutch pedal in. Hopefully this solves the issue.
01-07-2015, 07:09 PM | #20 |
Rep 875
I've never grind the 1-2 shift, cold or warm on the M3 or any other car I have driven. I always take a ever so slightly pause/break in between the lever moving out of 1 and then moving it into 2nd. It then clicks into 2nd nice and crisp every single time. I think another poster posted this before as well. I learned and have been doing this on all manual cars that I have driven these years and never grind any of them. Pickups, prelude, s2000, brz, accord, integra, mazda. None of them will go into 2nd smoothly if you rifle the gear level straight into 2nd from 1st. They might not grind but you can tell the tranny is not happy about it. Try the pause and see if it helps. just my 2 cents. Cheers.
01-07-2015, 07:40 PM | #21 | |
Rep 922
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package '11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery) |
01-08-2015, 02:40 AM | #22 | |
Rep 4,381
The gear lever should move into each gear easily with minimum effort, if you are forcing it in then you are wearing out the syncros. Last edited by SenorFunkyPants; 01-08-2015 at 02:58 AM.. |
