01-22-2019, 03:36 PM | #1 |
Rep 1,286
Push Start- No start ideas?
Got in my car this am to go to work, push start with foot on brake like I have for the past 10 years, except today, ignition comes on, but no starter engagement and of course motor doesn't start. Not a peep. No luck at all, just sits there with no noise just all the lights on like normal pre-start.
1) Changed key battery, tried key in dash, no luck 2) Battery is good, only 2 years old, car ran fine yesterday, no issues. 3) Used my code reader, I have fault on the "Car Access System" "Code is AOC1 - Present, CAS output terminal 50" What does that mean and can I fix it or am I stuck with a tow to the shop? I'm pretty handy with this car, but this one is a complete stumper for me. Anyone experience or have advice as to what I might try next. Thanks |
01-22-2019, 03:44 PM | #3 |
Rep 1,286
Mine's an '09 so it still has a key slot if you want to use it for when you have a dead key battery, not sure I have a receiver in the steering column. Anyway, with the key in the key slot, it still just sits there and does nothing.
01-22-2019, 04:32 PM | #4 |
Rep 742
Starter is going out. It'll start eventually but you gotta push the start stop button like 20-30 times for it to finally crank. I got the same code when my starter failed. You can try disconnecting the negative terminal from the battery and plugging it back in, that seemed to fix my issue temporarily whenever it wouldn't start
01-22-2019, 08:21 PM | #8 |
Rep 413
Check the wiring from the jump start point over to the starter itself. A0C1 is triggered when voltage at the output of the starter relay to the solenoid is low. This happens when voltage drop downstream of the battery happens, usually as a result of a loose or oxidized connection.
01-22-2019, 09:01 PM | #9 | |
Rep 1,286
My starter hasn't made any unusual noises and I don't have any prolonged cranking before starting, it just stopped working. However, it's not unusual that I might have 3-5 stop starts every day and I'm at 137,000 miles so maybe the starter just decided to poop out. But sort of weird no warning at all, just now no function at all, not even a click. |
01-23-2019, 10:25 AM | #11 |
Rep 749
Classic starter problem. I had same exact symptoms with same code. I replaced the starter and I am back to the road. No issues since then. At mileage similar like yours starting will go out.
Replace the starter and don't waste your time with troubleshooting other issues. Unfortunately it is not easy DIY but it is doable. If I had to do it again, I will take it to an indy. |
01-23-2019, 05:18 PM | #13 |
Rep 1,286
Gentlemen,
Thank you for the advice and you guys are all pretty consistent that I need a new starter. Charged the battery up over night and tried it again this AM. Still no start, no noise, nothing, so I'm going to replace the starter. I'm pretty handy, have all the proper tools and there's a really nice DYI on our forum, so that's the plan. I'll let you know the outcome is once I get it in and done. |
///M Power-Belgium63464.50 |
02-03-2019, 05:16 PM | #14 |
Rep 1,286
You guys rock!!
New starter, new idle control valve (only did it because it's a nuisance to get in there and I was having cold start stalling), and now it's good as new. Spins motor a lot faster than the old one too. Thanks again for the spot-on advice. I'm a happy camper again!! Missed my car was fun to drive it again today. |
