  TireRack
      03-24-2013, 12:15 PM   #1
CorrectoMan
Correcto///Man
CorrectoMan's Avatar
Spacers on 18" OEM
I'm looking for a more aggressive look to go along with my stock 18" OEM E92 M3 setup, but couldn't find any posts (or pics) of anything other than aftermarket setups. Ideally, I'd like the rear wheels pushed out a bit and the fronts to be flush.
Actually, ideally, I'd like a new set of wheels, but priorities dictate otherwise.
I read the sticky on spacers, great info. I'm looking to hear from someone that has done the same, what they did, how the results were, and pics are always welcome
      03-24-2013, 02:24 PM   #2
Detroit M3
Detroit M3's Avatar
31
Drives: Murdered E92 M3
12mm up front 10mm rear
E92. ModeCarbon. iND. eisenmann. ACM Test Pipe. BPM Sport. KW.
      03-24-2013, 03:33 PM   #3
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
Here is mine with 12.5mm spacers all around.
      03-25-2013, 09:05 AM   #4
CorrectoMan
Correcto///Man
Very nice! Any issues with 12.5mm all around? Rubbing, etc? If you have any straight-on rear shots, would like to see how the stance looks from the back.
Also, would like to see pics of other OEM + spacers setups to see the difference in the look.
      03-25-2013, 09:22 AM   #5
CrucialScott
BMX Godfather
England
12
Drives: 2010 White E92 M3
Tons of threads if you use the search, this has been covered time and time again...
I think most people go for 15mm up front and 12/15mm on the rear if my memory serves me correct. I'm sure someone else will chime in if i'm wrong.
Otherwise the route i would go is to measure your own arch and use your brain to calculate the correct sized spacer to get the desired look you want!
      03-25-2013, 09:31 AM   #6
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
No issues at all with 12.5mm all around. However, if you want to be completely flush you will want to go more aggressive. Something like 18/15 f/r.
      03-25-2013, 09:51 AM   #7
Lorde
Ya ya ya, I am Lorde, ya ya!
Lorde's Avatar
Drives: E90 M3, 2015 SQ5
2008 BMW M3 E90  [0.00]
http://www.m3post.com/forums/showthread.php?t=262054
Tags
oem 18", spacers
Search this Thread:
Advanced Search
