12-08-2016, 12:05 PM | #1 |
Rep 1,749
Camber plates and increased cornering grip
Wonder those on stock edc suspension who added camber plates was tgere a significant improvement in cornering grip at the track?
12-08-2016, 12:12 PM | #2 |
Rep 1,325
Yes, when I ran the fixed dinan camber plates on my stock suspension, there was slight more grip (increased contact patch) and improvement on tire wear.
Large improvements come when the alignment is set up as a whole (toe, camber, etc). Camber plates are a must if you will be tracking regularly or even semi regularly. Not just from a performance standpoint but from a tire preservation/cost stand point.
12-08-2016, 02:21 PM | #4 |
///M Powered for Life
11477
Rep 10,328
I am not sure if there's an actual increase in cornering grip. That said, a plate like the GC street has little downsides and allows you to not rape the tires in one weekend
12-08-2016, 02:43 PM | #5 |
Rep 818
Definitely more grip, better turn in and much better tire wear. Not to mention that they are adjustable so you can have one setting for the street and another for the track. My plates are marked with street and track settings so while I'm swapping pads, it's just a couple of minutes more to set the camber as well.
12-14-2016, 03:29 PM | #6 | |
Rep 225
Drives: 2011 Space Grey E90 M3 DCT ZCP
Marc
2011 Space Grey Metallic E90 M3 DCT ZCP |
12-14-2016, 03:55 PM | #7 |
Rep 1,424
Yes. Depending on your experience you could start with a small camber increases taking a couple of steps to reach -2.7 or -3.2. Maybe start with -2, move to -2.5 when ready, then find a happy place between -2.7 and -3.2. The tire you run will also determine where you end up.
12-15-2016, 09:59 PM | #9 | |
Rep 356
12-15-2016, 11:32 PM | #10 |
Rep 20
Drives: C5 Z06
Correct me if I am wrong, but when you chance the settings on the plate, you have to adjust for it in the toe also
12-16-2016, 12:31 AM | #11 | |
Rep 818
They are easy to adjust. You just jack up the car and loosen the three bolts at the top of the strut and slide the strut in or out and then tighten. The Vorshlag plates have a little pointer that moves as you adjust the plates so you can have your alignment shop mark the street and track locations to make it easier to switch between the two. |
12-16-2016, 06:52 AM | #12 | |
11477
Rep 10,328
I have it set a around -1 for street and aligned for 0 toe. When you go to the track and move the plates to -2.5 or whatever, the toe change it does is exactly what you want for the track You could say this is a positive result of the suspension we have on M3s |
12-16-2016, 07:38 AM | #13 |
Rep 300
Watch out for too much toe out.
I initially had my toe set to factory while at factory camber...that resulted in too much toe out (at least for me) when set to -2.7 camber while at track. My car was way too tail happy in the corners....AND I was wearing out the inside edges of my tires. |
01-03-2017, 05:21 PM | #14 |
Rep 777
Drives: E92 2013 M3
like everyone before, yes noticeably better.
01-19-2017, 08:10 PM | #15 | |
Rep 537
01-19-2017, 09:07 PM | #16 |
Rep 54
With the right camber, you could get out of the corner and apply gas so much faster.
Gain 2 sec right a away at my local 2.75 miles track after installed the camber plates. |
01-19-2017, 09:55 PM | #17 | |
Rep 137
If it's your DD, then it becomes a bit more complicated, and more concessions may be required.
'18 GT3 - 6MT
'13 E92 M3 - street/track '07 Cayman S - track car '15 FRS - Sprint racecar '00 Miata - Enduro racecar |
01-20-2017, 01:14 AM | #18 | |
Rep 2,527
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
I was doing 1:54.05 lap times at Auto Club Speedway when my R-comps corded on me and I didn't want to waste the weekend. Fastest lap I've ever done at ACS was 1:52.9 on R-comp so the fact I was able to get to around a second on cheapo tires is great. They were able to hold me on the track through the NASCAR bank at 150 mph.
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
