      08-22-2022, 08:54 PM   #1
MTM
Drives: 2009 M3
Strange buzz/rattle from DCT
OK, so I hate to post one of those vague and slightly random posts, but don't have a lot of choice so here goes:
Recently my '09 E92 M3 w/ DCT (105k miles and daily driver) has started making a new noise. From inside the car, it sounds like a short buzz/rattle/hum that very briefly goes in and out just on either side of the first 3 or 4 shift points (am usually going too fast to hear it after that so unclear if it's hitting the remaining gears or not). One day, it even rattled quite loudly at idle after just starting the car.
Kind of makes me think like a heat shield is rattling against the DCT body or something? Lord willing it's not inside the unit itself (yikes!).
So here is the question...has anyone else heard of or encountered something like this? Would be good to hear others' experience before I put it on the lift and start poking around.
Changed fluid, filter, and pan gasket last year (about 10k miles ago) so likely not related.
      08-23-2022, 06:22 PM   #2
Redd
Highly likely a loose heatshield.
      08-23-2022, 06:45 PM   #3
spammysammich
spammysammich's Avatar
1585
2009 BMW M3  [10.00]
There is a weird stamped sheet metal fastener that is a 10mm nut/washer combined. Those go missing on quite a few cars, so I'm told.
      08-24-2022, 07:51 PM   #4
deansbimmer
deansbimmer's Avatar
3751
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
Most likely the vibrations at certain RPMs are causing a loose heat shield to resonate. Run through the various shields under the car and make sure they're not missing hardware. You can bend them a bit also to make sure they're positioned correctly. Also check the exhaust, contact with covers will cause buzzing or rattles.
      08-25-2022, 04:43 PM   #5
MTM
Drives: 2009 M3
Great suggestions...will poke around once my travels finish.
      08-26-2022, 08:31 AM   #6
John Simon
Drives: BMW E60 M5
May be it is a loose Heatshield/kickplate that is ratteling.
