      08-17-2022, 08:28 AM   #1
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
Stage 0+ Tune?
I like the stock engine tune. I've had other tunes and prefer drivability and predictability of stock (same with stock DCT tune...very much dislike the behavior of the GTS tune).
But i do miss the 8600 rpm fuel cut. And I might want to go faster than the stock limiter allows on track.
So is there a tune/tuner option for a base stock tune (with all OBD readiness set - I need to pass smog in CA) that ONLY increases fuel cut to 8600 and eliminates the speed limiter?
Cheers.
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      08-17-2022, 08:34 AM   #2
Frostynorth
Weirdo
Frostynorth's Avatar
Drives: 2011 e92 M3
You can use ECUWorks and do it yourself.
      08-17-2022, 09:11 AM   #3
tdott
Drives: M3
Yes very easy, ECUworx is one option.
If you were willing to learn some hex editing, you can make those changes yourself using MSS6xflasher. This stuff is talked about on na m3 forum if you wanted to learn more.
I was able to make the following changes with a hex editor from what I learned.
- Speed Limit removal
- Cold Start Rev limiter and temps
- Cold Start Removal
- RPM Limiters in each gear
- DTC code suppression
None of the tune tables were touched, all those I left stock.
brettcp348.00
      08-17-2022, 02:55 PM   #4
akkando
akkando's Avatar
5865
Cheers.
Dinan will pass CA smog ( or it should as it's CARB approved )
      08-17-2022, 03:27 PM   #5
wyatth
Drives: E90 ZCP
Yeah, I'd do Dinan. Cheap, CARB approved, 8600 RPM, and feels like stock IMO.
