07-08-2022, 01:44 AM | #1 |
Rep 2,138
Drives: 2011 E92 M3
So, I am posting a new thread so that I do not Bogart the other ESS-625 thread.
Here is my issue - I am not making CONSISTENT boost. Other info: IATs are usually under 40C but sometimes they climb to 45C when stuck in traffic. No codes. No CEL. Running test pipes so I no longer have primary cats. Sometimes, the car pulls hard and my P3 gauge will capture 7+ PSI. This is especially true in 1st gear. I can hear it making boost, nice whistle and when I lift, there is a whole lot of PSHHHHHH as it bleeds excess pressure. Other times, it struggles to make over 2PSI. This is especially true when running WOT in higher gears. Faster than stock, but it just does not pull like it sometimes will. And this is so inconsistent. After struggling to make boost over and over, suddenly it will bull like a freight train and make all of the boost. I have removed my plenum and checked all of the intake boots look just fine. I lubed up all of the seals and checked all of the vacuum lines. All hose clamps are tight. All lines look good. I put a new fuel tank vent valve into the car when I installed the supercharger. When I re-installed the plenum, everything is lined up perfectly. Given the intake boots are lubed up, the plenum slides on easy. Nothing is folded up. I push down as hard as I can, and I weigh 250+. Then, I put a rag on the plenum and hammer it with a rubber mallet just to make sure it is fully seated. Then I tighten all of the clamps, making sure nothing moves or shifts. I took the diverter valve off of the plenum to check it. Looks OK. The little o-ring had a little pinch of rubber on it but it seemed fine. I took the DV apart and the diaphragm looks fine. Movement is not perfectly fluid, but not bad. I put a little oil on the shaft to make sure it is lubricated. Finally, I checked the belt. If I rotate the pulley with a wrench clockwise while looking at it (not the normal direction of force), it slips with 11Nm of force. If I try to rotate it counter clockwise, it will not slip and actually loosened the bolt at over 35Nm (I ran out of blue locktite during the install - give me an opportunity to fix that). Regardless, I do not think that there is any way I have belt slip - the belt looks 100% fine, as does the pulley. After all this, I am still running into Jekyll and Hyde boost. And it is very frustrating. SOOOOOO FRUSTRATING!! Has anyone else ran into this behaviour?? Is there anything that I should look for when I get my boost leak tester? Is there a chance that the DV is just faulty? Any help would be super awesome!! Note: I tried to install the high boost tie downs but I am sure ESS sent me the old ones as there is WAY to much of a gap to compress with the bolts. Unless the plenum is not seated properly. But I do not think that is the case as I said. Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... Last edited by Scharbag; 07-08-2022 at 01:49 AM.. |
07-08-2022, 05:07 AM | #2 |
mTekMods
2143
Rep 2,902
Where is the boost reference line tapped?
07-08-2022, 09:12 AM | #3 |
Rep 2,138
Drives: 2011 E92 M3
Boost line is tapped into the DV vacuum line.
07-08-2022, 09:31 AM | #4 |
Rep 725
I was making full boost on my ESS-625 kit but brought it back to have it removed the next day after installation. The issue was, it felt slow and the car was not fun to drive compared to the Harrop SC I had on my previous car. That is all I'm useful at diagnosing, which isn't useful to you. Hope you figure it out.
07-08-2022, 12:35 PM | #5 | |
Rep 482
I stumbled across a post while I was supercharger researching complaining about low boost. Their solution was to replace the T in the BPV with a Y, ala this post by GMP: https://www.gmpperformance.com/galle...ibach-springs/
Hope you find a resolution. I just put an order in for a G1, so would be good to know if I should just order a Y and have that installed instead. Going to order some new throttle body boots, as well. Quote:
SYT_Shadow11490.00 |
07-08-2022, 01:55 PM | #6 |
Rep 1,230
MilehighM3915.00 |
07-08-2022, 02:43 PM | #7 |
Rep 482
07-08-2022, 04:47 PM | #8 |
Rep 1,230
07-08-2022, 10:55 PM | #9 |
Rep 2,138
Drives: 2011 E92 M3
Removed the boot gauge. Made sure all was tight. Still feels Jekyll and Hyde FFS. Seems to work better if I roll into the throttle.
Does the DV need positive boost to keep it closed?
07-09-2022, 07:51 AM | #10 |
Rep 2,002
Might be a good idea to take the car to a authorized ESS shop or a shop with a lot of experience installing these kits. It has to be something simple....
My ESS 650 Kit on my car has run flawlessly for 5 years / 20,000 miles....never a issue, boost leak, or anything. These kits are very reliable and consistent....don't get frustrated...if you don't take it to a shop, maybe call ESS for trouble shooting?
ESS 650 ACM-R Upgrades |
07-09-2022, 09:01 AM | #11 |
wannabe
252
Rep 819
You have a vacuum/boost leak, and from the sounds of it, its vacuum source related. Cheack the lines you added individually for pinholes/cracks/kinks. The Vf kit taps the vacuum at a different point, but still taps from the same source.
Also, your blow off valve should be adjustable. Try tightening the actuator a tad
E90 M3 - 6speed - slicktop - single hump
07-09-2022, 10:35 AM | #12 | |
Rep 2,138
Drives: 2011 E92 M3
An I am sure I will figure this out. I will wait until I get the boos leak tester to gather some more info and then involve ESS or a pro.
07-09-2022, 10:37 AM | #13 | |
Rep 2,138
Drives: 2011 E92 M3
I will look at the DV again. I would rather not adjust it much as sometimes it is fine, other times it is not. So, I think you are right that it is a vacuum line issue. I will keep digging. Cheers,
07-09-2022, 10:19 PM | #14 | |
Rep 2,138
Drives: 2011 E92 M3
Took it for a test drive and same issue. If I roll onto the throttle in second gear and run it to red-line, I will make 8PSI. If I grab third and hammer on it, I struggle to make 4PSI. I do not have long open roads around me so it is hard to test properly. I also do not have a dyno in this village that I live in... FFS. I noticed that if I rolled onto the throttle in 3rd, boost would start to build. If I then go to WOT, boost dropped and then it again struggles to make boost. It is almost like the DV just cannot hold the boost... I want my damn boost leak tester!!! Come on Amazon. Anyway, this is beginning to piss me off a little bit.
07-10-2022, 08:09 AM | #15 | |
wannabe
252
Rep 819
Ecu is possibly sensing wheel slip and closing throttle to try to control, thus limiting boost. Also try driving in mdm mode and see if the same issue persists.
spammysammich1585.00 |
07-10-2022, 10:08 AM | #16 | ||
Rep 2,138
Drives: 2011 E92 M3
Gets squirrely when it makes boost for sure. That said, the Firehawk Indy 500 275s do certainly provide good grip!!!
07-10-2022, 09:53 PM | #17 |
Rep 2,138
Drives: 2011 E92 M3
How should the diverted valve be adjusted? Mine is fully open under vacuum. With the car running, I was able to turn the adjust many turns before it started to not be fully opened any more.
Does anyone have photos of their G1 DV showing how the far out the adjuster is sticking?
07-11-2022, 12:43 AM | #18 | |
Rep 35
Is the collar that sandwiches the oring on the dv in the correct way? I had mine backwards and the Valve wouldn't seal once it open after a shift. The collar shouldn't be flush with the valve so when you bolt it to the manifold it sandwiches the oring. Check that. |
Scharbag2620.50 |
07-11-2022, 01:28 AM | #19 | ||
Rep 2,138
Drives: 2011 E92 M3
07-11-2022, 07:12 AM | #20 |
mTekMods
2143
Rep 2,902
The blow off valve isnt closing
07-11-2022, 09:19 AM | #21 |
Rep 2,747
Plug the intake hole and pull the hose on the DV. You'll be able to hear it working properly or improperly. You shouldn't have to mess with it, it's factory calibrated. If you have attempted to mess with it, hopefully you counted turns and can put it back?
9ers
07-11-2022, 09:45 AM | #22 | |
Rep 2,138
Drives: 2011 E92 M3
Cheers,
Tags |
boost leak, ess |
