06-01-2011, 01:12 AM | #1 |
Rep 471
light flywheel...slap, clunk...???
I dunno exactly how to describe it, or whether or not it's normal.
When you're in first or second gear, and you lightly hit the gas, but have to stop, you kick in the clutch with the brake pedal, correct? For example, when you're inching away in tight spaces you have to slight dap the gas, then brake. etc.. I get this noise of either the clutch of the fly wheel.. like "clack clunkity clunk" It was somewhat there in my previous car, but not as loud as this one. I'm assuming it's cuz of a lighter flywheel than my previous car? and that's also why the revs drop so quickly? Am I not doing it right? normal or not?
2011.75 E90 ///M3 6MT | JB | Blk | CF | ZCP | ZCV | ZCW | ZP2 | 403 | 6NR | 752 [Sold T.T]
'95 Integra GS-R [Stolen-RIP] | '05 Legacy GT Stg 2[Traded] | '08 STi Stg 2+[Sold] |
06-01-2011, 01:17 AM | #3 |
Rep 471
you can also hear it slightly when you shut off the engine...
06-01-2011, 01:17 AM | #4 | |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
06-01-2011, 01:19 AM | #5 | |
Rep 471
"why are you doing that you're doing something wrong" I should say "that's how it is in the M3 so STFU!"
06-01-2011, 02:46 AM | #6 |
Rep 4,381
Sure its not just the drive train (propshaft/driveshaft) making the noise?
There is some movement in a dual mass flywheel but I would be concerned if it made a noise you could hear inside the car. |
06-01-2011, 05:15 AM | #7 |
Rep 288
It's a bit embarrassing when manoeuvring in the car park. Need to depress the peddle quite gently to reduce the clatter. I used to think the tranny was falling apart. But I found a guy at the gym with the identical M3. Drove it around a bit and his did the same. Maybe not quite as loud as mine but similar. So it's normal. Don't worry. Enjoy its idiosyncrasies.
06-01-2011, 06:05 AM | #8 |
Rep 4,445
It's BMW's signature Death Rattle, a $3k option to scare off "would be" criminals by tricking them into believing the car will breakdown if stolen. Embrace it
06-01-2011, 07:57 AM | #9 |
Rep 3,329
She shouldn't be talking in the car anyways... gotta hear the roar of the S65
F80 ///M3 6MT Avus Blue ZCP |
06-01-2011, 10:48 AM | #10 | |
Rep 2,000
Just how heavy is the flywheel in the E9X, and how much lighter is it compared to the E46 model? Bruce |
06-01-2011, 07:28 PM | #11 |
Rep 471
..should I post a youtube vid?
06-02-2011, 03:43 AM | #12 | ||
Grease Monkey
295
Rep 2,646
06-02-2011, 12:45 PM | #13 | |
Rep 2,000
I am challenging your assertion. As far as I know, the current M3 flywheel is a heavy, dual-mass unit designed specifically to counteract gear rattle at idle. As far as I can tell, you are making an assertion with no evidence to back it up. If I'm wrong, just tell me, without bluster if you can manage that. Bruce PS - It's also possible that the OP is getting noise from the throwout bearing. Last edited by bruce.augenstein@comcast.; 06-02-2011 at 12:52 PM.. |
01-15-2012, 10:09 AM | #14 |
Rep 5
I have the 2010 e93 auto dct.... Having the same clunk sound when car is about to stop in D2 mode...itsless in d4 and if i manually changefrom 2 to 1 itwont happen.....i think its normal... WHAT I WANTED TO ASK IS THAT I GET THE SAME NOISE BUT LOUDER EVERYTIME WHEN I CHANGE THE GEAR TO REVERSE OR D AT STANDSTILL...car has done 5000 miles... The noise which comes at standstill when i changeto reverseor d didnt use to come till the first service i think, i maybe wrong...plz help.... When driving shiftsare butter smooth and super fast with no sound or jerk..PLZ HELP REGARDING THE SOUND COMING AT STANDSTILL WHEN CHANGING TO D OR R
01-15-2012, 10:57 AM | #15 | |
Rep 244
I do find a subtle feathering or blip on the gas before engaging the clutch eliminates the clunk for the most part. This is only after warmup. In cold conditions for the first 2 or 3 minutes, the MT sounds like a bucket of bolts and requires a light touch. No issues from second gear and up. |
01-16-2012, 10:03 AM | #17 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
I'm pretty sure what the OP is experiencing is from the driveline; specifically the diff. BMW for some insane reason decided to mount the diff with very flexible mounts. I have to work the clutch very carefully at low speeds to avoid the 'clunk'.
I'm with Bruce on the flywheel weight. My e46 had a boat anchor for a flywheel. I don't believe BMW has changed their tune significantly with our cars. On the other hand, what's funny, is that I still get a gear rattle out of my car, even with all the dual mass complication BMW has put into it.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
01-16-2012, 01:16 PM | #18 | |
Rep 2,792
01-16-2012, 01:21 PM | #19 |
Rep 4,254
100% normal. It is the throwout bearing, however. Not the flywheel. Race clutches sound quite a bit different.
You can easily replicate this sound in 1st gear (as opposed to second) with a very brief, abrupt, acceleration without fully releasing the clutch pedal, and immediately shoving it back in. Will get your throwout bearing sound every time. Normal. Personally I love the mechanical-ness of it all. You should learn to love it, too edit: I should add this has been the case for nearly all new BMWs since the E46. Happened in my E46 M3, E82 135i, etc.
///M Power
01-16-2012, 04:02 PM | #20 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Read the M3 supplement to your owner's manual. It (the noise) is entirely normal.
You have to be 100% behind someone before you can stab them in the back.
David Brent |
01-16-2012, 08:19 PM | #21 |
Lurker
78
Rep 812
The dual-mass flywheel makes it worse, but I think it's just driveline (ie, diff, driveshaft, transmission) gear lash. It's the same sound and behavior as my wife's Z3 but worse.
It's a sign that you should let it warm up more before driving.
01-16-2012, 10:20 PM | #22 |
Rep 236
yup normal... it doesn't really happen to me anymore I found a new technique to prevent it, for 90% of the time atleast.
Try this: when at low speeds or in situations as OP, push the clutch in very gently and smoothly. Once you smoothly past the point of engagement, you can just push the clutch in all the way. BUT, you have to get on the clutch as soon as you let off the gas, otherwise it will "clunk". hope it works for you because it does get kinda annoying! |
